Help: Which bolt (size, where to buy) for mounting wall bracket to Pioneer Kuro? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-21-2011, 11:38 AM - Thread Starter
cannga's Avatar
Quoted: 926 Post(s)
Liked: 418
Hi I recently purchased used KPR 600M and Pro 950FD and am now planning to wall mount both. Sorry if the info has been posted, but I couldn't find through search.
1. What bolt (size and length) should I use to attach the wall bracket to the back of the Pioneer plasma please? I assume same size for all Kuro's?
2. Where to buy them? Home Depot type stores or are there nicer bolts made specifically for these plasma that I could get from a dealer?
Thanks in advance.
Regards, Can
My System & Theta Casablanca CBIII HD Mini-review CBIII HD - the processor for music lovers: clarity and richness, stunning imaging, off-the-chart dynamics.
High-End Speaker Impressions & Audio Comments Vinyl and tube preamp = completion of a fantastic audio journey.
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is online now
post #2 of 4 Old 01-21-2011, 11:58 AM
daniel'son's Avatar
Quoted: 33 Post(s)
.. my 1150hd manual, which is similar to 950 states M8 screw. Unsure how corrolates to standard screw, but was included in mount kit (Peerless).
note: actually, model 950 is pictured in my *.pdf manual (download).
add: probably available from HD, Lowe's or Ace Hardware.
from manual:
Caution
• Be sure to use four or more mounting holes symmetrical to the vertical and horizontal median lines.
• Use M8 screws, which go 12 mm to 18 mm (0.5 inches to 0.7 inches) in depth from the mounting surface of the plasma display. See
the side view above.
• Be careful not to block the ventilation opening at the rear of the plasma display.
• Be sure to install the plasma display on a flat surface because it contains glass.
• The screw holes other than the above are to be used only for the specified products. Never use them for mounting non-specified
products.
daniel'son is offline
post #3 of 4 Old 01-21-2011, 02:43 PM - Thread Starter
cannga's Avatar
Quoted: 926 Post(s)
Liked: 418
Thanks for the helpful reply. I did not realize wall mount kits could/would include bolts/screws.
I was looking at Peerless ST670 as recommended by a few here but I don't need the tilt function so probably will get SF660. http://www.peerlessmounts.com/dyn/Pr...s.aspx/av/6138
Which kit do you have?
from manual:
Caution
products.
Regards, Can
post #4 of 4 Old 01-21-2011, 03:07 PM
daniel'son's Avatar
Quoted: 33 Post(s)
.. i'm using the St6*0; would suggest if using the flat-mount, you might look at getting some Ultra HDMI L-shape adapters .. very useful when fitting HDMI cables, given the space from the wall.
*correction: checked box on extra mount I bought; its the ST660. From recall, believe the ST670 adds extra bracket for attachment to 3rd stud on Flat Panels
up to 65". Other mounts to consider are from Sanus & Promounts, but have been satisfied w/ quality of the Peerless.
