Toshiba 42HP66 Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-21-2011, 03:35 PM - Thread Starter
Handcd's Avatar
I recently moved and now I can not get any signal out of my optical out on the TV. It worked before the move. I purchased a new TV for another room and when I plugged the optical cable into it, and my surround sound worked fine. When I go into the menu system the "Digital Language" option is grayed out and I can not select it. I turned off the on-board speakers and nothing I turned off the sound stabilizer nothing. I think if I could get to the "Digital Language" option on the menu I could solve it, but I can't get there. I have read the manual and it does not discuss that being grayed out. Any Idea's??
Handcd is offline
post #2 of 2 Old 02-24-2011, 08:01 PM - Thread Starter
Handcd's Avatar
Does anyone have a Toshiba 42hp66 that they could look at their audio settings to see if the Digital language is gated out or if they are able to switch it between Dolby digital and PCM.
Handcd is offline
