Plasma double image - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 02-24-2011, 05:50 PM - Thread Starter
Pyrothermia's Avatar
Why does plasmas do a double image on 30fps games etc?
Is the response time just too fast?
Pyrothermia is offline
post #2 of 35 Old 02-25-2011, 09:46 PM - Thread Starter
Bump
post #3 of 35 Old 02-26-2011, 06:55 AM
Acid Snow's Avatar
TBH I don't know the technical reasons, and I haven't seen anyone else properly describe why it happens, but don't worry, it happens to every TV. Even the KUROs have the double image from 30fps games, it's just a side effect of the game, not the TV
Acid Snow is offline
post #4 of 35 Old 02-26-2011, 06:50 PM - Thread Starter
Phew
Cause before i thought it was motion blur but on a closer look i saw there was a double image. Really annoying, i hope they make 60fps only games in the future
post #5 of 35 Old 02-28-2011, 06:31 AM - Thread Starter
Is double images on 30fps games making anyone else insane? xD
It really is annoying
post #6 of 35 Old 02-28-2011, 07:33 AM
Acid Snow's Avatar
30fps games have only recently become annoying to look at, because everyone now owns 40" screen TVs and bigger, and the resolution is becoming sharper... Back when everyone had 17" CRTs, no one cared, because the "double image" effect wasn't smeared 2-inches across the small screen. What game are you playing anyway
post #7 of 35 Old 02-28-2011, 06:46 PM - Thread Starter
Haha, alot of 30fps games.
post #8 of 35 Old 03-02-2011, 07:28 AM - Thread Starter
Is this called 'judder'?
Every 30fps game seems unplayable with a plasma lol.. Should i just go LCD next time i buy a TV?
post #9 of 35 Old 03-02-2011, 05:05 PM
Mastperf's Avatar
LCD doesn't fix the problem. With LCD get blur or you can use frame interpoation but that adds a lot more input lag plus artifacts. If you use game mode on LCD, frame interpoation is the first thing to go. Your only hope is to switch to pc gaming and run all your games at higher frame-rates.
Mastperf is offline
post #10 of 35 Old 03-02-2011, 05:55 PM
fcwdev's Avatar
Quoted: 47 Post(s)
Try forcing 1080i
fcwdev is offline
post #11 of 35 Old 03-02-2011, 07:17 PM
Cahn2126's Avatar
Which games specifically are you talking about? I just got a Plasma and don't notice this.
Cahn2126 is offline
post #12 of 35 Old 03-03-2011, 01:00 AM - Thread Starter
Here is a video : http://www.youtube.com/watch?v=0nRf0...el_video_title
I play Heavy Rain, God of war 3, Killzone 2 and 3, Dead Space 2
post #13 of 35 Old 03-03-2011, 08:57 AM - Thread Starter
This thing is driving me crazy xD
How can you all play 30fps games on a plasma and not see it?
post #14 of 35 Old 03-03-2011, 09:15 AM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
i'm on a LG plasma and don't know what you're talking about.
Goatse is offline
post #15 of 35 Old 03-03-2011, 12:01 PM - Thread Starter
:s
post #16 of 35 Old 03-03-2011, 03:49 PM - Thread Starter
What should i do?
Is this really normal?
Everyone i asked say they don't see this stuff,
post #17 of 35 Old 03-03-2011, 05:26 PM
Big Brad's Avatar
Quoted: 300 Post(s)
Liked: 419
What you are seeing is most likely the games fault, not the TV. I've played most of the games you listed on my LG 50PK550 (Killzone 2 and 3, Heavy Rain, Dead Space 2 and also RE5 which you showed in the video), and while it is noticeable if I look for it, I typically am more focused on the game. Story is more important to me than graphics, and I can deal with things like lack of V-Sync or low textures if I find the game appealing enough.
This is likely a limitation of technology. If you find it really bothersome, you may want to consider going to PC gaming. You aren't going to find 60fps games becoming the norm on the current gen consoles. There hasn't really been talk of next gen consoles coming out in the near future. Probably not until 2013 at the earliest.
While it may be an issue to you, you're overreacting a bit in my opinion. It does not make the games unplayable for the majority of people (on AVS included). I would think DLP rainbows or ghosting in stereoscopic 3D games to more of a deterrent than a minor amount of judder.
PSN ID/XBOX Live! Gamertag: BiffCo
My SD/HD movie collection
Big Brad is offline
post #18 of 35 Old 03-03-2011, 11:42 PM - Thread Starter
Alright, hopefully it will diminish a bit in time. But it is normal right?
It is just really annoying for me coming from a CRT that had no problems and it was very small, so when i got the big TV i saw all the flaws.
post #19 of 35 Old 03-03-2011, 11:59 PM
Noah's Avatar
Some 30fps games are using frame blending techniques to make the framerate seem smoother. It has nothing to do with your display.
RE5, in particular, is known for this. It seems you've noticed that.
Noah is offline
post #20 of 35 Old 03-04-2011, 12:11 AM - Thread Starter
I don't even have RE5, it was a video i found haha.
For example playing Dead Space 2, panning around while you see text or other things i can see the double image that looks like blur.
post #21 of 35 Old 03-04-2011, 10:01 AM
Mathesar's Avatar
Quoted: 18 Post(s)
I noticed the same thing going from a 34" CRT to LCD & Plasma but I got used to it, nothing out there is better than a CRT when it comes to motion clarity.
Mathesar is offline
post #22 of 35 Old 03-04-2011, 10:17 AM
jwickers's Avatar
IIRC a lot of game have Motion Blur, which is a filter in the game that makes thing blurry when the picture moves. I remember for example i had this on Crysis (PC) so it is not console only. It also annoyed me somehow so i disabled it in the settings, not sure if you can do that on a console.
jwickers is offline
post #23 of 35 Old 03-04-2011, 12:03 PM
Mathesar's Avatar
Quoted: 18 Post(s)
Also a good point .. I recorded this video off a CRT and you can see the frame doubling effect used in RE5 when panning the camera http://www.youtube.com/watch?v=xzCapovsAnc
Mathesar is offline
post #24 of 35 Old 03-04-2011, 01:10 PM - Thread Starter
Thing is i notice this double image on all 30fps games, never saw it on my LCD
Alot of people say they don't even see it.
Can someone tell me if this is normal for all 30fps games on a plasma or if it is a defective TV or something?
post #25 of 35 Old 03-04-2011, 07:02 PM
jvernon's Avatar
How many times are you going to ask the same question? It has been answered many times in your many threads.
jvernon is offline
post #26 of 35 Old 03-05-2011, 01:31 AM - Thread Starter
post #27 of 35 Old 03-05-2011, 12:52 PM - Thread Starter
Why are plasma "oh-so-good" for gaming when 30fps games looks like crap? Majority of games are 30fps.
post #28 of 35 Old 03-05-2011, 04:50 PM
joe52985's Avatar
It happens in all 30 fps games, regardless of display type. Because of inherent motion blur on LCD it is less noticeable. If you want smooth motion. Be prepared to pay for it in input lag, typical motion interpolation systems add tons, making games mostly unplayable.
joe52985 is offline
post #29 of 35 Old 03-05-2011, 08:47 PM
jvernon's Avatar
joe, there is no point in trying to help him. Do a quick post search and you will see he repeatedly asks the same question over and over.
jvernon is offline
post #30 of 35 Old 03-05-2011, 09:05 PM
Big Brad's Avatar
Quoted: 300 Post(s)
Liked: 419
Because plasmas offer less input lag and better motion handling over an LCD. If a game looks like crap on a plasma then it will still look like crap on an LCD. I don't know how that's so hard to understand.
If it annoys you then sell your TV and get something that you'd prefer. But posting redundant questions on the same issue even though it's been answered more than a few times is not helping your cause.
Big Brad is offline
