Panny PHD Pedestal - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2011, 10:35 PM - Thread Starter
Denon_Kid's Avatar
my old panny th42phd8uk has to come off the wall and placed onto a pedestal. anyone know of cheap pedestal(s) that will fit without costing a fortune.
Denon_Kid is offline
Old 02-27-2011, 08:53 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Nothing cheap. The only Panasonic stand that will fit the 8UK is the original Pro model's TY-ST08K or the older TY-ST42PA20 from the 2003-2004 consumer models (it's the same stand but with silver accents instead of all black).
There is one universal aftermarket stand (the Premier PSD-TTS/B) that utilizes the wall mounting points on the TV and i've seen these as low as a hundred bucks.
http://www.premiermounts.com/product.asp?PartID=1252
If you're handy with building things, you could buy a cheap $30 wall mounting bracket and fabricate a base and uprights to bolt it to and make your own pedestal base.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 02-27-2011, 02:20 PM - Thread Starter
Denon_Kid's Avatar
yes, i do have fab skills, i have mig, tig, and plasma, so taking what i have on wall and making that work with a piece of steel for the base may be the way to go. maybe i fab something so that the wall mount can bolt to, this way i can always go back to the wall if i want. thnx.
Old 02-27-2011, 02:36 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
Power Strut PS200EH sold at electrical wholesalers:
Or PS200S slotted:
Randy
Old 02-27-2011, 05:39 PM - Thread Starter
Denon_Kid's Avatar
randy,
thanks for the info. i'll need to fab a heavy base, was thinking 1/4" with a full size footprint, and then add a smaller piece on top, kinda making a stepped look, should be heavy enough. then i have some self stick felt i will put on bottom to prevent scratching the furniture, etc.
Old 02-27-2011, 06:09 PM
wojtek's Avatar
New TY-ST08K pedestal stands are on Ebay for $160-180.
I pulled an absolutely perfect TY-ST08K pedestal stand from my RIP 50PHD8UK and the bidding on ebay is right now at $50.
wojtek is offline
Old 02-27-2011, 08:24 PM - Thread Starter
Denon_Kid's Avatar
but the ebay item is $35 to ship. you know how much steel i can get for $85? a lot.
i'll likely just get a couple pcs of 1/4 plate, cut it to shape with my plasma (plasma is like hot knife in butter and the knife never gets cold). then i might weld a short upright using 2.5" OD 1/4" wall steel tube, and then just make a easy frame using the electrical channel so my wall mount can bolt to it. if i spend $40 for the steel and 2hrs of my time then its well worth the fab DIY.
or, i can fab the TY-ST08K..... bottom pc is 1/4" plate, short upright, then the horizontal can be 1/8" plate, then i can weld steel rod on the ends like the TY has.
i'll post pics as i fab it (whatever "it" is).
thnx
Old 02-28-2011, 06:46 AM
wojtek's Avatar
thnx
DK - sounds like you will have much more fun fabbing your own stand anyway.
Good luck. If you are in the NYC metro area you could pick up the stand for free. I have to charge $35 shipping because I want it professionally double packed. It is a heavy item and could be bent by the "throwers", (ie UPS or USPS).
wojtek is offline
Old 02-28-2011, 05:27 PM - Thread Starter
Denon_Kid's Avatar
i like to fab, but ut oh, i am in nyc area. PM sent. thnx.
Old 02-28-2011, 09:15 PM - Thread Starter
Denon_Kid's Avatar
wojtek,
ebay got too pricey very fast. thnx for the opportunity, but i'm back to fab'ing.
