Official Panasonic 2011 TC-PxxST30 Thread [No Price Talk] - Page 249 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #7441 of 8510 Old 02-20-2012, 06:22 PM
DOC1963's Avatar
Originally Posted by kwaidonjin View Post
Found july 2011 sn 1208, Does that mean I will have the fluctuating Brightness?
Absolutely no buzzing(from more than 2 ft. away.) 1 dead(dark) pixel in lower right of screen. hard to notice.
PDP EEP value of 82.53
The value shows that you have the patch preinstalled from the factory. You should have no problem with fluctuating brightness.
DOC1963 is offline
post #7442 of 8510 Old 02-20-2012, 08:15 PM
kwaidonjin's Avatar
OK, thanks, I thought my Sn had to be higher. But glad to hear.
kwaidonjin is offline
post #7443 of 8510 Old 02-20-2012, 11:58 PM
barrance's Avatar
Originally Posted by carpboy View Post
CATS on?
Yes, it was on and so was the other black leveling setting. I turned these features off as well as AGC and punched in some custom settings and everything is all good. I couldn't be happier with this purchase.
barrance is offline
post #7444 of 8510 Old 02-21-2012, 08:48 AM
asmealio's Avatar
Quoted: 17 Post(s)
Originally Posted by gstelmack View Post
I didn't want to bring the whole post over, folks can follow the link, but thank-you for these settings. I tried them out last night instead of bouncing back-and-forth in the Disney WOW options and they are pretty darn good.
No problem
asmealio is offline
post #7445 of 8510 Old 02-21-2012, 12:39 PM
shrimpman's Avatar
Callibrator in Los Angles recommendation. Can't find listings anywhere.
shrimpman is offline
post #7446 of 8510 Old 02-21-2012, 01:00 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Here's a thread on calibrators, hope this helps
Sorry my link didn't post.
whipit is offline
post #7447 of 8510 Old 02-21-2012, 04:11 PM
shrimpman's Avatar
No link but found it. Called Accucal, Jeff.
post #7448 of 8510 Old 02-21-2012, 04:15 PM
KtrainHurricane's Avatar
Quoted: 38 Post(s)
Would I be able to use the wireless adapter (N5HBZ0000055) that came with my ST30 for my Panasonic BDT110 Blu-ray disc player? I know the BDT's wireless adapter will not work for the TV...
KtrainHurricane is offline
post #7449 of 8510 Old 02-21-2012, 04:16 PM
shrimpman's Avatar
BTW, had Fbr upgrade today by Panny using SD card due to how it's mounted. Guy was supervisor and says he's only one authorized to it with card as an FYI. Went well I guess as I never had problem. Logged about 120 hours on slides, tv and game play so think I'm ready for D-nice settings. Life is good, thanks to you all. I still suck at COD, MW3. Hopefully there will be a fix for that soon. Oddly find myself watching this more than pj. Now have to update the Denon for 3d. Does this maddness ever end???????
post #7450 of 8510 Old 02-21-2012, 05:45 PM
kwaidonjin's Avatar
I have been using the break in DVD from the master thread:
http://www.avsforum.com/avs-vb/showthread.php?t=949107
Are these the same images that are on the download for the thumb drive? I am 24hrs into it, Mine flashes through the colors and each one stays on 30 sec. Not sure if it is same as what D-nice has specified.
post #7451 of 8510 Old 02-21-2012, 10:08 PM
kwaidonjin's Avatar
Also, anyone point me in the right direction for 3D glasses, I can find them, I just can't believe how expensive they are. Especially when Samsung sells them for under $50. Thanks
post #7452 of 8510 Old 02-22-2012, 06:09 AM
PDPnNJ's Avatar
Search on Amazon for SainSonic 3D glasses or PS3 3D glasses. Both can be purchased for under $60.
PDPnNJ is offline
post #7453 of 8510 Old 02-22-2012, 06:40 AM
DOC1963's Avatar
The reason the Panasonic glasses are so insanely expensive is due to the fact that no "legitimate" reseller has them. Who you're left dealing with are the bottom dwelling price gougers who are just trying to maximize their profit.
I was lucky enough to get a pair of the "large" 3rd generation Panasonic glasses from Vann's for $79 per pair just a few weeks ago. I bought the only two they had...
The Sainsonic glasses, as suggested, are good candidates, but just be forewarned that they have a range of only 15 feet. Kinda short IMO...
I have a pair of Xpand 103s that compare pretty well with the 2nd generation Panasonic glasses, but are not as good as the 3rd gens.
Good luck...
DOC1963 is offline
post #7454 of 8510 Old 02-22-2012, 06:41 AM
Jimmy's Avatar
Mine works with the 110. The adapter that came with my BDT350 also works with the ST30 and the 110, go figure. I've read that some have had trouble with both. I never tried the ST's adapter with the 350 though.
Jimmy is offline
post #7455 of 8510 Old 02-22-2012, 07:27 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
I haven't been able to get my adapter to work from my 50ST30 in my bdt110.
The 110 needs a proprietary adaptor, and it's pricy.
whipit is offline
post #7456 of 8510 Old 02-22-2012, 09:25 AM
kwaidonjin's Avatar
Good luck...
Do the Expands work with the Panasonics???
post #7457 of 8510 Old 02-22-2012, 09:57 AM
Jimmy's Avatar
You're right, I just tried again and it doesn't work in the 110. I was sure I used the ST adapter to download the updates for the ST and the 110 the day I set them up. The adapter that came with the 350 does work with everything. When I hooked up the 350 adapter to the 110 to see if it would work, it must have downloaded the player update then. I thought for sure it was the other one. Sorry for the bad info.
Jimmy is offline
post #7458 of 8510 Old 02-22-2012, 10:45 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Good to know the 350 adapter will work in the 110, they must have added some protocol that the tv's adapter has.
whipit is offline
post #7459 of 8510 Old 02-22-2012, 10:46 AM
jlin's Avatar
Good luck...
Are you saying that the SainSonic glasses are better than the Xpand 103's?
How's Panny's 3rd generation glasses better than the 2nd generation one (not that it matters since they aren't available to purchase).
jlin is offline
post #7460 of 8510 Old 02-22-2012, 11:06 AM
justpassedu's Avatar
Quoted: 60 Post(s)
From reviews and reading most think the xpand's are better than the sainsonics and also the panny 3rd generation glasses are available to buy , just do a search For Panasonic TY-EW3D3MU , they are proven to be better than the 2nd gen ones , thinner lens , lighter , more light also passes through the lens. I just ordered a pair so if you do a google search you will see they are out there to purchase , just gotta do a little searching , they are all over eBay and many online stores. And read some reviews from real life people like on amazon , you will clearly see the 3rd gen panny glasses surpass the 2nd gen.
justpassedu is offline
post #7461 of 8510 Old 02-22-2012, 11:51 AM
kwaidonjin's Avatar
Who did you buy from???
post #7462 of 8510 Old 02-22-2012, 12:13 PM
kwaidonjin's Avatar
will these work? 3DG-X103 < I have searched, some amazon reviews say these work. I have a hundred dollar gift card from Dell, they have those and 2 more models 3DG-EX103 and X103 XpanD Universal 3D Glasses X6D.
post #7463 of 8510 Old 02-22-2012, 12:17 PM
jlin's Avatar
I got the X103 from Amazon. yes it does work but have no other glasses to compare with for quality.
jlin is offline
post #7464 of 8510 Old 02-22-2012, 12:24 PM
kwaidonjin's Avatar
Thanks for the reply, Dell has the Mitsubishi 3DG-X103 glasses for $65, I wonder if these are the same as the regular X103???
post #7465 of 8510 Old 02-22-2012, 12:51 PM
jlin's Avatar
No idea about the Mitsubishi 3DG-X103 but the Amazon price was changing between $54 and $64 in the last few days. I picked up mine last week for $54.
jlin is offline
post #7466 of 8510 Old 02-22-2012, 01:14 PM
wiremite's Avatar
The Sony PS3 3d Glasses go on sale a lot at $49. I haven't used them but other have reviewed them as working quite well. They are universal.
I guess we need to wait until the Universal 3d Glasses make it big and we get great glasses at $40.
wiremite is offline
post #7467 of 8510 Old 02-22-2012, 01:22 PM
ultraviolet353's Avatar
I bought a 60 inch ST30 from Costco.com
Love the price and the 90 day return policy if it has issues.
Can anyone recommend a good stand for this set? It seems like a lot of stands have glass on the top shelf which concerns me. Anyone know of a good stand (under $300) that does not use glass as the top shelf?
I am so pumped--it should be here in a few days. I know it is bulkier than the 2012 models, but to be honest, I like the look of the 2011 ST30 since it is all black.
ultraviolet353 is offline
post #7468 of 8510 Old 02-22-2012, 01:29 PM
jlin's Avatar
I use the $19.99 coffee table from Ikea as my TV-stand.
Don't laugh. I was prepared to spend $200 on a TV stand but found this coffee table that works just as well.
jlin is offline
post #7469 of 8510 Old 02-22-2012, 02:28 PM
kwaidonjin's Avatar
I am getting the 3DG-X103 XpanD 3D Glasses from dell for $65. They say Mitsubishi but I read on Amazon they work with Panasonic also.
post #7470 of 8510 Old 02-22-2012, 02:49 PM
Dierkdr's Avatar
Liked: 54
Can anyone recommend a good stand for this set? It seems like a lot of stands have glass on the top shelf which concerns me. .....
We've had a tv stand with a raised glass top for a number of years now.
In turn, it has held a 36" Toshiba FST CRT - at something like 150lbs - a Pan 50" plasma, and currently a Pan 60" ST30. (Not counting various pieces of equipment on the lower shelving.)
Don't recall total weight rating of the stand, but the top shelf is rated to hold tvs up to 300lbs (!!) - secret, of course, is to Place the tv on top, as opposed to DROPPING the tv on it!
Dierkdr is offline
Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv
