Official Panasonic 2011 TC-PxxST30 Thread [No Price Talk] - Page 283 - AVS | Home Theater Discussions And Reviews
post #8461 of 8474 Old 01-26-2015, 12:00 PM
Liked: 0
Originally Posted by tribby2001 View Post
After 3 years with no issues with my TC-P42ST30, the display has gone dark and sound has ceased
The display went dark during a short period of use. No sound or picture. Front power LED stays illuminated red.
I unplugged the power cord for about 30 minutes and plugged it back in. When I press the On button on the front panel I can hear a few micro-relays click and the power light turns on red. But still no sound or picture. Also, I can not turn the set off (red power light off) with the remote or the front panel power button (Lock Mode per service manual). I have to unplug the power cord.
When the front red led is on, and I hold down the power button, it will blink 14 times repeatedly.
Any suggestions?
This happened to me as well.
We heard intermittent tones from the Verizon FIOS hardware mounted in the foyer
closet. SHortly thereafter, the pic and sound were lost. The remote (either the Verizon
or Panasonic) will power up the TV but there is no pic or sound. The power
lamp is continuously illuminated. We still have internet access via Verizon's
wireless router as well as Verizon telephone service. All three services enter
the house via the hardware mounted in the foyer closet. The Verizon remote
will cause the channels to change on the converter box as well. The TV is
Panasonic Viera TC-P42S30 and its less than 3.5yrs old.
madvladtv is offline
post #8462 of 8474 Old 02-17-2015, 09:11 PM
Luisfc1972's Avatar
Quoted: 65 Post(s)
i just got a message from the tv when using youtube. it wont be supported anymore after april 20. any way to go around this other than using blu ray player etc.?
Luisfc1972 is offline
post #8463 of 8474 Old 02-18-2015, 04:41 PM
Yardy's Avatar
Got the same message also. I was wondering the same thing too. Sometimes I like to browse youtube without turning on the blu ray player.
Yardy is offline
post #8464 of 8474 Old 02-24-2015, 10:06 PM
upa123's Avatar
Dolby Digital through HDMI?
Good day,
After messing with this for the last few days, I thought I would seek some help. The TV is the P65ST30. I have an AppleTV connecting to the TV to HDMI 2. I get no sound if I enable Dolby Digital on the Apple TV, but if I disable it, the sound is fine.
I figure it's possible the ST30 can not decode DD signal. So I connect a soundbar with HDMI going through the HDMI 1 ARC port on the TV. I figure even if TV can't decode the signal, ARC will simply cause it to bypass to the sound bar. Nope, no sound there again. Sound does work again when I disable DD, so I know at least the ARC connection is good to the sound bar.
What else am I missing here? I went through the manual a few times for both the TV and the sound bar.
Appreciate any suggestions!
upa123 is offline
post #8465 of 8474 Old 02-25-2015, 04:03 AM
whipit's Avatar
Quoted: 49 Post(s)
Liked: 72
These tv's can only output stereo unless you are using an internal app or tuner. Best to use an AVR as your source switch, then you can get all the audio codecs.
whipit is offline
post #8466 of 8474 Old 02-25-2015, 09:42 AM
Augerhandle's Avatar
Quoted: 237 Post(s)
Liked: 158
ARC (Audio Return Channel) is to get the sound from OTA (Over the Air) channels from your TV to your receiver when your antenna is connected to your TV. It's just a convenience, so you don't have to run an additional audio wire back to your receiver for OTA.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_________________________________________________
Augerhandle is offline
post #8467 of 8474 Old 02-26-2015, 11:38 PM
upa123's Avatar
Appreciate the help. I had hoped even if the TV is not able to decode DD signal, it would still pass through the signal from any source. Sounds like that's a misunderstanding from my part.
upa123 is offline
post #8468 of 8474 Old 03-10-2015, 11:19 AM
lowe's Avatar
Liked: 1
Hello to the forum. I have found a lot of helpful info on this site but I am now having an issue with my 55" ST30. I bought it in early 2012 and it has worked great for the past few years. It has a little over 5000 hours and the most up to date firmware. Recently, though, when the background screen is off-white to light grey in color, I get this flickering purple interference. It can happen on a static image or moving scene but it always seems to be visible when the background is a white to grey color. I tried running the wipe bar function overnight as well as the Disney WOW pixel flipper overnight and it's not getting better. Source material doesn't seem to matter either, cable, Blu, Smart apps, etc. They all do the same thing. If I go into the service menu and do the color slides, the colors are OK, but it does it on the lighter grey and white slides. If the picture is not white or light grey based, it looks OK, but there is still detectable flickering.
I can see that there is IR (will post pics once my post count is enough) but I wanted to make sure it wasn't anything else. Any help or guidance is appreciated. Thanks.
lowe is online now
post #8469 of 8474 Old 03-11-2015, 02:06 PM
lowe's Avatar
Liked: 1
Updating with pics. Found my issue in the VT30 thread (dying circuit boards) but figured I would post the pics here anyway in case anyone was interested.
ID:	597385   Click image for larger version
lowe is online now
post #8470 of 8474 Old 03-25-2015, 04:24 AM
bogart219's Avatar
Hello. I have a Panasonic p60st30 that I have had for about three years now. I never updated the software since I had it. Is this something I should do? Is it safe doing it? I'm having an issue with netflix not being able to switch profiles. I'm wondering if updating the software on the Pana would help this? Any thoughts? Thanks!
bogart219 is offline
post #8471 of 8474 Old 03-26-2015, 07:50 AM
lowe's Avatar
Liked: 1
Updating the software is pretty easy. You can do it through the Network submenu if you have the TV on your network. If not, I think you have to do it via a USB flash drive. My 55" ST30 is at firmware 2.20 and all of the apps work fine.
lowe is online now
post #8472 of 8474 Old 03-27-2015, 02:04 AM
bogart219's Avatar
Thanks for the info Lowe!
post #8473 of 8474 Old 03-27-2015, 08:46 AM
spocko's Avatar
Note that the firmware was last updated in 2012, so there hasn't been anything recently, and there probably won't be any more updates.
It's definitely safe to do the update. Don't know if it will solve your Netflix issue, but it can't hurt to try. Here is more info:
http://av.jpn.support.panasonic.com/.../down_na1.html
spocko is offline
post #8474 of 8474 Old 04-12-2015, 10:56 PM
Luisfc1972's Avatar
Quoted: 65 Post(s)
anyone interested in the wifi dongle ill sell for $20.
Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv
