Samsung PNxxD450/PNxxD490 Owners Thread - Page 62 - AVS Forum
post #1831 of 1860 Old 03-26-2013, 10:58 AM
tylerSC's Avatar
Quoted: 113 Post(s)
Liked: 92
Originally Posted by sigmundfreud View Post
Hi guys,
was about to buy an E450 (E455) today but the salesman bombarded me with reasons for why not to buy it as it was so dated. I left the shop empty handed! So what do you think, is it too dated not being full HD and all? Especially since most TV stations are now, or are about to, broadcast in HD. Cheers.
There is now an F4500 being released as the newer model, but in the same basic price range you can now get a 51F5300 that gives you better pic quality in full 1080p resolution. So I would choose the entry level 1080p version.
tylerSC is offline
post #1832 of 1860 Old 05-08-2013, 06:39 PM
bosoxi's Avatar
any more calibration settings for the PN51D450 or has this forum dried up?
bosoxi is offline
post #1833 of 1860 Old 07-12-2013, 07:32 PM
bosoxi's Avatar
anyone have the gamma setting in the service menu to the pn51d450 tv?? is it 0.93??
bosoxi is offline
post #1834 of 1860 Old 07-16-2013, 04:24 PM
nikulogical's Avatar
Anyone have the calibration from this site http://www.televisioninfo.com/content/samsung-pn51d450-plasma-hdtv-review.htm
it was perfect for my set but I had to reset it, now the website has taken down the settings.
nikulogical is offline
post #1835 of 1860 Old 07-18-2013, 10:42 AM
bosoxi's Avatar
has there ever been an update to the pn51d450 firmware T-STD4AUSHC??
bosoxi is offline
post #1836 of 1860 Old 07-18-2013, 05:37 PM
Vic12345's Avatar
Quoted: 12 Post(s)
Liked: 25
I Thought they had a few different firmwares for that one.There is also info on the site that sounds like this one about firmwares.Id be careful with trying them as some people have had problems after installing them.Try a google search
Vic12345 is offline
post #1837 of 1860 Old 07-20-2013, 07:27 AM
bosoxi's Avatar
i saw an updated version for the 43 inch pn43d450 but does that mean its for the 51 inch too?? i didn't want to try it and screw up the tv lol
bosoxi is offline
post #1838 of 1860 Old 07-21-2013, 05:38 AM
Vic12345's Avatar
Quoted: 12 Post(s)
Liked: 25
People were having problems with floating blacks on the pnd450,and trying different firmwares too see if it corrected it.Not sure if theres one that works best for this.
I'm not sure if it would work for the 51..I'm guessing yes but id hate too see you brick or degrade your tv.
Vic12345 is offline
post #1839 of 1860 Old 07-21-2013, 06:06 PM
bosoxi's Avatar
yeah i better not chance it i don't want to break my tv at this point lol
i wish someone on here had the service menu numbers for the pn51d450 though
bosoxi is offline
post #1840 of 1860 Old 07-31-2013, 07:19 PM
whitenoble's Avatar
Hello Everyone,
I've been following this thread for a long time and for me i find it full of information. Thank you to all at AVSForum with all your settings. Now, I want to help someone back. Bosoxi I'll give you what you've been asking for but i prefer another form of contact as this will create a very long post on my behalf. Unless if any Administrator can post a, Yes or give me permission to post it here, I will as well.
whitenoble is offline
post #1841 of 1860 Old 08-02-2013, 08:03 AM
dw83415's Avatar
Hello, first post here and sorry in advance for messing up. I have a pn51d450a2d that buzzes like clockwork with a buzz for 7 seconds and no buzz for 3 seconds and repeats. This is not affected by being turned on or off, channel, picture, volume etc. Also, if I go into my basement to my fuze panel / box, there is a buzzing that is the same as the TV. If I unplug it, it all stops. Any help is greatly appreciated. I searched for this kind of buzz problem but didn't find anything. Also, the houses wiring and fuze/ breaker box is all new.
dw83415 is offline
post #1842 of 1860 Old 09-22-2013, 08:53 PM
anede001's Avatar
Anyone know of a fix for the problems with green accuracy on the PN51D450? Pretty sure it's just a drawback of this budget set, but checking to make sure. Thanks.
anede001 is offline
post #1843 of 1860 Old 09-24-2013, 12:44 AM
Vic12345's Avatar
Quoted: 12 Post(s)
Liked: 25
Whats wrong with the green? You also need it on auto ColorSpace.
Vic12345 is offline
post #1844 of 1860 Old 09-25-2013, 11:43 AM
anede001's Avatar
As Nutdotnet noted in post #666, there is oversaturated green on this panel. The color accuracy on everything else is pretty good. I love this panel, and my picture quality is fantastic, but the green does take on a bit of a neon appearance. I was just curious if there was any workaround in the service menu or something. Most likely it's just an inherent problem in the budget panel.
anede001 is offline
post #1845 of 1860 Old 09-25-2013, 04:20 PM
Vic12345's Avatar
Quoted: 12 Post(s)
Liked: 25
Youve got a combination of too much green and not enough red.Try raising red gain up 10 notches and redbias up 2.Watch tv for a couple days or a while .it will look reddish.If its way too red then red gain up 5,bias up2.that should get you closer...you could leave the red bias where it is too....ps its incredibly hard too get it really good unless you know exactly what too look for.
Vic12345 is offline
post #1846 of 1860 Old 10-15-2013, 10:10 AM
bosoxi's Avatar
are there any hacks for the pn51d450 besides the cinema smooth one??
bosoxi is offline
post #1847 of 1860 Old 11-18-2013, 07:48 AM
Mbuxx's Avatar
I'm looking at buying this tv but have never owned a plasma. I'm worried about stuff burning in, will this be an issue? It's the 450 I'm looking at.
Mbuxx is offline
post #1848 of 1860 Old 11-27-2013, 03:18 PM
bosoxi's Avatar
i had the tv for 2 years and no problem yet with burn in
bosoxi is offline
post #1849 of 1860 Old 11-29-2013, 05:52 AM
Mbuxx's Avatar
Thanks for your reply. I took the chance and picked it up a week it so back. Being nervous about burn in never owning a plasma, if have to say in super impressed. I have a 60 inch led lg and I'm not sure which one I like better now lol.
Mbuxx is offline
post #1850 of 1860 Old 11-29-2013, 05:57 AM
massaqsure's Avatar
you are right,I really need to get a better camera than my blackberry to get some high quality photos for people to really see what they are getting with this TV.thanks
paXMwh
massaqsure is offline
post #1851 of 1860 Old 12-03-2013, 05:20 PM
music_to_my_ear's Avatar
Quoted: 133 Post(s)
Liked: 72
What is the maximum brightness the 43D450 can achieve? I dont have a coloriometer on hand to measure it
music_to_my_ear is offline
post #1852 of 1860 Old 12-06-2013, 04:41 PM
Quoted: 133 Post(s)
Liked: 72
Anyone?
post #1853 of 1860 Old 12-30-2013, 01:41 PM
yayix's Avatar
TV suddenly died yesterday while watching some movie.tried turning it on/off, disconnected all cables including power then turned it on again and it still won't turn on. Red indicator light at the bottom blinks and there's this clicking sound coming from the back. I did searched online for possible causes but I don't want to speculate first before I hear from the experts here or somebody who had the same trouble.. I have the pn43D450A2Dxza bought from best buy early 2011. Hoping to hear from folks here for any help and possibly how-to on how to fix it. It sure is out of warranty for some time now. Love this TV and I don't want to part with it just yet lol.
yayix is offline
post #1854 of 1860 Old 01-01-2014, 06:37 PM
yayix's Avatar
Anybody?
yayix is offline
post #1855 of 1860 Old 01-08-2014, 07:55 PM
bosoxi's Avatar
reset from the service menu???
bosoxi is offline
post #1856 of 1860 Old 01-24-2014, 11:20 AM
bosoxi's Avatar
PN51D450, below are the settings we determined to be ideal:
Setting Default Calibrated
Picture Mode Movie
Cell light 10
Contrast 95
Brightness 58
Sharpness 0
Color 50
Tint G50/R50
Black Tone Low
Dynamic Contrast Off
Flesh tone 0
Edge enhancement Off
Digital Noise FIlter Off
Color Tone Warm2
bosoxi is offline
post #1857 of 1860 Old 01-29-2014, 04:05 PM
pestul's Avatar
Thanks, I'll give your settings a whirl on my PN43D450. This TV is still trucking along quite nicely. I still prefer the picture on this to most of the modern sets I see in stores today despite it being 2 1/2yrs old.
pestul is offline
post #1858 of 1860 Old 01-29-2014, 07:17 PM
yayix's Avatar
Anybody?
Gonna answer my own question..
The problem was as it turned out was the X main board caused by the factory installed FAULTY FIRMWARE. Purchased the repair kit at shopjimmy, downloaded the latest firmware and updated the TV's firmware once the "repaired" X main board was installed.
So this is a heads up to anybody that hasn't upgraded yet to upgrade now or pay for a hefty samsung repair or like me a lower cost (~$80) DIY route!!
yayix is offline
post #1859 of 1860 Old 03-25-2014, 05:13 AM
pestul's Avatar
I know this is a bit late, but is there any newer firmware than the May 11, 2011 v.1006.6 firmware for the PN43D450 North American? Thanks.
pestul is offline
post #1860 of 1860 Old 05-12-2014, 05:31 PM
kesslerbmw's Avatar
Anyone had issues with their HMDI input on this Model?
Came home today, and none of the HDMI inputs work, I tried everything I could find, from resetting it, unplugging it for 10 min, then  plugging the HDMI in, and turning it on... Nothing.
It acknowledges the HDMI's when I plug them in, but it won't connect or display them.
Analog works, and I'm currently using it as such.
Anyone have any ideas? Do I need a new board? If so, should I spent 40-50 on ebay for one, or buy a new one from Shop Jimmy for 90?
I wish I would have found this forum sooner, the info here on setting up the display is awesome. Hopefully I can straighten this TV out.
Thanks in advance!
kesslerbmw is offline
Samsung Pn51d490 51 Inch 720p 600hz 3d Plasma Hdtv Black , Samsung Pn51d490 51 Inch 3d 600hz Plasma Hdtv 3d Kit , Samsung Pn43d490 43 Inch 720p 600hz 3d Plasma Hdtv Black , Samsung Pn43d450 43 Inch 720p 600 Hz Plasma Hdtv Black , Samsung Pn51d450 51 Inch 720p 600 Hz Plasma Hdtv Black
