Official Samsung 2011 PNxxD550 Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
post #1441 of 1922 Old 01-23-2012, 10:38 PM
CTM Audi's Avatar
Quoted: 86 Post(s)
Thanks a lot for that upload, I can officially say brightness pops are now gone. I used my usuall spot in POTC that always did it, and now it doesnt. Also, I "think" the black level might be better, but it might be because Ive been using CinemaSmooth because of the pops, which doesnt have the same darkness level as having it off.
CTM Audi is offline
post #1442 of 1922 Old 01-23-2012, 10:50 PM
elcamino's Avatar
Originally Posted by chambery View Post
Do you have a 3rd option of returning this set for another Samsung of the same model?
Apparently, some buzz more than others. Probably a replacement would not buzz as noticeably.
I was really impressed the place I bought it from let me do just that today, though it's now on back-order.
With that said it sounds like a bit of a crap shoot. In store I did put my ear right up to both a 51" and 64" (they are sold out of the 59") and no buzz whatsoever. I did get a few odd looks however...
To an earlier question reply, the sound from mine was not from the speakers but could be heard emanating directly from the panel. Sort of like a toned down version of the buzzing heard from overheard high voltage lines. The sound was definitely directional as off-axis it was much less noticeable.
Let's hope my next one works out better.
elcamino is offline
post #1443 of 1922 Old 01-24-2012, 02:06 AM
Yoeddy1's Avatar
Thanks for uploading the firmware. Just updated my PN64D550. So far so good!
Jason
Yoeddy1 is offline
post #1444 of 1922 Old 01-24-2012, 04:54 AM
keidow's Avatar
Hi everyone, have been watching this thread with great interest. Does anyone know if the new firmware works for Canadian models? Thanks!
keidow is offline
post #1445 of 1922 Old 01-24-2012, 07:37 AM
jstiene's Avatar
Hello.
I just inherited a Samsung PN51D550C1F with a cracked display, but I did not receive a remote. I know this sounds stupid, but is there a way to turn this on with a remote, as I swear I cannot locate a power button on this model. Also, is there a service manual outh there for this model? I checked scribd,etc with no luck so far...any help is appreciated...
Joe
jstiene is offline
post #1446 of 1922 Old 01-24-2012, 08:35 AM
pdyebrasil's Avatar
Originally Posted by jstiene View Post
Hello.
Joe
The power "button" is capacitive touch. It is located on the bottom left of the bezel on the front of the TV. Just touch the power symbol.
Display - JVC DLA-RS4810 Projector, 106" Da-lite screen
Equipment - Integra DTR-6.8 AVR, Mac Mini HTPC (Win10, Kodi), Xbox One, Apple TV (3rd gen)
Speakers - Tekton Pendragon Towers, Pendragon Center, Pioneer BS-22s, dual Outlaw Audio Ultra-X12 Subs
pdyebrasil is offline
post #1447 of 1922 Old 01-24-2012, 08:38 AM
pdyebrasil's Avatar
Thanks for the firmware King5six1!
I'm happy to report that the upgrade went super smoothly. I just threw the unzipped folder on a FAT32 formatted flash drive, plugged it in, went to update from USB, and it found the file. It performed the optimization. No more POPS to report!
I have a PN59D550. YES!!!
post #1448 of 1922 Old 01-24-2012, 09:12 AM
guest1321's Avatar
Was there a certain point that the pops starting occurring in the lifetime of your panels?
guest1321 is offline
post #1449 of 1922 Old 01-24-2012, 09:16 AM
pdyebrasil's Avatar
I've owned two 59D550s and they both had the brightness pops. They had them straight out of the box. I returned my first one for excessive buzzing. The new one buzzes much less, and I am thinking I will keep it. Since the pops seem to be remedied by a firmware update, it points to a software issue.
post #1450 of 1922 Old 01-24-2012, 01:00 PM
Leech's Avatar
Originally Posted by suibhne View Post
Hi folks - I hate to quote myself, but I still haven't found an answer to this question:
I notice that Samsung's website for the D530 does not list Cinema Smooth as a feature, while it clearly does for the D550. The D530 manual also does not mention Cinema Smooth. However, Samsung's spec sheet for the D530 does list Cinema Smooth as a supported feature. Which is correct?
Can anyone with a D530 confirm whether or not it supports the same 4:4 pulldown as the D550 (which Samsung calls Cinema Smooth)?
(Of course, Amazon and some other retailers also advertise the D530 as sporting Cinema Smooth, but that's not meaningful....)
Cinema Smooth feature is there on D530. I just tested it with models own current firmware. It works really well. D530 "multiversion" e-manual mentions this feature and does not restrict D530 on this.
I dont know why some specs leave the feature out. One source even mentioned that "Cinema Smooth is exclusive to D550 and up". Im a bit late on this thread but happy to report this is not the case.
Bottom line: D530 supports 4:4 pulldown. Tested on 1080p/24 Blu-Ray.
Cheers,
Leo
Leech is offline
post #1451 of 1922 Old 01-24-2012, 03:06 PM
CTM Audi's Avatar
Quoted: 86 Post(s)
All of them prior to 1019.5 have brightness pops, whether people are able to notice them or not. Though if you use CinemaSmooth, or have HDMI level on normal, then it does not do them. Only with CS off and HDMI level on "low".
CTM Audi is offline
post #1452 of 1922 Old 01-24-2012, 03:20 PM
sammy93's Avatar
Originally Posted by King5six1 View Post
You should be able to get it here...
http://www.mediafire.com/file/36qwt7...T-MST4AUSC.zip
I zipped the entire folder. Again this is 1019.5 from what Samsung sent me via usb. After it installed it ran some optimizer on the TV and I have been watching dark knight and haven't seen any pops yet. Hopefully it works for everyone.
Thanks !
Hi, I have the pn51d550. I have done the update for the 1018 version on the web site. I had no problems instaling that. I unzipped the 1019.5 and tried installing that on the usb. It said no updates found. It looks like its the same file # as the 1018 update. Its says update t mst4ausc.
sammy93 is offline
post #1453 of 1922 Old 01-24-2012, 04:04 PM
keidow's Avatar
Thanks King5six1 for the file. I'm in Canada so no telling when we would have gotten it otherwise. I updated, apparently from 1016 and it went through the optimization process and now I'm sitting at 1019.5 on my PN51D550. Haven't spent long enough with it to know if the brightness pops are gone, but I can vouch for the firmware upgrade working in Canada. Hoping for good things!
keidow is offline
post #1454 of 1922 Old 01-24-2012, 04:44 PM
CTM Audi's Avatar
Quoted: 86 Post(s)
Did you extract the files first?
CTM Audi is offline
post #1455 of 1922 Old 01-24-2012, 05:22 PM
ripple420's Avatar
In the root of your USB stick you need the folder T-MST4AUSC from the zip and all the files in it. Just extract the ZIP straight to a USB stick and it should work.
I just updated from 1018 with no problem. My settings were even retained.
ripple420 is offline
post #1456 of 1922 Old 01-24-2012, 05:31 PM
iShiv's Avatar
Quick question...I'm having a hard time selecting cinema smooth when watching TV. It's actually greyed out. I can't even select it.
I'm using AT&T Uverse and have my box set to 1080i.
Is there a reason i'm unable to use Cinema Smooth ?
iShiv is offline
post #1457 of 1922 Old 01-24-2012, 07:01 PM
ripple420's Avatar
Thats only an option when viewing 1080p material
post #1458 of 1922 Old 01-24-2012, 08:10 PM
CTM Audi's Avatar
Quoted: 86 Post(s)
You have to be watching "film" 24FPS material.
CTM Audi is offline
post #1459 of 1922 Old 01-24-2012, 09:06 PM
iShiv's Avatar
Please excuse my illiteracy...but what do you mean I have to be watching film 24FPS material ?
How can I enable that...and is that material specific to certain Cable providers ?
iShiv is offline
post #1460 of 1922 Old 01-24-2012, 09:40 PM
Stormwulf's Avatar
In particular, it's used on Blu-Ray disc films, not broadcast material. Hope that helps.
Stormwulf is offline
post #1461 of 1922 Old 01-24-2012, 09:41 PM
Stormwulf's Avatar
Thanks !
Thanks so much for making this available.
post #1462 of 1922 Old 01-24-2012, 10:11 PM
ZachB10's Avatar
Thanks for posting the 1019.5 .. I just picked up the PN51D550 today after returning a Panasonic 50ST30. I haven't even gone through calibration yet and the colors are amazing and look more natural (especially skin tones) than the Panasonic.
First impressions .. very satisfied so far.
ZachB10 is offline
post #1463 of 1922 Old 01-24-2012, 10:26 PM
darklordjames's Avatar
Liked: 94
What was your primary reason for returning the ST30? I'm trying to decide between the two at the moment.
darklordjames is offline
post #1464 of 1922 Old 01-24-2012, 10:47 PM
kwaidonjin's Avatar
I am waiting for the 64 d550 to hit about $1500.
kwaidonjin is offline
post #1465 of 1922 Old 01-25-2012, 07:45 AM
ZachB10's Avatar
There were mild green hues in some scenes on the Panasonic that drove me crazy (mild, but there), and the flesh tones, no matter what adjustments I made (I used the Disney WOW Blu-Ray to calibrate the set, and I had run slides, etc. for about 24+ hours along with watching some Blu-Rays) made people look like they had sunburn. The Samsung does not have the anti-glare, but I had a Plasma without the anti-glare coat before, and the colors are MUCH more natural on the Samsung. I may have had a bad ST30 panel, but the issues I had don't seem terribly uncommon from reading other reviews. Best Buy did not have any other 50" ST30's so I swapped for the Samsung after seeing people comment on the 1019.5 brightness pop fix. No regrets here.
ZachB10 is offline
post #1466 of 1922 Old 01-25-2012, 08:05 AM
NASCARVW's Avatar
I have a question regarding the way the TV reads the files from the USB port. I have connected my external harddrive to the TV. While trying to play movies from there, it seems it will only find the files that are not located in a file folder.
If I put the movies in a subfolder it just doesn't seem to be able to find them. It says some sort of error message, I can't remember.
But if I take the movie file and put it in the MAIN directory it finds them and plays them with NO PROBLEM.
Also, I was wondering what FILE types this TV will actually play?
I have a SONY cam that uses the AVCHD files, just wondering if this TV could read them? I know the easier answer is TRY IT AND FIND OUT...lol
I'm at work right now, and just thought if someone knew off the top of their head it would be easier.
I've had the 51" Samsung since this weekend, I've experienced no POPs of any sort, and am in LOVE with the picture! (Of course I upgraded from a 4 year old Sony Bravia DLP) so I'm sure that has something to do with it.
Well anyways, thanks for everyone on this FORUM, reading your posts and suggestions helped me pick out a GREAT TV in my price range!
NASCARVW is offline
post #1467 of 1922 Old 01-25-2012, 08:50 AM
ripple420's Avatar
It does not play AVCHD
When you browse the USB are you going into the VIDEOS area of the left-side menu first?
(source->usb->videos)
I noticed if you go into PHOTOS for example, it will not show video files. It filters.
Mine shows content in the root as well as folders. Just navigate to the folder and click on it to enter it.
Perhaps the file format you are trying to see is not supported.
Page 178-182 of this doc shows all the file formats supported.
http://downloadcenter.samsung.com/co...ATSCA-1020.pdf
post #1468 of 1922 Old 01-25-2012, 10:03 AM
ripple420's Avatar
Thank You!
Awesome of you to share this with everyone.
Thanks !
post #1469 of 1922 Old 01-25-2012, 01:14 PM
sammy93's Avatar
Thanks, I downloaded the file to my usb stick. Then I extracted the files and put the usb stick into the tv and it said no updates found. I did it the same way I did it when I did the 1018 firmware update from the web. Its not detecting it. I will play around with it a little more tonight. At least I know its possible since other people have done it that have the 1018 firmware. Thanks again.
sammy93 is offline
post #1470 of 1922 Old 01-25-2012, 05:29 PM
jstiene's Avatar
Hello.
I inherited a Samsung PN51D550 display and when I plug it in, the red led blinks 6 times and then nothing. If i push any of the buttons the red led flashes faintly. Also i notice there is a green LED glowing inside. Any suggestions what the 6 red blinks means as error code? Also, is there a service manual available somewhere?
jstiene is offline
Samsung , Displays , Plasma Hdtv , Samsung Pn51d550 51 Inch 1080p 3d Plasma Hdtv 3d Kit , Samsung Pn59d550 59 Inch 1080p 600hz 3d Plasma Hdtv
