Official Samsung 2011 PNxxD7000 Thread - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #3511 of 4173 Old 01-06-2012, 12:43 PM
ItzMe's Avatar
Quoted: 28 Post(s)
Originally Posted by esfan_adam View Post
I just got a brand new Samsung 64D7000. When hooking it up, I plugged in the optical out cable to the television and heard a snapping noise with a sound to follow which sounded like a piece of plastic falling into the TV. The optical out seems to still work fine but I am quite worried. Should I exchange this TV?
Originally Posted by chikoo View Post
There is protective flap on the optical output. Did u snap that?
I've done that before with other devices. Its easy to break, and I don't think its important at all.
ItzMe is offline
post #3512 of 4173 Old 01-06-2012, 03:56 PM
SteveinDanville's Avatar
It might have been just the snapping into place of the male end into the female piece. You have to push it until it clicks, otherwise it'll just fall out.
SteveinDanville is offline
post #3513 of 4173 Old 01-06-2012, 03:59 PM
My original one was the one with the forklift tongue through the box and into the TV. My replacement was delivered and was on the wall in 10 minutes. No bubbles, no buzz (Aug. '11 build date) and no cracks, so for the time being I'm just doing the gray/black sliding right-to-left deal.
When you guys talk about running pictures on a slideshow, how do you do that? Thanks for the info...happycamperville right now.
post #3514 of 4173 Old 01-06-2012, 05:54 PM
maxwell800xp's Avatar
I am very close to purchasing a pn59d7000. I have done a lot of research to come to this point. Then I found this forum. Great forum. My question to everyone is this. Has anyone seen a deteriation in the blacks or color on these panels or heard of the blacks fading or loss of saturation on colors. What is expected to happen in 5 years. Any thoughts.
maxwell800xp is offline
post #3515 of 4173 Old 01-06-2012, 05:58 PM
When I've got the sliding gray/blacks going, should I be seeing some light vertical banding/false contouring? Because I am. It's getting dark now here so it's starting to show, but in daylight I couldn't see it.
post #3516 of 4173 Old 01-06-2012, 06:05 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 705
Just watch some regular material. You don't have to "break it in ".
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #3517 of 4173 Old 01-06-2012, 06:09 PM
Excellent. Thanks.
post #3518 of 4173 Old 01-06-2012, 06:13 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
False contouring does not occur on a screen showing one color. What you probably are seeing is a slight condition of not perfect screen uniformity. It will fade a bit with time. You probably will not see it under viewing of normal content.
Larry
LarryInRI is offline
post #3519 of 4173 Old 01-06-2012, 09:40 PM
dzack02's Avatar
Excellent. Thanks.
Just ESPN and they're **** bottomline... ugh!!
dzack02 is offline
post #3520 of 4173 Old 01-07-2012, 07:02 AM
pekkle's Avatar
I'm not sure how everyone else does it, but I downloaded the images from this post to a USB flash drive and plugged the drive into the TV. Then I went to Smart Hub -> Photos and pressed play.
pekkle is offline
post #3521 of 4173 Old 01-07-2012, 09:51 AM
Jruc03's Avatar
Quoted: 13 Post(s)
Exactly how I did it as well. I'm still running the slides every now and then overnight. I saw some slight IR from playing uncharted 3 on my PS3. Probably should have waited a little while longer before heading into gaming.
Its not even really visible so I don't want to scare anyone I can only see it if the entire screen is white and even then I have to move my head at different angles to faintly see it. I ran the slides overnight and now Its gone. The TV is only a week old btw probably only have about 100 hours on it.
Jruc03 is offline
post #3522 of 4173 Old 01-07-2012, 07:19 PM
JMUdukes07's Avatar
I haven't seen it mentioned much on any of the last 5-10+ pages . . .
Can anyone tell me if Samsung released any firmware updates or anything that fixed the fluctuating brightness issues that were plaguing these sets when I was researching a few months ago?
I'm thinking about getting one of the 51D7000's soon and was hoping this issue would have been fixed by now.
Thanks for any replies!
JMUdukes07 is offline
post #3523 of 4173 Old 01-07-2012, 09:57 PM
Flash311's Avatar
Not yet and prob not in the foreseeable future unfortunately.
Flash311 is offline
post #3524 of 4173 Old 01-08-2012, 02:54 AM
oqvist's Avatar
Have you seen the plasma on yourself? I have the D7005 and I can´t for my life understand why it´s supposed to be such an issue. But maybe they solved it for the european model?
oqvist is offline
post #3525 of 4173 Old 01-08-2012, 09:14 AM
Vanla's Avatar
Larry:
What is your verdict on the samsung d7000 series as it has been roughly a year of ownership. I am just curious to know.
Others are also free to chime in.
Honestly this is my first plasma set.
Vanla is offline
post #3526 of 4173 Old 01-08-2012, 12:03 PM
JMUdukes07's Avatar
I haven't seen the model myself (other than in the store) but I'd really like to purchase it considering how amazing everyone says the picture is.
However, since I watch a lot of hockey and movies the fluctuating brightness would absolutely be a deal breaker for me. That's why I'm leaning towards the GT30 although this set would be my clear-cut #1 choice if it weren't for the fluctuating brightness.
post #3527 of 4173 Old 01-08-2012, 12:22 PM
Joseph Clark's Avatar
Quoted: 272 Post(s)
Liked: 319
I saw an intermittent white "flash" during bright scenes with my new D7000 last night. At first I thought it was a loss of sync, but it didn't look at all like sync loss on my C8000 (which was replaced by Best Buy with the D7000 in a warranty swap because of a screen problem). It's not a big flash, but it's definitely distracting. Is this what you guys are talking about, and is it on every D7000 out there?
Joe Clark
Joseph Clark is offline
post #3528 of 4173 Old 01-08-2012, 12:32 PM
oqvist's Avatar
I have played a lot of NHL 12 and watched a lot of hockey on it and my display don´t suffer from this. SD TV but has never been able to see the FBR watching hockey. NHL 12 is really sharp and also don´t suffer from FBR. But then the white levels is kind of constant here so that is not so strange perhaps.
I have been able to see the effect by watching some arctic documentary but there is no flicker just a modest switch that is hardly a dealbreaker by any means and only occasional.
But well most complaints around these has been from PND owners not the european PS versions.
oqvist is offline
post #3529 of 4173 Old 01-08-2012, 03:35 PM
chikoo's Avatar
is there a YouTube video showing this fbr issue?
chikoo is offline
post #3530 of 4173 Old 01-08-2012, 04:05 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 705
Firmware 1014.6 on its way via USB stick. Supposedly fixes the pops. Guess I'll have to wait and see.
I'm on 1015 now. Seems strange to go backwards for fix I've not heard of 1014.6.
Rivers Edge Theater
post #3531 of 4173 Old 01-08-2012, 04:16 PM
alexmanny01's Avatar
Is this upstate via USB confirmed?
alexmanny01 is offline
post #3532 of 4173 Old 01-08-2012, 04:18 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 705
Nope. No one has received it yet.
Rivers Edge Theater
post #3533 of 4173 Old 01-08-2012, 04:35 PM
muffinmcfluffin's Avatar
Quoted: 223 Post(s)
Liked: 130
Do you mean you have to have it sent to you, or you can download it once it arrives online?
Living Room: Samsung PN60F8500 PDP / Anthem MRX 720 / Klipsch RC-62 II / Klipsch RF-82 II (x2) / SVS PC13-Ultra / Sony MDR-7506 Professional / Sony PS3 / DirecTV HR44-500 / DarbeeVision DVP-5000 Darblet / Panamax M5400-PM / miniDSP UMIK‑1 USB
Bedroom: Samsung PN59D7000 PDP / Energy Power Bar Elite Soundbar & SW / Astro A50 / Sony PS4 / DirecTV C41W-500 / DarbeeVision DVP-5000 Darblet / Hauppauge HD PVR 2
Classroom: SMART Board X800 / Yamaha RX-V667 / Insignia NS-B2111 (x2) / SVS SB-2000
muffinmcfluffin is offline
post #3534 of 4173 Old 01-08-2012, 04:43 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 705
Myself and a few others are having it mailed to us. Not available through download.
Rivers Edge Theater
post #3535 of 4173 Old 01-08-2012, 07:18 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
I had 1014.5 installed for a few months and there was no visible difference from 1013. I now have 1015.0 and still see no visible difference. I have not yet put a meter on the TV to confirm what I see.
I suspect that the latest updates do nothing more than add more stupid apps and needless streaming connections. It's too bad that the emphasis is there and not improving display performance.
Larry
post #3536 of 4173 Old 01-09-2012, 08:39 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1052
Originally Posted by Turrican4D View Post
Hallo to all of you Samsung PDP owners.
I just wondered myself, if it would be possible to tweak the Samsung D7000 and D8000 models with altering pot positions in a way, as it is possible with the LG pdps?
Has anyone of you openend the case of your set yet?
I know, that Panasonic doen't have any pots in its sets anymore (all the voltages are chipcontrolled), so I don't know, what the state of Samsung is.
Any information could be helpful.
I am looking into this on my D8000, there are two trimpots on the PS board (I think VS and VA) and there are also two on the Y-Scan board labeled Yrr and Yscan. A service tech replaced my PS board a month ago while troubleshooting another problem (main board) and did not adjust voltages to the label setting so I want to check first if those are where they need to be. After that I'll see if there is an headroom for mll adjustments since my panel size (51") has a higher baseline mll than the larger panels I'd like to see if there is any margin for lowering it.
zoyd is offline
post #3537 of 4173 Old 01-09-2012, 08:51 AM
Jruc03's Avatar
Quoted: 13 Post(s)
Originally Posted by Vanla View Post
Larry:
Vanla did you ever recieve your firmware via usb from Samsung?
What steps did you take to get them to send it to you? I went through live chat and they were of no use
Jruc03 is offline
post #3538 of 4173 Old 01-09-2012, 09:30 AM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
Wow, this firmware stuff is very odd - they're sending out 1014.6 when 1015 is already installed on some sets?
My 59D7000 has a new bug - it turns itself on randomly. I think it did this once around Thanksgiving, but for the last few days it will only remain off for an hour or less before powering up. Just an irritation really, but it surely needs to get fixed. Still running 1013.1.
AvidHiker is offline
post #3539 of 4173 Old 01-09-2012, 01:38 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 705
I did it through Live Chat. I told them I had fluctuating brightness issues and that there is a firmware being mailed to others to fix it. I didn't get any push back and I actually talked to two different people. Didn't have my serial # the first time to register it.
Rivers Edge Theater
post #3540 of 4173 Old 01-09-2012, 03:33 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 705
Cnet's CES coverage mentions a fix for the pops in the 2012 Sammy plasma article
http://ces.cnet.com/8301-33379_1-573...ol%3bcnetRiver
Rivers Edge Theater
Samsung Bd D7000 3d Blu Ray Disc Player Silver , Samsung Pn51d7000 51 Inch 1080p 600hz 3d Plasma Hdtv With Pn51d7000 Bdd5500 3d Blu Ray Player 2 Ssg
