Official Samsung 2011 PNxxD7000 Thread - Page 138 - AVS | Home Theater Discussions And Reviews
post #4111 of 4137 Old 01-23-2013, 04:21 PM
LarryInRI's Avatar
Liked: 168
I agree with Willie. Samsung usually will replace the panel without any hassle. On the other hand, the replacement panel may not be much better. You may end up with screen non-uniformity in different areas. So check the new replacement screen carefully before signing off on it.
A third party warranty probably is useless with this sort of condition. They will say it is considered a viewing quality issue and is not covered.
In any case never mention viewing habits when submitting a claim.
Larry
LarryInRI is offline
post #4112 of 4137 Old 02-09-2013, 02:10 PM
bajanjack's Avatar
I just replaced my directv HR24-500 dvr with the "genie"- HR34-700. The 3D worked fine with the HR24, but won't work with the HR34. Same exact cables for the dvr swap. I'm assuming the problem resides with the dvr, but any known issues with my PN 64D7000?
bajanjack is offline
post #4113 of 4137 Old 07-09-2013, 05:47 AM
ColdFyre22's Avatar
Has anyone noticed cracking forming inside the plastic trim around their PN64? I've owned this set since 2011 and its just started happening now. Ill take some pictures when I get home later, but its INSIDE the plastic frame. You can run your nail across the front and back and not feel the crack, it seems to be inside the plastic. On my set its in the trim at the lower right of the TV, and is affecting about a 4" section of the plastic trim. It was 3" but this morning when I looked it seems to have grown. Is this a known issue that Samsung is aware of. I was thinking of calling Samsung but since the TV is out of warranty I'm not sure they'd even do anything about it.
ColdFyre22 is offline
post #4114 of 4137 Old 09-23-2013, 06:15 PM
BlueHurricane's Avatar
Xfinity just installed their new X1 system in my house and the box that is hooked to my Sammy 7000 will allow me to select output resolution. Should I output 1080p/30 or 1080p/60?
BlueHurricane is offline
post #4115 of 4137 Old 12-03-2013, 03:29 PM
nikerret's Avatar
Originally Posted by LarryInRI View Post
You check the hours on the panel by pressing mute>7>3>7>enter. The time is shown in the MRT item. Exit by turning off the TV.
Larry
Thanks!! Mine was bought October 23, 2011. I utilized break-in slides for most of the first 100 hours, probably 70, or so. Now, it has 3442 hours. Just throwing that out there!
nikerret is offline
post #4116 of 4137 Old 02-10-2014, 01:52 PM
Jason Walstrom's Avatar
Hey guys, maybe you can help me with something that I have noticed very recently. I have owned the 64D7000 for about two years, I bought a 3 year warranty from BB as I knew this was my first ever Plasma and I didn't know what to expect. I have thoroughly enjoyed this tv and the pq that you get from Plasma. Like most owner's of this set, I have had to deal with fbr, which I also promptly did the fix, I still see it from time to time and I have learned to live with it. I mostly watch television shows with the light on and watch blu rays with the lights off. I can live with the fbr that I still see, It doesn't bother me anymore, it is so subtle now it's not worth getting worked up about BUT most recently as December I have started to noticed vertical lines during panning shows, the lines are very very faint, very subtle, I see them mostly on the right side of the screen, mostly with grayish backgrounds, thank god I do not see them during Hockey. At first I thought i was just seeing things, I thought maybe it was the source but I see the lines all the time now, with directv, ps3 and xbox one. The most i have done that might have done anything to effect the set was to hook up the new Xbox One but I'm not sure that is related. I have included a picture here of what I believe is is uniformity.
Now here is the question, should I learn to live with this like fbr or should I try to get it serviced? Now I have been through the whole service thing before with my JVC Lcos and I know that you have to have the patience of Job when dealing with this stuff. What should I do? Toss the dice and see what BB can do for me or just try to be happy for a few more years until something better comes along?
Entertainment Landfill The Weekly Podcast Commentary of Film, Television and Pop Culture iTunes
XBL GT: The Jastrom
Jason Walstrom is offline
post #4117 of 4137 Old 02-10-2014, 03:27 PM
Monnone's Avatar
Ironic. I've seen these lines too recently. Also the only thing I've done different is hook up a new Onkyo Receiver and an Xbox One (if that matters at all).
I haven't disconnected things to see it that is causing some sort of interference...I may try now though.
B
Monnone is offline
post #4118 of 4137 Old 02-12-2014, 10:45 AM
jcalabria's Avatar
Quoted: 40 Post(s)
Liked: 52
No lines on my 51D7000, but the fluttering pink blotches (like pink clouds or cotton candy) are getting worse.  You can see them in most large open light areas (open sky, hockey rink, etc.)  The Olympics are really bringing them out.  Hours (MRT) are currently at 9864 at exactly two years since purchase.  Damned shame because TV still looks gorgeous otherwise... in fact, most people don't even notice the blotches unless I point them out or its a very obvious situation (not usually in typical programming).
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.3.1_6
jcalabria is offline
post #4119 of 4137 Old 02-14-2014, 05:53 AM
Rob67's Avatar
Liked: 26
I am assuming yours is calibrated and this isn't the pink effect caused by the contrast being set to high? I have a 57D7000 but am unsure of the hours. I will have to check. I haven't seen that effect yet.
Rob67 is offline
post #4120 of 4137 Old 02-14-2014, 08:51 AM
jcalabria's Avatar
Quoted: 40 Post(s)
Liked: 52
Yeah... Calibrated and definitely not anything like a primary clipping. In fact, no adjustment makes any difference at all.
post #4121 of 4137 Old 02-15-2014, 07:13 AM
guest68's Avatar
Have just seen where the 59" unit is still available for around 1100.
Considering the age of 7000 and comparing the newer units of this size, is it a good value? From what I've gathered, it seems to be a panel that is similar to the present 8500 series, yet is priced right now, at the 5500 series,
guest68 is offline
post #4122 of 4137 Old 02-15-2014, 09:33 AM
Rob67's Avatar
Liked: 26
I think it is one of the best sets I have owned. I would say, unless you can find one of the few remaining Panasonic plasmas from last year, this is a great deal.
Rob67 is offline
post #4123 of 4137 Old 02-16-2014, 10:27 AM
mobilelawyer's Avatar
It is a fine set.
mobilelawyer
at your service
mobilelawyer is offline
post #4124 of 4137 Old 08-29-2014, 05:06 PM
muffinmcfluffin's Avatar
Quoted: 77 Post(s)
Liked: 76
How are the black levels for ya'll now on these sets?
Mine has over 6,000 hours on it, and last night was the first time I thought something was seriously screwed up with the blacks. Not that they were ever great to begin with, but they had a legitimate gray look to them, and it wasn't even close. I played TASM2 on it, and I thought it was a PS4 settings issue. I can't seem to locate what that issue would be though, so I'm chalking it up to my blacks finally rising, and badly.
Anybody else getting this?
muffinmcfluffin is online now
post #4125 of 4137 Old 08-30-2014, 10:33 AM
Quoted: 77 Post(s)
Liked: 76
Nevermind, turns out it must be a combination of the PS4 and my TV and their settings. When I disable 1080p/24Hz it seems to look as it normally does. Problem is though, now I'm watching in 60Hz and I don't much prefer that.
I wonder what's going on here, or if anybody else also has the same issues. Keep in mind there is still the issue when I turn off CS with that 1080p/24Hz option enabled, so I think there's something else going on with the PS4 that's making this happen.
post #4126 of 4137 Old 09-01-2014, 01:14 PM
Parrot_HD's Avatar
I went power on my 51d7000 this morning, the Samsung Smart TV displayed, then displayed the input, then powers off and starts all over again at the Smart TV logo.
I did some searching and read about the weak capacitors (I don't think this applies to my TV), then read it could be the power module board or the main control board.
Any thoughts or anyone have this happen.
I'll kill a man in a fair fight. Or if I think he's gonna start a fair fight. Or if he bothers me. Or if there's a woman. Or if I'm gettin' paid. Mostly when I'm gettin' paid - Jayne
Parrot_HD is offline
post #4127 of 4137 Old 09-01-2014, 06:27 PM
zoyd's Avatar
Quoted: 743 Post(s)
Liked: 642
zoyd is online now
post #4128 of 4137 Old 10-22-2014, 11:27 AM
manhatton's Avatar
Quoted: 16 Post(s)
I also have the pink pixel blotching. Is there any recourse now being out of warranty?
manhatton is online now
post #4129 of 4137 Old 10-22-2014, 11:59 AM
jcalabria's Avatar
Quoted: 40 Post(s)
Liked: 52
Don't know of any recourse with Samsung. I had previously found some info tying the issue to drifting voltages that can be adjusted to correct the issue. I don't have the details handy at the moment. I'm more than capable of checking this out but have been too busy/too lazy to dismount the TV to check it out further. As I mentioned in my earlier post, it's rarely noticeable in typical programming and those times it is it is usually very fleeting. I see it mainly when I bring the HTPC desktop up and open an explorer window... if the window exceeds approximately half of the screen the window background will have it very noticeably.
post #4130 of 4137 Old 10-22-2014, 12:10 PM
zoyd's Avatar
Quoted: 743 Post(s)
Liked: 642
If what you are seeing are blotchy magenta areas on white backgrounds then this is due to the reset pulse width being too short causing misfires of the green sub-pixel. I would guess this could happen as the phosphors age and become less efficient. On the 51" you should be able to adjust the Yrr resistor counter-clockwise to fix this but it will also raise your black level slightly. See this thread for more info.
jcalabria likes this.
zoyd is online now
post #4131 of 4137 Old 10-22-2014, 12:45 PM
manhatton's Avatar
Quoted: 16 Post(s)
It is exactly that. I suppose I'm not thrilled about losing black level, but I'm sure my eyes would adjust to that overtime. I certainly cannot adjust to intermittent flashes of a color not intended to be viewed.
Thanks for the in depth walk-through, I'll be looking to attempt this soon.
post #4132 of 4137 Old 10-22-2014, 01:32 PM
HomeTheatreMaven's Avatar
My 64 still looks beautiful but I have 3 problems:
1 Wireless connection won't connect - other devices have no problem
2 Wired connection won't connect - other devices with same wired connection have no problem
3 Can't install firmware upgrade - followed instruction and it says no file to update, even though it's there and the USB drive and folders are recognized
I've tried unplugging set and that doesn't help.
I could do a factory reset I guess (EXIT button for 10 seconds?) but I lose all my custom picture settings.
Any ideas? Thanks.
HomeTheatreMaven is offline
post #4133 of 4137 Old 10-25-2014, 01:47 AM
Vic12345's Avatar
Quoted: 44 Post(s)
Liked: 27
Adjusting Voltages too sticker values,using cool tone in regular menu and adjusting white balance in service menu and reducing red gain down too mid 80s in service menu got rid of most of the pink coloring on full bright screens on mine,and reduced some pink coloring in clouds and when the camera moves on mine.The problem is the pink cloud problem seems like its gotten worse with time and I don't have a yrr adjustment on mine. I was pretty much forced too do these adjustments as I'm not sure Samsung would of acknowledged them as problems.
E450
Vic12345 is offline
post #4134 of 4137 Old 11-19-2014, 02:38 PM
manhatton's Avatar
Quoted: 16 Post(s)
Samsung tech just left. He reports (as has been anecdotally) voltage adjustments are very temporary. Quoted ~$1,400 to replace panel and power supply.
Yikes.
He does, however, recommend making three attempts with customer service to see what they are willing to do. Depending on how that goes, I may be canceling/returning my F8500 order.
post #4135 of 4137 Old 11-20-2014, 06:50 AM
manhatton's Avatar
Quoted: 16 Post(s)
Looks like I'm keeping my order....
Samsung was willing to cover parts ($1,178), and I'll cover labor ($269) of which the $110 I paid for the service call is applied. Although not thrilled to dish out $159, that's short money for a mostly new set. I am quite impressed and consider myself lucky that they're willing to cover this much given the many stories of less fortunate results.
post #4136 of 4137 Old 11-20-2014, 07:29 AM
zoyd's Avatar
Quoted: 743 Post(s)
Liked: 642
That's a good deal and it will give you a new panel that should last a long time. I don't agree with the tech about the temporary comment though, this particular voltage adjustment would cure the problem for a very long time (years) but you'd give up some black level to do it.
zoyd is online now
post #4137 of 4137 Old 02-15-2015, 06:19 PM
sirbrillo's Avatar
My Unit stopped working (T.V. won't turn on and I see no picture) for the 2nd time since purchasing.
I have had this TV since late 2011 and very much enjoyed the picture. I have my unit mounted to the wall with a fairly flush mount and I about a year and half ago the T.V. stopped working and I had to have the unit repaired due to overheating. after the repair I mounted the TV with a good 2 inch gap in the back and went about enjoying the T.V. again.
Now I'm back to a dead T.V. and really confused. We don't even watch the T.V. all that much and its died twice. Going to have a service technician look at the T.V tomorrow.
Any advice? Do these units have heat issues? Is this a common problem? Any suggestions on how to reset the T.V.?
Vizio M602i-B3
Onkyo 706 THX Reciever
Sony PS3
Paradigm Monitor Series Speakers
M&K THX Subwoofer
sirbrillo is offline
Samsung Bd D7000 3d Blu Ray Disc Player Silver , Samsung Pn51d7000 51 Inch 1080p 600hz 3d Plasma Hdtv With Pn51d7000 Bdd5500 3d Blu Ray Player 2 Ssg
