Official Samsung PNxxD6500 Calibration thread. - AVS Forum | Home Theater Discussions And Reviews
Old 03-25-2011, 05:18 PM - Thread Starter
TheBrandon's Avatar
Quoted: 36 Post(s)
Not sure if we will be so lucky as to have D-Nice or Chad drop us a starting reference however this is what I have so far for my 2D settings,
PN59D6500, going for a more natural image.
Cell Light 20
Contrast 68
Brightness 48
Sharpness up to you
Color 45
Tint G/R G52-R48
HDMI Low. Gamma I believe I have set to +1.
Some very good depth to this image.
Here are the settings I am currently using after trying pretty much everything out there.
Give these a shot if you haven't (credit to Varkeast),
Mode Movie
Peak White 35ftL
Cell Light 15
Contrast 94
Brightness 65
Sharpness 10
Color 48
Tint 50/50
Black Tone off
Dynamic off
gamma -1
RGB Only off
Flesh Tone off
Edge Enhance off
Motion Light off
xvYcc off
Color Tone warm2
Digital Noise off
mpeg Noise off
Color Space
Red_r 78
Red_g 75
Red_b 50
Green_r 100
Green_g 16
Green_b 0
Blue_r 18
Blue_g 22
Blue_b 37
Yellow_r 14
Yellow_g 29
Yellow_b 43
Cyan_r 100
Cyan_g 48
Cyan_b 36
Magenta_r 37
Magenta_g 100
Magenta_b 49
White Balance
r-offset 24
g-offset 22
b-offset 26
r-gain 21
g-gain 26
b-gain 28
10-point
r1 0
g1 1
b1 -1
r2 3
g2 2
b2 -1
r3 4
g3 3
b3 -1
r4 3
g4 3
b4 0
r5 3
g5 3
b5 1
r6 4
g6 4
b6 0
r7 3
g7 3
b7 1
r8 1
g8 3
b8 -1
r9 -2
g9 -2
b9 -6
r10 -3
g10 -2
b10 -3
TheBrandon is online now
Old 03-31-2011, 11:48 PM
MDjavaherian's Avatar
Is there any reason why this thread hasn't received any additional comments? I'm sure plenty of people are calibrating their D6500's.
MDjavaherian is offline
Old 04-01-2011, 05:25 AM - Thread Starter
TheBrandon's Avatar
Quoted: 36 Post(s)
How did the settings work for you? I tried 60 on color left 50/50 on Tint and dialed in the advance by pushing Blue to max. Sean202 gave me his colors and they worked well so I added them in the original post since these are easier to start with.
Old 04-01-2011, 06:51 AM
Thanks. I really don't have a good eye yet, but I tried your original settings and they seemed nice. Maybe a little dim?
Thanks again.
Old 04-01-2011, 08:03 AM
catspit30's Avatar
is the PNxxC6500 the same as this without the 3d?
catspit30 is offline
Old 04-01-2011, 09:31 AM
taiteng's Avatar
I wonder why I can't change my HDMI setting. It is shaded out set on normal.
taiteng is offline
Old 04-01-2011, 01:20 PM
The same as what? I don't understand the question.
Old 04-01-2011, 06:33 PM - Thread Starter
TheBrandon's Avatar
Quoted: 36 Post(s)
Thanks again.
If you are used to LED\\LCD these would probably appear dim.
This depends on source. I imagine you are on your cable box?
Old 04-28-2011, 12:18 PM
chilecayenne's Avatar
Hello,
Just found this thread. I just got the pn59d6500.
Anyone got some calibration numbers for this particular model they like?
What would you run for break in vs after break in?
Thanks in advance,
chilecayenne
chilecayenne is offline
Old 04-28-2011, 01:11 PM
andrewbaddeley's Avatar
Hi all, can anyone confirm on an improvement in PQ on the D6500 vs the D550 (59/64"). Not bothered with internet on tv but will spend extra if there truly is an image processing improvement. Thanks.
andrewbaddeley is offline
Old 04-28-2011, 02:10 PM - Thread Starter
TheBrandon's Avatar
Quoted: 36 Post(s)
Originally Posted by chilecayenne View Post
Hello,
Thanks in advance,
chilecayenne
I have been anxious to see calibration numbers as well. Bummer CNET already reviewed the Panasonic GT30 but hasn't touched Samsungs Plasma models. For break in you could follow DNICE slides he has out for the Kuro. For settings I am not sure, I didn't break mine in however I notice the picture has gotten visibly better once settling.
I do not think you would ever notice a difference if you were looking side by side. I do not think you can deny there are less reflections on the 6500 and that to me is worth the extra in addition to the fact that with the 6500 you can get 5 movies and 2 glasses.
Old 04-28-2011, 02:17 PM
Thanks for the reply.
Ok..I watched a stones concert dvd right off after getting it. I've got the break in slides running now, will try to do for most of afternoon..but willl want to watch some movies tonight with the new 'toy'.
I just set it to the factory default for movie. Settings are kinda high for that tho?
Looked like contrast was 95
Cell 18
Brightness 55
Sharpness 20
Color 50
Tint G50 R50
I set gamma to +1 just to see if a difference.
I'm guessing this can't hurt for break in....hoping for movies with no bars, etc...should be ok?
Man..is there a site out there that explains what all these settings do and how they interact? I looked into the advanced menu and WOW....tons of choices, all of which I have NO idea what they do.
Old 04-28-2011, 02:34 PM
matz8916's Avatar
the D550 is much more reflective.
matz8916 is offline
Old 04-28-2011, 02:57 PM
SRrobin981's Avatar
The D550 is a mirror and suited for bat caves only *at least if you are as sensitive to reflections as I am. D7000 is way better for that, but I am still thinking of replacing my two sets of white blinds in our family room. And then there's that fairly glossy white ceiling.
SRrobin981 is offline
Old 04-28-2011, 03:19 PM
banditws6's Avatar
TheBrandon, did you get a replacement D6500 after returning your first one, or did you get a different model?
I tend to see folks setting their brightness around 40-50 with gamma +1. I have gamma on my D6500 set at 0, a and brightness can't go below 60-62 without losing shadow detail. I wonder if it's better to set gamma +1 and decrease the brightness a bit. Will try that out. Otherwise, my settings are pretty similar to yours in the original post, as a result of my own eyeballing and testing with the AVS 709 disc.
banditws6 is offline
Old 04-30-2011, 08:49 PM
Wiggin028's Avatar
Just ordered my first plasma! Thanks for the information about the D-Nice slides for the Kuro. I've got them and the instructions on how to run them, but I was wondering if anyone can share settings for the break-in process?
Wiggin028 is offline
Old 04-30-2011, 09:03 PM
Vcolassi's Avatar
I too am a fan of the +1 gamma. I have been testing out brightness levels between 45-53ish. The +1 gamma keeps the blacks black and brings out the shadow level great. At least on my 59" 6500.
Vcolassi is offline
Old 06-01-2011, 05:48 AM
mstrength's Avatar
Bump...
I will be picking this TV up next week in the 59". How long do you guys recommend running the sets on "xxxx" mode before calibrating them to your liking?
mstrength is offline
Old 06-02-2011, 04:34 AM
BurtReynolds's Avatar
^^^I think I've consistently seen about 100 hours mentioned on here before guys recommend having it professionally calibrated. As long as you don't do anything extreme, I don't think calibrating it earlier does any "harm". You might just have to tweak it again as the panel gets broken in, hence why it isn't worth paying someone to do it until your panel is "ready".
Slightly off-topic, but this is the closest thing we have to a 6500 plasma thread.
Is anyone still having issues with the firmware? I put it off since everyone had to do the "code" to get their TVs to work again, and I just remembered it is out there. Did Samsung ever update it to make the upgrade go smoothly?
I think I've finally run my 6500 long enough to try some of the settings from here and the 7000 thread, but I should probably take care of the firmware before I go through changing things just to have it get reset.
BurtReynolds is offline
Old 06-13-2011, 11:43 AM
Micker's Avatar
Just got the 59d6500 the other day. Haven't had time to set it up yet, but can't wait!! Anyone have some calibrated settings that look really good?? How do the settings from the d7000/8000 look on the 6500?? This is my first plasma, going from a 52a650 lcd.
Micker is offline
Old 06-13-2011, 12:39 PM
kheovnien's Avatar
Micker,
I should be getting my 59D6500 this week. moving the 46A750 into the bedroom. is the LCD more reflective, less reflective, or the same as the plasma? also, how are the blacks (in comparison)?
kheovnien is offline
Old 06-13-2011, 02:16 PM
Micker's Avatar
I'll let you know, setting it up tonight and will calibrate it a bit. Gonna see if plasma is really as good as they say.... Hope its a nice picture upgrade over my a650, which is a very good lcd. I usually only watch that tv at night with no lights on, so should be ideal for plasma.
Micker is offline
Old 06-13-2011, 05:57 PM
obveron's Avatar
Quoted: 17 Post(s)
So the D6500 has a glare filter the D550 doesn't have? I thought you had to to go up to the D7000 before you got the real black filter?
obveron is offline
Old 06-13-2011, 07:41 PM
kheovnien's Avatar
supposedly the D6500 has an anti-reflective coating/filter but no real black filter. The real black filter is to preserve contrast (blacks) in off-axis lighting (i.e. ceiling lights) not prevent glare, that's there too just not part of the RBF.
Old 06-30-2011, 11:29 AM
mstrength's Avatar
bump... Post of some settings folks. Is everyone using the D7000 and 8000 settings?
Old 06-30-2011, 05:19 PM - Thread Starter
TheBrandon's Avatar
Quoted: 36 Post(s)
I am using Cues settings. These work fantastically for my set. No black crush and the colors look great. Comparing to my calibrated Kuro.
Old 07-01-2011, 05:55 AM
mstrength's Avatar
Do you have a link where those are located? Search is not being my friend this morning.
Old 07-01-2011, 06:18 AM - Thread Starter
TheBrandon's Avatar
Quoted: 36 Post(s)
Taken from TivoHD Thread for D7000 and D8000 Procalibration.
TiVoHD zoyd cue03 LarryInRI
64D8000 51D8000 64D8000 64D7000
Mode Movie Movie Movie Movie
Peak White 30ftL 27.8ftL
Cell Light 20 15 20 15
Contrast 96 80 95 80
Brightness 54 54 53 66
Sharpness 0 0 5 0
Color 50 50 50 44
Tint 50/50 50/50 50/50 48/52
Black Tone off off off
Dynamic off off off
gamma -1 -1 -1 0
RGB Only off
Flesh Tone 0 0 0
Edge Enhance off off off
Motion Light off off off
xvYcc off off off
Color Tone warm2 warm2 warm2
Digital Noise off off off
mpeg Noise off off off
Color Space
Red_r 48 39 43 36
Red_g 6 6 6 50
Red_b 6 5 5 50
Green_r 20 20 14 60
Green_g 54 50 50 50
Green_b 3 6 1 20
Blue_r 3 1 3 40
Blue_g 3 3 0 20
Blue_b 50 41 47 50
Yellow_r 53 51 48 50
Yellow_g 53 51 50 50
Yellow_b 6 7 5 2
Cyan_r 17 18 15 20
Cyan_g 52 48 49 46
Cyan_b 52 48 51 46
Magenta_r 47 41 44 40
Magenta_g 8 6 6 3
Magenta_b 57 48 48 47
White Balance
r-offset 26 22 25 28
g-offset 25 26 25 22
b-offset 22 25 25 22
r-gain 13 30 25 28
g-gain 25 25 25 24
b-gain 29 27 30 24
10-point
r1 0 -1 1 0
g1 0 -1 0 0
b1 0 0 1 1
r2 0 2 -4 0
g2 0 1 -3 0
b2 0 2 -4 0
r3 1 0 1 0
g3 0 0 1 0
b3 0 -2 0 0
r4 0 1 0 0
g4 0 0 1 0
b4 0 -1 1 -1
r5 0 0 2 -1
g5 1 1 2 0
b5 2 -3 3 1
r6 -2 0 1 -1
g6 0 0 1 0
b6 0 1 2 1
r7 1 1 0 0
g7 2 1 0 0
b7 2 2 0 0
r8 -2 -1 -1 0
g8 0 0 -1 0
b8 0 1 -1 0
r9 0 -1 0 0
g9 2 -1 0 0
b9 -2 1 -1 0
r10 0 1 1 0
g10 2 0 0 0
b10 -2 3 -3 0
Old 07-05-2011, 01:16 PM
jmsnyc's Avatar
Quoted: 18 Post(s)
Just curious how the settings in OP are working for most?
jmsnyc is offline
Old 07-05-2011, 02:19 PM
Jay Nova's Avatar
I tried the Cue03 settings and it took pretty much all the color out of the display. So I wouldnt go with that. Gonna try some others once my panel gets replaced...
Jay Nova is offline
Samsung Pn51d6500 51 Inch 1080p 600 Hz 3d Plasma Hdtv Black 2011 Model , Samsung Pn59d6500 59 Inch 1080p 600 Hz 3d Plasma Hdtv Black 2011 Model
