Anyone know how to uninstall Viera Connect Apps? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-13-2011, 07:58 PM - Thread Starter
humphrey11's Avatar
I can't seem to find the option.
humphrey11 is offline
post #2 of 17 Old 04-14-2011, 09:54 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Go to the menu and scroll down to the box with the wrench icon. Then continue to scroll to Viera Link settings and turn them off.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #3 of 17 Old 04-14-2011, 12:11 PM - Thread Starter
humphrey11's Avatar
anyone?
post #4 of 17 Old 04-14-2011, 12:57 PM
whiteboy714's Avatar
Did you try what the post above you said?
whiteboy714 is offline
post #5 of 17 Old 04-14-2011, 04:17 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
anyone?
Ian
mailiang is offline
post #6 of 17 Old 04-14-2011, 10:59 PM - Thread Starter
humphrey11's Avatar
Sorry, I didn't notice your post before I posted a 2nd time. And no, it doesn't work. The only thing that shutting of Viera Link does, is disconnect the hardwired connections between the television and blu-ray player (the remote controls are no longer shared, and the two devices don't turn on/off with each other).
post #7 of 17 Old 04-15-2011, 11:49 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
What are you trying to do?
Ian
mailiang is offline
post #8 of 17 Old 04-15-2011, 01:03 PM - Thread Starter
humphrey11's Avatar
Ian
I'm trying to uninstall apps that I download from Viera Market.
post #9 of 17 Old 04-15-2011, 01:22 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
The feature you are referring to is new and only available on the 3D sets. I thought most of the content was for streaming. I doubt you will find much info on downloading content unless you contact Panasonic direct. Have you tried customer service?
Ian
mailiang is offline
post #10 of 17 Old 04-15-2011, 01:39 PM
dlplover's Avatar
You can use a hammer, but it might have unintended consequences.
dlplover is offline
post #11 of 17 Old 04-15-2011, 01:51 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Ian
mailiang is offline
post #12 of 17 Old 04-15-2011, 09:43 PM - Thread Starter
humphrey11's Avatar
Ian
Nah, not yet. I figured I'd try here first.
And Viera Market has games, streaming content, sports scores, facebook, twitter, etc...quite a few options. I find most of the offering pretty useless, but hey, maybe one day I'll want to facebook on tv?
post #13 of 17 Old 04-24-2011, 10:13 AM
RickyKohler's Avatar
I just figured it out... Go into VIERA CAST (rather than the TV menu) and use the MORE/BACK arrows until you get to a screen with Settings. In settings, you can choose Customize HomeScreen, which is where you can uncheck the specific apps you no longer want. You can also move apps from page to page, so that your favorites are shown first, or located in groups of your choosing.
RickyKohler is offline
post #14 of 17 Old 09-11-2012, 01:34 PM
platinumzombie's Avatar
sorry for resurrecting this thread.
this does not remove them, only hides them. anyone figure this out yet?
platinumzombie is offline
post #15 of 17 Old 11-13-2012, 11:10 AM
doug290's Avatar
Thank you
doug290 is offline
post #16 of 17 Old 12-26-2012, 01:46 PM
tfunq's Avatar
Looks like it's not possible, which is amazing. Panasonic's help "module" on How to Remove Apps from VIERA Connect describes the procedure above, which just hides from them display. They're still in your list of apps.
The only way to remove an app from that list appears to be to reset the whole app set to the default.
No wonder everyone is hoping Apple comes out with a TV. The picture is great on the Panasonic but the UX is horrible.
tfunq is offline
post #17 of 17 Old 06-27-2015, 10:07 PM
Liked: 0
Remove apps
What you do is go to the app you want to remove and then press the options menu on the remote and this will give an option to remove it , hope this helps
Geoffs2 is offline
