Does your 2011 Samsung "D" plasma have brightness pops? - Page 68 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Does your 2011 Samsung D series plasma have brightness "pops"?
Yes 1 100.00%
No 0 0%
Voters: 1. You may not vote on this poll
Old 01-31-2012, 06:08 AM
LanceX's Avatar
Quoted: 84 Post(s)
Liked: 30
awesome bry.
AGAIN ZOYD COMFIRMED NO TRUE CHANGE IN BLACK LEVELS. Those that cant optimize please see Zoyds thread on manually updating!
LanceX is offline
Old 01-31-2012, 06:36 AM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
Originally Posted by KTM250 View Post
I would be very careful saying this. The update has really trashed the picture on my D8000. The blacks are no longer black they are gray. Dark content never gets black. It looks like what they did was to make the tv stay in the popped state. Dark content has the light haze look to it now. I hope recalibrating will help. If not I will contacting Samsung and found out how to roll this back one Rev.
Try again after calibration (I'm assuming you have a meter to confirm?). The update in no way trashes the black levels. 0% pre/post black level stability has been confirmed on the D8000 and D7000 by me(51D8000) and Jason Widdon@HDJ owners thread (64D7000), not sure if Larry has measured it yet but his qualitative assessment was positive.
You will not be able to rollback the update without replacing your logic board.
zoyd is offline
Old 01-31-2012, 06:39 AM
KTM250's Avatar
Quoted: 13 Post(s)
Originally Posted by LanceX View Post
awesome bry.
AGAIN IT TRASHED MY PICTURE. So which tv does zoyd have 7000 or 8000? This could be a difference. What would be nice is to have one of the pro calibrators with good equipment check the black level out. I also have a i1d2 meter like zoyd and it is not the best at the low end.
KTM250 is offline
Old 01-31-2012, 07:03 AM
zoyd's Avatar
Liked: 1051
Post your D2 measurements of a 0% stimulus for comparison.
51D8000 pre=0.015 ftL, post=0.015 ftL
64D7000 pre=0.007 ftL, post=0.007 ftL
zoyd is offline
Old 01-31-2012, 09:26 AM
KTM250's Avatar
Quoted: 13 Post(s)
Zoyd you stated that "You will not be able to rollback the update without replacing your logic board". Now please explain to me why this would be? If you can flash it up you should be able to flash it down. Makes no sense.
KTM250 is offline
Old 01-31-2012, 09:39 AM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
I believe zoyd said this is because the logic board comes with factory-installed firmware that has never been released to the public (prior firmware upgrades have not modified, and therefore did not contain, the logic firmware). Once you upgrade it to this "popless" revision, you overwrite the old firmware, so there is no going back.
AvidHiker is offline
Old 01-31-2012, 10:08 AM
redrayderz01's Avatar
So Samsung in California called me today and offered me a refund because the technician that came yesterday (replaced mainboard) deemed the tv irrepairable. This was before I did the logic board update.
I declined the refund and told the lady that I adjusted the settings and can live with the pops. I DON'T want to start all over with another TV.
So far so good with the logic board update.
redrayderz01 is offline
Old 01-31-2012, 10:13 AM
zoyd's Avatar
Liked: 1051
correct. Factory logic flash files are not available to revert to.
zoyd is offline
Old 01-31-2012, 10:20 AM
zoyd's Avatar
Liked: 1051
Oh and by the way, none of this would have been possible without the work of several people over at samygo.tv I would not have been able to extract those flash files if they hadn't first hacked the D series TVs and discovered the firmware encryption keys.
zoyd is offline
Old 01-31-2012, 12:35 PM
cyberbrad's Avatar
zoyd - I have a 64D7000 currently running FW 1011 and logic board version shows 2011-02-22. The TV is currently prompting me to install FW 1015. Do you recommend that I apply that 1015 firmware first, and then apply the logic board update? Or apply logic board first and then firmware?
cyberbrad is offline
Old 01-31-2012, 12:48 PM
zoyd's Avatar
Liked: 1051
You can just apply the 1014.6 FW here to save time and then recheck logic board version. If it isn't 11-11-04 then apply the logic board update. I'm not aware of any benefits for being on 1015 vs. 1014.6
zoyd is offline
Old 01-31-2012, 01:16 PM
cyberbrad's Avatar
Thanks. Are you saying it saves time because 1014.6 includes the 11-11-04 logic board update?
Old 01-31-2012, 01:29 PM
alexmanny01's Avatar
Does anyone have the roll back update for the d7000?
alexmanny01 is offline
Old 01-31-2012, 01:42 PM
ampogo's Avatar
That is correct.
ampogo is offline
zoyd's Avatar
Liked: 1051
yep, but it does not always get applied, it's been hit and miss
zoyd is offline
Old 01-31-2012, 01:46 PM
Squints's Avatar
I second this. I would like the roll back as well!!
Squints is offline
Old 01-31-2012, 02:24 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Originally Posted by redrayderz01 View Post
Major, major props to Zoyd and Larry. Do you guys work for Samsung or something?
Lol
Tonight was the first night where I could actually enjoy some shows!
All the credit should go to zoyd. He is the one with the knowledge and experience in digital and analog electronics engineering. I'm just an old physicist -- the analog type -- that follows him around picking up his crumbs here and there.
Larry
LarryInRI is offline
Old 01-31-2012, 02:27 PM
cyberbrad's Avatar
Thanks zoyd and ampogo !
Old 01-31-2012, 02:31 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
I measured my 64D7000 last night. The minimum luminance level was unchanged from before the logic update. It is still at 0.007-0.008 ftL.
A note to those that have to enter the service menu: Doing so will reset all your user settings to the factory default values -- including the Brightness.
Larry
Old 01-31-2012, 02:36 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
Old 01-31-2012, 04:14 PM
Squints's Avatar
Was having troubles last night updating my PND6900. Kept saying "no match". Have to try the "less_deepblack" file Tonight when I get home. Just seems plugging the USB in from Samsung would be less of a "hack" so to speak. Diving into this makes me uncomfortable, don't want to brick my tv. The thought of voiding my warranty is lingering in m head....
You guys are good though. Thank you for your efforts! Samsung seems to hang us out to dry with their lack of concern on the subject...
I'll update if I'm successful.
Squints is offline
Old 01-31-2012, 04:18 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
Old 01-31-2012, 05:30 PM
ampogo's Avatar
I had the same issue, I also had to use the less_deepblack on mine and the "updating" process commenced. Good luck!
ampogo is offline
Old 01-31-2012, 05:32 PM
ampogo's Avatar
Thank you Zoyd, I no longer have brightness pops now that I updated my logic board. This was a long time coming, congrats to everyone now we can enjoy the tv fully.
ampogo is offline
Old 01-31-2012, 05:40 PM
So do us d7000 owners with firmware 1015 need the roll back USB?
Old 01-31-2012, 05:41 PM
Congrats! Feels good, doesn't it?
Old 01-31-2012, 05:52 PM
zoyd's Avatar
Liked: 1051
Great! glad to hear it.
@alexmanny01: You can wait till samsung sends you a rollback or update logic board as others are doing. your choice.
zoyd is offline
Old 01-31-2012, 06:34 PM
pato79's Avatar
Quoted: 21 Post(s)
Update:
Its been about a week and I have not seen one pop on either my 51D8000, or 59D8000.
Thanks again to everyone especially Zoyd.
pato79 is offline
Old 01-31-2012, 09:14 PM
Sorry I'm sure it's been discussed...
How do I update logic board and then upstate to fix? Thanks to all
Old 01-31-2012, 09:22 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
First post in the Samsung D series FBr fix discussion thread.
Larry
