Official Panasonic 2011 TC-PxxS30 Thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
post #511 of 525 Old 06-19-2013, 01:42 PM
DGerard's Avatar
Buzzing sound.
Just a quick note for others who may be having similar problem. My TC-P50S30, manufactured the end of 2011, put in service 1/2012, started having a buzzing noise from the upper right corner of the set when viewed from the rear, varying with screen brightness/whiteness. Plasmas as a whole have some buzzing associated with them, but this is clearly not normal and was new. After lots of Google research, I have determined that the noise on 2010 sets is usually due to a cracked transformer ferrite and has been cured by wrapping the transformer with zip ties to act like a clamp. Google it on your own if you want more details. However, for sets made in 2011, the cause is loose screws on the boards, very commonly the board near the upper right corner as viewed from the rear. The screws themselves don't vibrate, they act as a ground path for the boards and when not tight lose their conductivity. After removing the rear panel, I found one screw, the usual one implicated, able to be tightened easily about a 1/4 turn. This eliminated the buzz right away. Several others were slightly loose on other boards. I tightened them all up. Note, Panasonic makes a replacement screw kit for this reason. The new screws have split type lock washers on them. If my screws loosen up again, I may go for the new screw set, or maybe blue loctite instead. Hope this helps others.
Connecticut
DGerard is offline
post #512 of 525 Old 06-22-2013, 08:08 PM
sage11x's Avatar
Quoted: 731 Post(s)
Liked: 808
I've got the buzzing very bad. My set is still under the two year warranty so maybe I'll sit on death hold and see if Panasonic will send a technician out to tighten the screws. You'd think that after this many years making sets that Panny wouldn't be making these kind of mistakes...
I guess I shouldn't complain too much as my brand new FR-S needs to have the Toyota part of the engine's fuel injection system ripped out and replaced.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #513 of 525 Old 09-03-2013, 03:34 AM
HonoredShadow's Avatar
I have a few question about this TV which I have had for over a year or so.
1) Does labeling the inputs make a difference in any way? Eg. HDMI 1 to GAME etc... I expect no.
2) Is their a difference in plugging things into either HDMI 1 or 2? They are labeled different. I have a PC in HDMI 1 and XBox in HDMI 2. Neither HDMI is labeled as I said above.
3) The ATI/AMD card I have has detected the TV and set itself as 'default' to Ycbcr 4:4:4. Is this correct for the TV? The PC connected is only used through the TV and only plays TV programs/films. No games.
4) I use the resolution of 720p as I can't read text/internet otherwise. Should I tick or un-tick the option in the ATI/AMD driver for GPU scaling? Currently it is on.
5) I have noticed you guys talking about HDMI content detection. I my UK TV I have this in Setup/Link settings. HDMI content detection Off/Auto. It is off by default. What is it? It's a universal on or off it seems. I could be wrong.
Wonder if it improves picture with PC and XBox? Also would it create more frames lag?
Would be VERY grateful for any suggestions. Thanks all.
HonoredShadow is offline
post #514 of 525 Old 09-18-2013, 11:55 PM
zapco's Avatar
I bought mine probably more than 2 years ago and now I have the red light blinking 7 times with no picture or power. From what little research I've done it seems it can be a few things, loose connections, faulty card or failed plasma screen.
Anyone else have similar issues? Would like to hear from the community.
Bret
zapco is offline
post #515 of 525 Old 09-19-2013, 02:20 PM
tomwil's Avatar
Liked: 26
Most likely it is a SC/SU/SD board failure due to faulty firmware. If you have the boards replaced, be sure to have the revised Panasonic firmware installed.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #516 of 525 Old 09-20-2013, 07:44 AM
Clemulus's Avatar
It just so happens my S30 just had the 7 blinking lights of death last night. Panasonic wanting $35 to tell me what could be wrong with it. A little internet research showed it's probably a fried board. Not sure what my next steps are going to be....really p'od. I can only get 24 months out of a TV? Was thinking of getting the ZT60 but not so sure about Panny now. My Kuro pro-110fd is still marvelous at 4 1/2 years old.
Clemulus is offline
post #517 of 525 Old 01-23-2014, 10:08 PM
olp79's Avatar
Hey guys, was wondering how I can get the snow/salt and pepper to show up on this tv? I have some image retention and would like to just have the "snow" on the screen for a few hours to see what happens. Whenever I switch it to ant/cable, the snow shows up, but then goes black, and a caption pops up, Anyway to have the snow stay on there?
Thanks for any info.
olp79 is offline
post #518 of 525 Old 01-23-2014, 11:10 PM
sage11x's Avatar
Quoted: 731 Post(s)
Liked: 808
Go to amazon and pick up the Disney wow disc-- it features a 'pixel flipper' which you can use. To be honest, though, just watching tv is the best way to alleviate IR (assuming it's a program without the logo or static graphic that caused the IR in the first place).
sage11x is offline
post #519 of 525 Old 01-24-2014, 11:30 AM
olp79's Avatar
Thanks for the reply.
I actually ordered one of these discs to calibrate the set, but seems to be taking forever for delivery.
I bought the set used (probably not the best idea) for a couple hundred, checked the hours, and it "only" has 1500 hours on it. Now that I have it home, I can see some burn in/image retention. Looks like a computer screen to me.
Besides the Disney Disc, what else is recommended to get rid of, or at least reduce the burn in?
olp79 is offline
post #520 of 525 Old 01-24-2014, 11:50 AM
sage11x's Avatar
Quoted: 731 Post(s)
Liked: 808
As I said, just running the display with varying content will suffice. Depending on the damage you may or may not be able to alleviate it. Persistent IR is typically caused by static logos or computer graphics 'aging' the phosphors in those areas more than the rest of the screen. The only real way to combat that kind of abuse is to continue to watch the display (or use the pixel flipper or screen wipe)-- eventually, with any luck, the wear between the affected areas and the surrounding panel will reach a more uniform state of wear and you'll not notice it. Sucks I know.
sage11x is offline
post #521 of 525 Old 06-15-2014, 09:02 PM
Liked: 0
Somehow my TC-P50S30 is exhibiting motion interpolation for the first time in the 3 years i've owned it. i have no idea how this happened. from what i can find online, it has some software called Intelligent Frame Creation? I can't find an option for this anywhere, however. Can someone tell me how to turn this off? Thanks very much.
dave13 is offline
post #522 of 525 Old 06-15-2014, 09:43 PM
sage11x's Avatar
Quoted: 731 Post(s)
Liked: 808
Really? Normally this is an option in the picture settings but your TV shouldn't have it as only the ST and up came equipped. Are you sure what you're seeing is being caused by the TV? What exactly are you seeing?
sage11x is offline
post #523 of 525 Old 06-23-2014, 09:11 PM
jdougmc's Avatar
I've been trying to find an IR remote app for my Galaxy S5 phone that will control my TC-P42S30 but have had no luck. I've tried at least a dozen from the Google Play Store, including the two "official" apps from Panasonic, but none work. Has anybody had any luck with an Android app that will control this TV? I have no problems controlling other devices from the S5, just this TV. I have only downloaded and tried the free ones so far, because I'm afraid to pay $8-10 for an app that doesn't work, but I gladly will if I know it's good.
J Doug
jdougmc is offline
post #524 of 525 Old 05-04-2016, 01:49 AM
scottyboy76's Avatar
Hey guys, my lae wife and I bought our 2nd panny plasma after being so satisfied with our 50pz700u.
our new one is a tc-50s30, love it with the smart features and all, although the pic on the 700 was much more natural especially skin tones.
Now the problem, after a static discharge, which seemed like a lightning strike, ther were some problems for som electronics in the house.
All device affected were hooked to a cable coming in from outside.
Directv boxes, wirel
ess phones and answer machine etc.
our panny pz700 only lost hdmi capability, hooked it up diff, and works fine for a bedroom set, pic looks good as ever.
the p50s30 however wont power up.
1st, are there any internal fuses.
If it power supply, is plug and play or does It need soldering
I did buy a Samsung pn60f5300f for living room, looks fine but must get a disc to help me adjust10p white balance, as well as other functions with test patterns..
The main complaint is a scene with the sky in background, or bright lighting is way too blaring losing detail
I have tried gamma adjust and of coarse standard contrast bright and such.
I would appreciate a recommendation on a user friendly test and adjust video to use thru my buray player
Somewhere around here is joe kanes video essentials but I don't think it is bluray.
Any help tryinto decide whether to put money in the s30 as wel as a good bluray adjustment vid that a laymen can work with would be greatly app.
BTW money is kinda tight as im a disabled vet on a fixed income.
If a shop tells me its going to be a good bit of money to fix, I will try to work with local vet organization to pool our money and donate to a deserving combat vet.
If you guys help me w some good advice, I will definitely post some pics when we surprise the great american with the tv
Any helpwill be very helpful, concerning adjusting the Samsung plasma in the living room and also any simple checks or tests on thes30.
scott
BTW not sure why that quote was included in my post, not intentional.
scottyboy76 is offline
post #525 of 525 Old 01-13-2017, 10:25 AM
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
I need help for a friend. I gave him a lan antenna that came with my ST30(it died) so he could hook up to the internet for Netflix. It didn't work so he called Panasonic and they told him my antenna wouldn't work with his plasma. I thought these antennas were generic so I don't believe them. Four questions:
1. Am I right?
2. If wrong what antenna should he get?
3. Can I loan him my Buffalo AC usb antenna off my PC? Will that work? Not sure how since it needs drivers on my PC.
4. Is ther a built-in antenna on the tv just for testing the connection ability?
Jack
JackB is offline
Panasonic Viera Tc P50s30 50 Inch Plasma Hdtv , Panasonic Viera Tc P60s30 60 Inch 1080p Plasma Hdtv , Panasonic Viera Tc P46s30 46 Inch Plasma Hdtv
