Panasonic ST30 Custom Mode Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-26-2011, 01:24 PM - Thread Starter
blest's Avatar
First post!
Hello everyone, I recently purchased an ST30(55") from amazon and I've been going mad trying to figure out the best settings without having to get a professional to calibrate the TV for me. I've searched the forum for my answer but I kept finding other posts that didn't answer me correctly.
Basically I would like to know every single Custom Mode setting you all used for your set. I think it would help others in need who have a similar question. The TV is excellent but I know I can tweak it more. Sorry if this is a repost.
IE*
Brightness = 10
Contrast = 7
Color = 2
etc..
Thank You,
b|est
blest is offline
post #2 of 19 Old 04-26-2011, 02:40 PM
GSDTrainer's Avatar
Search for the "official stxx panny" on here. Theres probably settings in that thread.
EDIT: heres the thread http://www.avsforum.com/avs-vb/showthread.php?t=1319498
GSDTrainer is offline
post #3 of 19 Old 04-26-2011, 03:22 PM - Thread Starter
blest's Avatar
Ahh thank you sir, I'll get to reading
**EDIT** hmmm I've looked at that one before and I couldn't find exactly what I was looking for... Or maybe I should go page by page ( i think there are 60+ pages :[ ....)
Any other ideas?
blest is offline
post #4 of 19 Old 04-26-2011, 04:50 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Do a Google search for:
"d-nice" Panasonic ST30
Larry
LarryInRI is offline
post #5 of 19 Old 04-26-2011, 05:05 PM
MASKOAA's Avatar
Quoted: 13 Post(s)
Are you sure your settings are right? 2 for color out of 100? lol
MASKOAA is offline
post #6 of 19 Old 04-27-2011, 09:18 AM
chemical360's Avatar
Larry
Just keep in mind that D-Nice's settings are to be used only if you ran slides for 200 hours.
I tried his settings without running slides and the pictures was near colorless and dark.
I tweaked mine myself in Custom and got mixed results until I have settled on what works best for my room and lighting. I will PM you what I have used but please understand that this is not the best idea. Your lighting conditions and room are different and therefore these settings may look off.
Xbox Live=chemical360
PSN=chemical360
chemical360 is offline
post #7 of 19 Old 04-27-2011, 11:16 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
Actually they're supposed to be run for 100 hours, not 200.
Yeah, any deviation from the panel aging instructions usually results in non-ideal results.
Maybe at this point a calibration DVD would be helpful?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8 of 19 Old 04-27-2011, 11:29 AM
MASKOAA's Avatar
Quoted: 13 Post(s)
I used D-Nice settings without using the slides and I actually loved it.....
MASKOAA is offline
post #9 of 19 Old 04-27-2011, 11:31 AM
Eh, I have it looking good on my own. But when I get around to it, I do have a calibration DVD I do want to try.
Sorry about the misinformation there. I thought it was 200... My bad.
PSN=chemical360
post #10 of 19 Old 04-27-2011, 05:14 PM - Thread Starter
blest's Avatar
Is there something specific i should run for 100 hours? or just loop any random movie?
Thx guys
b|est
blest is offline
post #11 of 19 Old 04-27-2011, 05:40 PM
fairchild99's Avatar
Liked: 151
Thx guys
b|est
Color slides or just watch regular HD content that fills the whole screen with no logos or hud's.
http://www.eaprogramming.com/downloa...kIn_Images.zip
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #12 of 19 Old 04-27-2011, 05:48 PM
Jacob305's Avatar
Quoted: 85 Post(s)
Liked: 48
I own the gt25 set from last year. I use the thx setting for 2d movies and the james cameron settings for 3d movies. it works great for both.
Jacob
Jacob305 is offline
post #13 of 19 Old 04-27-2011, 06:20 PM - Thread Starter
blest's Avatar
thx fairchild! so i can run this while i go to work and then come home and watch tv and then next day repeat the process? or do i have to wait 100 hours before i start using it regularly.
Ahh the questions of a noob.
blest is offline
post #14 of 19 Old 04-27-2011, 07:40 PM
Liked: 151
If you plan to use D-Nice's settings then you'd want to run the slides for 100 hours without any other content in between. You can do that or just watch the TV as normal then apply whatever settings you want. Break-in process for the first 100-200 hours is done usually to evenly age the panel for a calibration done with a meter+software.
post #15 of 19 Old 04-27-2011, 10:55 PM - Thread Starter
blest's Avatar
A gentleman and a scholar! here here! i think i'll put the pictures on a usb stick and just have the tv have a slideshow.. good idea?
blest is offline
post #16 of 19 Old 05-02-2011, 09:36 PM - Thread Starter
blest's Avatar
bump
blest is offline
post #17 of 19 Old 05-02-2011, 09:41 PM
Liked: 151
If you are following D-Nice's settings, then follow them exactly.
If you are just doing them to age the panel for whatever reason then yes use slideshow and make sure they are cycling through the colors at a decent pace (I think 20-30s between color is fine)
post #18 of 19 Old 01-30-2012, 06:09 PM
HouseOfChains's Avatar
Hi all,
Sorry for bumping such an old thread but I cannot find D'Nice's settings for the ST30. It seems it's guarded and only set via PM. Would someone mind sending me them? Thanks!!
HouseOfChains is offline
post #19 of 19 Old 01-31-2012, 09:27 AM
BrownRB's Avatar
Not that hard to find - here you go:
http://www.avsforum.com/avs-vb/showthread.php?t=1371710
Be prepared to be overwhelmed...
BrownRB is offline
