Antiglare / Antireflective coating peeling on new Samsung plasma? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 1203 Old 06-02-2011, 06:30 PM
Acid Snow's Avatar
Originally Posted by spdntrxi View Post
that is not the purpose.. samsung is not my fav company either but dont make stuff up.
...Yeah, I assumed a bit, but are you sure the coating doesn't have a dual purpose?
Acid Snow is offline
post #182 of 1203 Old 06-02-2011, 06:36 PM
RedOctober205's Avatar
Originally Posted by Acid Snow View Post
I too wanna see pics of the peeling coat... It's disgusting of Samsung to use a tinted plastic coating on their plasmas', in attempts to take the cheap way out to increase their black levels. Anyone here who buys these model Samsungs' after having read the posts in here is supporting bad design philosophies and a lazy company.
Well then you can complain to Panasonic as well. Jump in a time machine and complain to Pioneer also. All the AR coating are tinted.
RedOctober205 is offline
post #183 of 1203 Old 06-02-2011, 06:41 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Um, if i'm not mistaken, the AR Filter on the Panasonics and Pioneers also helps increase their black levels. FWIW.
Seems like maybe Samsung is having a problem with the application of the adhesive (or with the adhesive itself) on their bonded filter.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #184 of 1203 Old 06-02-2011, 06:44 PM
dlplover's Avatar
I was pretty sure Pio's was bonded directly to the glass. Panasonic's probably is as well. ie a chemical layer on top of the glass rather than a plastic one. Pretty sure that is what Acid Snow is talking about. I know you can get AR filters that you can apply, but I don't think they're necessarily the same as the material that's on there in the first place (i.e. that can rub off and requires care when/if cleaning). Or in the least, the others are all adhered properly so that they stay on for the life of the set.
There're people will 10 yr old Panasonic and Pio sets that have not undergone peeling.
dlplover is offline
post #185 of 1203 Old 06-02-2011, 06:48 PM
dlplover's Avatar
The hate is strong is this one
AFAIK, ALL modern plasmas use the AR filter to both reduce glare and to improve black levels. He's not making that up.
dlplover is offline
post #186 of 1203 Old 06-02-2011, 06:52 PM
spdntrxi's Avatar
AR yes.. but it does not look tinted to me.
Johnny
Klipsch,Denon,Parasound,Sunfire
spdntrxi is offline
post #187 of 1203 Old 06-02-2011, 07:18 PM
Acid Snow's Avatar
WTF!? Pioneer (and others) used coatings on their glass that wasn't built into the glass to improve their anti-reflection properties? ...Pioneer just dropped down a peg
Seriously though, WTF ? ...StarTrek obviously has the best technology, everything else is just a soggy-bread. Captain Picard FTW (I came after Kirks time, sry).
post #188 of 1203 Old 06-02-2011, 08:07 PM
dlplover's Avatar
You'll have to clarify that statement because I'm not sure which panels you're referring to. I think you're misunderstanding what people mean by "tint".
dlplover is offline
post #189 of 1203 Old 06-02-2011, 08:13 PM
spdntrxi's Avatar
Now I realize "tint" can mean many colors but when some ads that it's purpose was to have cheap darker black levels.. well then tint turns into meaning "darker" to me.
Regardless it should not be peeling at the corners or anywhere else.
Johnny
spdntrxi is offline
post #190 of 1203 Old 06-03-2011, 01:35 PM
digiuser's Avatar
Still, nobody with this unbelievably wide spread problem has posted pictures. Maybe they are to busy shopping for another TV?
Anxious to see if mine is going to have the problem.
If you have the peel, please post pictures.
digiuser is offline
post #191 of 1203 Old 06-03-2011, 01:42 PM
dvrmstrng's Avatar
my pictures were posted on page 2 i believe. Only got worse as time went on. Started outside the pixel panel and within days was peeling over top of the pixels.
dvrmstrng is offline
post #192 of 1203 Old 06-03-2011, 02:30 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Anxious to see if mine is going to have the problem. If you have the peel, please post pictures.
Did you even read this thread or the other thread? About 5-6 people have posted pictures of their peeling screens.
Randy
post #193 of 1203 Old 06-03-2011, 09:59 PM
Dave_O's Avatar
After reading about this issue in a number of forums, I checked my new set with a flashlight and saw that it indeed had 2 very small areas of peeling film, which depressed when touched, in the upper corners. Probably would never have noticed it if I hadn't read of the problem.
Reported to Samsung, they said they will send a service rep out.
Dave_O is offline
post #194 of 1203 Old 06-04-2011, 07:23 AM
dvrmstrng's Avatar
Whoa thats way worse than the first two sets I returned. MY first two the peel wasn't even close to reaching where the pixels are.
post #195 of 1203 Old 06-04-2011, 07:53 AM
spdntrxi's Avatar
worst I've seen.. did you help it a little after it started ?
Johnny
spdntrxi is offline
post #196 of 1203 Old 06-04-2011, 08:26 AM
Dave_O's Avatar
Not at all. Called my local dealer (The Stereo Shop in Rochester NY) this morning, and thy are replacing it this afternoon. Hope the scond one is OK
Dave_O is offline
post #197 of 1203 Old 06-04-2011, 11:49 AM
Techlord's Avatar
Just imagine all of the other buyer's of these new Samsung plasmas that haven't been to any forums, not everyone on the planet belongs to a forum. Those people will go to where they purchased the set for a full refund and pick-up another plasma that doesn't suffer from peeling (VT30), I'm guess I'm saying most don't ever get reported at least on the internet.
Techlord
Techlord is offline
post #198 of 1203 Old 06-04-2011, 12:00 PM
spdntrxi's Avatar
Techlord
if you think the Vt30 has no issues.. well wakeup
Johnny
spdntrxi is offline
post #199 of 1203 Old 06-05-2011, 03:06 AM
Techlord's Avatar
I never stated that the VT30 didn't have no issues, all manufacturer's have their issues. The fact is this particular peeling issue is so wide spread it's making headlines, a large percentage of these Samsung plasmas are in fact suffering from the same defect from inside store display rooms to the consumer's home in what little time they have been released to the public! The failure rate is high for the amount of time they have been on the market!
Techlord
Techlord is offline
post #200 of 1203 Old 06-05-2011, 06:23 AM
Quoted: 1392 Post(s)
Liked: 587
Does make one wonder if anyone at Samsung actually plugged one of their sets in and played it for a week or two.
JimP is offline
post #201 of 1203 Old 06-05-2011, 07:00 AM
spdntrxi's Avatar
probably not.. which is why they where out so fast this year
anyways it will be fixed, probably is fixed already but damn there are alot of sets out there already. Sammy is going to have to worry about this for a full year, maybe longer. This could end up costing them having to exchange D series panels for E series panels down the road.
Johnny
spdntrxi is offline
post #202 of 1203 Old 06-05-2011, 08:33 AM
David_B's Avatar
Quoted: 14 Post(s)
Liked: 32
Let's hope so! Free upgrades for everyone next year! woop!
David_B is offline
post #203 of 1203 Old 06-05-2011, 08:39 AM
dlplover's Avatar
Do you know this for a fact?
dlplover is offline
post #204 of 1203 Old 06-05-2011, 09:36 AM
spdntrxi's Avatar
ofcourse not... but sammy typically jumps on things like this quickly..other things not so much. Will they admit something is wrong is an entirely different story.. they probably wont.
People just need to return there sets and send a message..I'm sure they are well aware. I showed my retailer the peeling on their set already.
Johnny
spdntrxi is offline
post #205 of 1203 Old 06-05-2011, 03:55 PM
Liked: 587
Well, you know that they not going to just throw those sets away. They probably won't replace the screens. My bet is that they'll remove the coating and respray it.
Think refurbs with an extended screen coating warranty.
JimP is offline
post #206 of 1203 Old 06-05-2011, 04:02 PM
Refurbished vs reconditioned...the two are different. They cannot simply remove and respray. With the process they go through to produce them in the first place, and the relatively low occurrence of issues, it would be cheaper/easier to scrap the panel glass altogether...if not the entire display.
post #207 of 1203 Old 06-05-2011, 05:51 PM
dvrmstrng's Avatar
I believe my 3rd and my "perfect" 64D7000 is starting to peel in the upper left hand quarter. It looked flawless last week upon delivery, but im almost positive im starting to see it let go in the upper left hand corner. I will give it until the end of this week.
post #208 of 1203 Old 06-05-2011, 06:20 PM
spdntrxi's Avatar
The way I figure it.. is this should be covered by the worksmanship of the warranty..although its a royal PITA hopefully exchanging later gives more time for sammy to get their act together..(later build date) going for a 4th panel in ~30 days is kinda crazy.
Johnny
spdntrxi is offline
post #209 of 1203 Old 06-06-2011, 02:52 AM
Techlord's Avatar
I'm not the least bit surprised, I did see this coming however. I saw one today at BB and pointed it out to the sales rep and he was shocked by how many returns there have been thus far! Why wait for Samsung to get it right, they don't deserve your loyalty after three freaking panels! Makes you wonder how many other components are sub-standard ...
Techlord
Techlord is offline
post #210 of 1203 Old 06-06-2011, 03:07 AM
Techlord
I have a hard time believing that a lowly BB sales rep, not working with returns, would be aware of the rate of returns. Of course an infant has more display tech knowledge in their pinkie finger than most BB employees as well.
