Green push horrible on G20 - AVS Forum
post #1 of 5 Old 05-21-2011, 07:08 PM - Thread Starter
SDB30's Avatar
I have 50G20, I've used D-Nice's service menu offsets, I prefer to use custom mode because of the nice pop and great contrast that it provides, but the green push is so bad I keep findiding myself switching back to THX mode. Is there anyway to get custom to match THX clor accuracy, or is this a flawed set? Some expert advice would be greatly appreciated
SDB30 is offline
post #2 of 5 Old 05-22-2011, 05:21 AM
Moderator
PooperScooper's Avatar
Quoted: 43 Post(s)
Liked: 73
How did you measure the green push or the accuracy of the THX mode? Once you change settings on a display you should wait a week or so to "adjust". Sometimes the new settings are correct, e.g. calibrated to D65, and you're just not used to seeing it.
larry
Opportunity is missed by most people because it is dressed in overalls and looks like work. -- Thomas Alva Edison
PooperScooper is offline
post #3 of 5 Old 05-22-2011, 06:22 AM - Thread Starter
SDB30's Avatar
Some blues looks almost aqua, like when I pull the direct tv guide, the guide looks aqua in custom mode, then I switch to thx mode or any othe mode and its a nice blue color, if I'm watching something showing the ocean it looks greenish blue, switch to thx mode it looks blue,likes it's supposed to. It's just really frustrating, I want to try to find a pro calibrator, but I can't justify that to my wife, she doesn't see the point, so I'm hoping I can do something in the service menu myself. It's worse in warm than normal or cool. My current offsets are : r-cut 76
g-cut 80
b-cut 83
r-drv fd
g-drv f7
b-drv 90
all cut 83
all drv fd
SDB30 is offline
post #4 of 5 Old 05-22-2011, 06:25 AM - Thread Starter
SDB30's Avatar
Green push may not be the right term, sorry I'm just a beginner
SDB30 is offline
post #5 of 5 Old 05-22-2011, 06:48 AM
Camster's Avatar
I've found the G20 hard to get looking right in Custom. One thing is it seems to need colour set lower. Anything over say 42 is too much. I assume if you used D-Nices settings your colour is around 35 as I think that is about what he posted.
I agree though I always go back to THX as it just looks right.
Camster is offline
User Tag List
