I wiped away the anti glare on my plasma TV - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 37 Old 05-28-2011, 06:07 PM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
So, I had a small scratch on my TV, and read from numerous sources online that using a white eraser on a scratch would remove it.
I did it briefly, and it didn't work, however, it did remove my anti glare...
Now I have a rather large blotch of extra shiny TV that looks awful when the TV is displaying a dark image.
Pretty choked... The scratch wasn't even noticeable, ever... I was just anal about it.
Is there anything to do to fix this? It looks ridiculous...
Tr0gd0r3 is offline
post #2 of 37 Old 05-28-2011, 06:30 PM
80sGuy's Avatar
Quoted: 179 Post(s)
Liked: 34
Never try to alter or mess with something that you're not familiar with. Try putting it back in the same manner (if it's even possible anymore) to see if it corrects the problem, otherwise you're screwed.
80sGuy is offline
post #3 of 37 Old 05-28-2011, 06:35 PM
hotskins's Avatar
Quoted: 60 Post(s)
Liked: 68
You can buy glare filter for your tv online or just save up for a new tv
hotskins is offline
post #4 of 37 Old 05-28-2011, 06:48 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 498 Post(s)
Liked: 766
Originally Posted by Tr0gd0r3 View Post
So, I had a small scratch on my TV, and read from numerous sources online that using a white eraser on a scratch would remove it. I did it briefly, and it didn't work, however, it did remove my anti glare... Now I have a rather large blotch of extra shiny TV that looks awful when the TV is displaying a dark image. Pretty choked... The scratch wasn't even noticeable, ever... I was just anal about it. Is there anything to do to fix this? It looks ridiculous...
Boy i wish you had come here to ask about fixing a scratch before taking that eraser to the screen - we would have told you that any attempt to remove a scratch will result in even worse damage to the AR Filter and to just leave it and live with it.
There is no way to repair a damaged AR Filter, but some brands/models have the filter bonded to a separate layer of outer glass which can be replaced. Others have the filter bonded directly to the plasma panel itself which would be prohibitively expensive to replace.
What brand and model is your TV?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 37 Old 05-28-2011, 07:15 PM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
Panasonic viera tc-p46s2
The noticeability seems to have gone away a bit... I cleaned the screen a bit.
It looks like a finger print basically. Tried using some cleaner I got from an electronics store specifically for plasma TVs... Maybe if I use it a couple more times and give it more time it'll help a bit .
AGHHHH
Tr0gd0r3 is offline
post #6 of 37 Old 05-28-2011, 07:31 PM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
Never mind. Still terrible.
Is there anything I could rub on? It's a small section. Just need to get rid of the shinyness of it... It's about an inch long, and a CM wide...
Tr0gd0r3 is offline
post #7 of 37 Old 05-28-2011, 08:23 PM
EvanVanVan's Avatar
Quoted: 20 Post(s)
Probably a last resort, but you could erase the rest of it? So at least it's one solid texture rather then a big ugly spot...?
EvanVanVan is offline
post #8 of 37 Old 05-28-2011, 08:46 PM
dlplover's Avatar
What model is this?
dlplover is offline
post #9 of 37 Old 05-28-2011, 11:54 PM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
Originally Posted by dlplover View Post
What model is this?
Tr0gd0r3 is offline
post #10 of 37 Old 05-28-2011, 11:55 PM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
thought about it, don't want to.
seems like too high of a risk... the spot's small enough that im hoping i can find a cheap easy fix ... hopiiiiing
Tr0gd0r3 is offline
post #11 of 37 Old 05-29-2011, 10:23 AM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
Anyone ?
Tr0gd0r3 is offline
post #12 of 37 Old 05-29-2011, 10:41 AM
Hudson1's Avatar
Anyone ?
You did a very foolish thing and the remedy is to live with it or buy a new television.
Hudson1 is offline
post #13 of 37 Old 05-29-2011, 10:47 AM
hotskins's Avatar
Quoted: 60 Post(s)
Liked: 68
luckily the 46s2s are not too much money. we have floor models vt25s for 996 at my store
hotskins is offline
post #14 of 37 Old 05-29-2011, 10:51 AM
Michael2000's Avatar
Liked: 27
This thread is a real eye opener. It shows how vulnerable these big TVs are to damage. It's a lot of square inches that could come in contact with other objects. Also in the old days, some CRT TVs came with glass contrast panels which 1) were durable in themselves, and 2) could be replaced if damaged. Not so with today's TVs. It would be nice if there were protective films you could put on, similar to that available for cell phones.
Michael
Michael2000 is offline
post #15 of 37 Old 05-29-2011, 11:29 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
I checked with Panasonic parts on line. You would have to replace the whole panel on the S2. Sorry dude.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #16 of 37 Old 05-29-2011, 11:51 AM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
I hate my life.
I have a 3 year extended warranty. Does something like this typically apply..?
Tr0gd0r3 is offline
post #17 of 37 Old 05-29-2011, 03:11 PM
aydu's Avatar
Quoted: 136 Post(s)
Liked: 113
I hate my life.
You could check the wording on your warranty, but I doubt it.
Most extended warranties just continue the coverage that the manufacturer's warranty provided.
Some manufacturers are going towards using Gorilla glass on their sets. This is supposed to provide a much more durable surface to the tv screen.
These sets are very fragile. People with kids, or flying game controllers are very likely to see damage.
IF you have Homeowner's insurance, you might check to see if accidental damage is covered. There would be a deductible, but it would likely be less than a new set.
Best of luck getting this resolved.
Don't take it too hard. In 10 years, you'll look back and laugh about the situation. In 20, you'll likely not remember it at all - unless your married. A significant other keeps a detailed record of every dumb thing you did - and reminds you frequently.
aydu is offline
post #18 of 37 Old 05-29-2011, 05:08 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Don't I know it. And mine is a lawyer too!
Ian
mailiang is offline
post #19 of 37 Old 07-19-2011, 11:25 PM - Thread Starter
Tr0gd0r3's Avatar
Quoted: 13 Post(s)
Hi. An update for anyone with this problem.
I decided to try Nushield because it was guaranteed, and only $15.
It worked, almost flawlessly.
I only notice it if I'm on an impossible angle that I wouldn't watch my TV anyways.
So... If anyone wants a cheap easy solution, there you go.
Tr0gd0r3 is offline
post #20 of 37 Old 07-19-2011, 11:54 PM
tfoltz's Avatar
Quoted: 62 Post(s)
Liked: 80
tfoltz is offline
post #21 of 37 Old 07-20-2011, 07:30 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Michael
You could get one of these:
http://www.tv-armor.com/
KONICA TECH likes this.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #22 of 37 Old 07-20-2011, 09:20 AM
dlplover's Avatar
Michael
Protective film will not stop a cell phone screen from cracking. Most it'll do is protect it from being dropped onto a flat surface.
Such a film would be pointless for a large tv, but as dsskid noted you can get a tv-armor for some real protection. There's also a bunch of other companies that make "tv screen protectors" if you google. tv-armor was one of the first though and is pretty reliable (it's the one I have).
dlplover is offline
post #23 of 37 Old 07-20-2011, 09:47 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Glad to hear it! You should add Nushield the link.
Ian
mailiang is offline
post #24 of 37 Old 07-30-2014, 10:41 PM
Liked: 0
I have the same problem with my SONY KDL 55w957a.. Im from Colombia. Dont know what to do
rangels04 is offline
post #25 of 37 Old 04-27-2015, 01:46 AM
Ketro's Avatar
Liked: 0
Hi Tr0gd0r3,
I have the same problem, did want to remove a scratch from my samsung F8500 and remove the anti glare layer. What did you exactly bought at Nushield and what did you do to get rid of the spot?
Thanks , hope you can help me .
Ketro is offline
post #26 of 37 Old 04-27-2015, 01:48 AM
Ketro's Avatar
Liked: 0
Anyone who can help me?
Ketro is offline
post #27 of 37 Old 04-27-2015, 01:49 AM
Ketro's Avatar
Liked: 0
There should be something that works to repair like a small spot?
Ketro is offline
post #28 of 37 Old 05-01-2015, 04:07 AM
Ketro's Avatar
Liked: 0
Originally Posted by mailiang View Post
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>Tr0gd0r3</strong> <a href="/forum/post/20716972"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
Hi. An update for anyone with this problem.<br>
I decided to try Nushield because it was guaranteed, and only $15.<br>
It worked, almost flawlessly.<br>
I only notice it if I'm on an impossible angle that I wouldn't watch my TV anyways.<br>
So... If anyone wants a cheap easy solution, there you go.</div>
</div>
<br><br>
Glad to hear it! You should add Nushield the link.<img alt="" class="inlineimg" src="http://www.avsforum.com/avs-vb/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br><br>
Ian
Hi mailiang,
Do you happen to know about this nushield kit that removes most of the damage .
I mailed Tr0gd0r3 but still no respons, maybe you could help me out.
Thanks in advance .
Ketro
Ketro is offline
post #29 of 37 Old 07-22-2015, 05:03 PM
Liked: 0
Originally Posted by Ketro View Post
Hi mailiang,
Thanks in advance .
Ketro
Did you ever find a solution to this?
I too have a F8500 that has some light scratches in the AG film.
Debating on how to handle it.
  • Leave it.
  • Remove the film without replacing it.
  • Remove the film and replace it.
  • Try and 'repair' (see hide) the scratches.
TheNozzle is offline
post #30 of 37 Old 07-22-2015, 05:15 PM
wuther's Avatar
Quoted: 578 Post(s)
Liked: 139
  • Leave it.
If you cannot see it while the TV is on then leave it alone.
I have a scratch on my plasma but I can only see when it is off.
wuther is offline
