Netflix audio firmware fix out for 2011 Panasonic Plasmas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-30-2011, 06:45 AM - Thread Starter
naalexDC's Avatar
You can download the manual firmware upgrade from the website: http://www2.panasonic.com/consumer-e...-P55GT30.DF#ts
I can't get my TV to upgrade itself automatically through the settings though. It'll probably be available in a few days, I'm guessing.
naalexDC is offline
post #2 of 3 Old 05-30-2011, 07:55 AM
HDTVShopping's Avatar
Does the update fix the issue with the sound?
HDTVShopping is offline
post #3 of 3 Old 06-01-2011, 09:38 PM - Thread Starter
naalexDC's Avatar
It's supposed to fix the problem, but I haven't been able to update through the TV's update firmware feature.
naalexDC is offline
