Where to get Pioneer Elite TV Stand - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-31-2011, 12:14 PM - Thread Starter
smess1211's Avatar
I have a 61" Pioneer Elite Plasma and need the table top stnad that goes with it.
I have searched high and low and can find one nowhere.
Anyone have any ideas?
TV is a Pro 1410HD and the stand is a PDK-1014
I have tried the usual ebay, amazon, craigslist etc.
thanks in advance
smess1211 is offline
post #2 of 2 Old 01-09-2013, 08:09 PM
cjmelinda's Avatar
some one on ebay is selling the pedestal feet for that plasma tv this week if you are still interested . the sits on 2 small feet one on each end ,but you can retrofit with a lg visio 57 inch base just add about ten pounds to the base the new ones are light plastic ,so add a metal sheet or thick piece of wood to the bottom it balances out the hevyness of the flat screen itself so it does not topple over good luck
cjmelinda is offline
