Panasonic ST30 DIY Calibration and Settings Thread - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1411 of 1416 Old 10-22-2013, 09:55 PM
kwaidonjin's Avatar
Originally Posted by joekingsj2 View Post
I just wanted to share my experience and adjustments since I have tried a variety of settings in an attempt to get a good image and I believe I have FINALLY got it.
The TV has a few problems that made it very difficult for me to get a satisfactory image;
-Colors look overly magenta and just plain off with the color past 29 or so. This is especially difficult to fix since there are no individual primary/secondary color adjustments.
-I have a slight green blob on the right side of the screen.
-Lack of 10 point gamma adjustment.
I used the X-Rite colorpro 3 along with the AVC 709 disk and HCFR software to do my adjustments.
Picture Mode - Custom
Contrast - 72 (adjusted using the AVS 709 Contrast test pattern)
Brightness - 74 (adjusted using the AVS 709 Brightness test pattern)
Color - 29
Tint - +4 (I had to push the tint to the green side to help with the magenta push my TV was exhibiting).
Sharpness - 33
Color Temp - Warm2
C.A.T.S. - Off
Color space - Normal (setting this to Wide gave skin tones an odd hue)
W/B - All calibrated accoring to my HCFR results
Black extension +3 (Crushed blacks SLIGHTLY and effects GAMMA in an odd way but content looks VERY nice IMO. on both dark and well lit scenes)
Gamma adjustment 2.4
Panel brightness - Mid
Contour emphasis - Off
AGC +2 This was a key adjustment for me. Most people keep this at 0 but when I set this to +2, I get the slight pop from the image I am looking for and colors look more vibrant without looking pushed or inaccurate in any way (similar to the way a CRT's colors look). Also, with AGC turned on, the green blob on the right side of the screen is much less apparent.
HDMI Range - Standard
Content Type - Off (I know some people prefer to set this to Graphics, but to me, setting this to Off gives a better contrast between blacks/whites and colors look more accurate).
Motion Smoother - Off
Black Level - Light
After my adjustments, I was able to get an image that resembles that of my friend's ISF calibrated Kuro.
Can you list all your pro settings?? WB and such.
kwaidonjin is offline
post #1412 of 1416 Old 01-09-2014, 12:25 AM
yobiruk's Avatar
Originally Posted by achelaaca View Post
Someone with the US version of ST30 models could please post the eight bytes that appear at address 40 of the eeprom(peaks) table ?
The sixth byte value should help us with european version of ST30 to enable the DLNA function.
This screenshot is from an european 50ST30:
imageshack.us/photo/my-images...513221245.jpg
Hi achelaaca,
Did you find how to enable DLNA function ?
I'm in the same situation.
My DLNA servers view my Panasonic P50ST30 as a DLNA player, but it cannot play there.
yobiruk is offline
post #1413 of 1416 Old 05-12-2014, 02:09 AM
N9ZN's Avatar
FYI - Your images no longer can be displayed, you may want to locate another server to place them on.
Now to your request, I have a TC-P42ST30 (U.S. 2011 model) and have gone into the EEPROM editor/flash utility located hidden within the SVC-TOOL information area. The data below is written exactly as the EEPROM editor/ flash utility displays for the PEAKS EEPROM HEX value table. Usually tables in Hex read from right to left but there is no mention of the order used (left to right vs right to left) to write this table. Based on viewing the highlighted data, increment by increment, these value tables are written LEFT TO RIGHT.
Hex-Addr   Data Area
00000038  00 00 00 00 00 00 00 00
00000040  19 08 19 00 72 03 02 20
00000048  00 00 00 FF FF FF FF FF
If you need more information about this Panasonic built in utility please let me know. There is no mention of the EEPROM editor/flash utility I can find on line but I will happily share what I know (very little beyond what I see on screen). It would be much appreciated if you would share any information you may have about this utility.
I am looking for data values written at location Hex 0150 and 0151 (sub contrast | RF_NTSC) also Hex locations 017C through 01C3 (SD & HD, high mid and low,Color Temperatures for R-CUTOFF, G-CUTOFF, B-CUTOFF, R-DRIVE, G-DRIVE, B-DRIVE.)  Note: FYI - ALL-CUT values are written else where and are standard set at value Hex 80. Should you require the X or Y axis W/B adjustment values I have them available for the TC-P42ST30 which I believe to be close to values of the model you are working with.
 I also need info for SVC-MENU Peaks EEPROM contrast setting values as the TC-P42ST30 sets leave the factory (will save swapping Peaks EEPROMS between 2 A boards).
Better yet, if you need any data from Flash(Lsi-data), Flash(Fake-Eeprom), EEPROM(Peaks), EEPROM(STBY), or FLASH(Module) I have access to all of it. It is very lenghty and there is no known way to dump this data to a file right now. I do believe there is a built in mechanism to allow transfer of data to a printer or other storage medium and I am trying to discover how to access this area. It would be very helpful if you know of a data sheet for IC8000, the Peaks module, or a copy of the loaded software program for these TV's.
Should you require a long list of data I can photograph it and post it as it appears in the editor. I have done this for your requested data below.
Best wishes with the data!
Monty
N9ZN is offline
post #1414 of 1416 Old 08-26-2014, 06:06 AM
e0feldgg's Avatar
Tightening all the screws inside worked for me too!
e0feldgg is offline
post #1415 of 1416 Old 10-25-2014, 06:37 PM
pmanyon's Avatar
Quoted: 64 Post(s)
Liked: 32
I have owned this TV for three years now, and I still think it holds it's own and even surpasses many of the current LEDs out there. Even the new lg oled is only a bit better in my opinion.
pmanyon is offline
post #1416 of 1416 Old 12-28-2014, 11:19 AM
Iron Maiden's Avatar
Quoted: 537 Post(s)
Liked: 208
Just popped my 60" open the other night. I had the common loose board in the upper corner. I went over every screw I could find in there. Must be 50 or so!!! Lost count how many needed to be tightened. But looking at the back, the upper right corner, the board was completely loose. Screws almost backed out all the way.
Once tightened, I treated the backside of the back cover with Damplifier Pro. A sound/vibration control product by Second Skin Audio. I had some left over from treating my C5 Corvette during the audio install. The back panel on the 60" is thin and an obvious culprit for noise and vibration. It didn't take much to deaden the piece. Maybe 10 pieces spread over the cover to create a dead panel. Simply does not vibrate anymore.
The TV is once again, dead quite. In fact it is more quite than when it was new. With no audio on and in my seating position, you can't hear anything. New, I could hear it. I really think the back panels on these tvs transmit noise by vibration. Treating the panel solves this. Certainly did in my case!
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
Panasonic Viera Tc P42st30 42 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P46st30 46 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P55st30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65st30 65 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic
