The Official Panasonic GT30 Settings Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 1341 Old 12-12-2011, 08:55 AM
george_g123's Avatar
Dave_O, many thanks for posting your color calibration settings! They work great!
george_g123 is offline
post #272 of 1341 Old 12-12-2011, 08:57 AM
ped
ped's Avatar
Hi there everyone, I've just got myself a THP50GT30A in the last week or 2 and absolutely love it, but....I've noticed something that I've never seen before on any tv (I work for an electrical retailer, so have seen plenty)
not sure how to explain it other than a series of white dashes that so far have appeared in the top left and bottom left corners when watching free to air tv, it's not on every channel, but it's not restricted to just one broadcaster.
Originally Posted by LSonsthagen View Post
I see that every night when watching our local news channel. Seems to only show up when they cut to the field reporter. I assumed it had something to do with a different camera since the feed from the anchor desk in the studio looks fine. It is the same for me on OTA as well as DirecTV's feed.
I think there are a couple possible causes for this:
The source is simply not encoded correctly and you are seeing bits of noise. I see this mostly with commercials.
There is a specific combination of the pixel orbiter and the HDMI screen size setting (size 1, size 2) that produces something similar to this. I don't recall the exact combo, but if you have the pixel orbiter on try turning it off.
ped is offline
post #273 of 1341 Old 12-12-2011, 12:17 PM
adverse_cal's Avatar
Thanks for the suggestion, I had a look in the advanced picture settings menu and found the pixel orbiter is set to auto with no option to change.
However, I tried changing some of the other settings, turning the 16:9 overscan setting to on has removed the noise, will check it later tonight to ensure it is still working.
Again, thanks
adverse_cal is offline
post #274 of 1341 Old 12-12-2011, 12:55 PM
pmil7991's Avatar
I applied the fw 2.1 on my 55GT30 over the weekend and then fw 2.2. Then I went and applied Dave_O mid panel brightness settings for fw 2.1. Man oh man, the picture looks fantastic. I watched a couple of blu-rays (King Kong and Sherlock Holmes). The picture quality on both, especially the skin tone, really blew me away. Thanks Panasonic and Dave_O.
pmil7991 is offline
post #275 of 1341 Old 12-12-2011, 01:51 PM
Mr.Green72's Avatar
I have a hard time processing that a firmware upgrade retains parts of the previous one, but I guess that if no one managed to brick his set and is happy with the results it's worth giving it a shot!
Mr.Green72 is offline
post #276 of 1341 Old 12-12-2011, 03:09 PM
ggsantafe's Avatar
Quoted: 199 Post(s)
Liked: 164
Mr.Green72 I have a hard time processing that a firmware upgrade retains parts of the previous one, but I guess that if no one managed to brick his set and is happy with the results it's worth giving it a shot!
pmil7991 I applied the fw 2.1 on my 55GT30 over the weekend and then fw 2.2. Then I went and applied Dave_O mid panel brightness settings for fw 2.1. Man oh man, the picture looks fantastic. I watched a couple of blu-rays (King Kong and Sherlock Holmes). The picture quality on both, especially the skin tone, really blew me away. Thanks Panasonic and Dave_O.
I second pmil7991 - followed the same sequence and am enjoying the results.
ggsantafe is offline
post #277 of 1341 Old 12-12-2011, 03:38 PM
day1yun's Avatar
can a few people post their default sm settings for each of the color temps(cool,warm,normal)? I know each display has different default sm settings but I'm wondering if the offset between the color temps is consistent from set to set. That may be a good way for people who have screwed up their sm settings for "warm" to recover the default values.
day1yun is offline
post #278 of 1341 Old 12-12-2011, 05:49 PM
wco81's Avatar
Quoted: 1194 Post(s)
Liked: 414
How do you upgrade the firmware?
I downloaded Dav_O's PDFs and set the THX and Custom with the values in those PDF files.
I've only watched TV, including Fox's poor-quality NFL broadcasts. I also watched Boardwalk Empire last night on D* (channel 501).
Picture looks fine, somewhat dim but mostly I notice a softness to the image.
Anyone else?
wco81 is online now
post #279 of 1341 Old 12-13-2011, 02:04 PM
pmil7991's Avatar
If you look in this thread, you'll find a link for fw 2.1. Follow the instructions and afterwards, connect to Viera Connection. You can then upgrade to fw 2.2. Then apply Dave_O's mid panel brightness for fw 2.1 settings. That's about it.
pmil7991 is offline
post #280 of 1341 Old 12-13-2011, 02:08 PM
bmanlb's Avatar
Anyone have good settings for 3d? Thanks!
bmanlb is offline
post #281 of 1341 Old 12-14-2011, 04:38 AM
AGtastic's Avatar
I have applied the 2.1 patch and Dave_O's 2.1 settings to my 65GT30. However, I have noticed much more pixilation in colored areas and color banding than before, even when comparing the same sources and material. Is it just me or perhaps I need to adjust my settings? If so, what settings would affect this?
Thanks for the advise!
AGtastic is offline
post #282 of 1341 Old 12-14-2011, 04:44 AM
justinto's Avatar
Quoted: 22 Post(s)
Install the 2.2 over the 2.1 update, then apply these settings:
Picture Mode Custom
Temperature Warm2
Panel Brightness Mid
Contrast 80
Brightness 50
Sharpness 25
Color 49
Tint 0
Gamma 2.2
Black extension 0
Color management Off
Video NR Off
Contour emphasis Off
CATS Off
AGC 0
Block NR Off
Mosquito NR Off
Motion smoother Off
Black Level Light
Grayscale
High R -1
High G 0
High B 3
Low R 0
Low G 0
Low B -1
Justin
LG OLED 65B6P; LG OLED 55B6P
Denon x4200W; (2)
Aperion Verus Grand Speakers
justinto is offline
post #283 of 1341 Old 12-14-2011, 06:48 AM
cpcat's Avatar
What were you using before? If you have increased the light output of the display then you'll inevitably see more artifacting. This can be a tradeoff.
THX is another very good option. Try contrast around 65 and brightness at 51. Undersaturate the color a few tics to 48.
cpcat is offline
post #284 of 1341 Old 12-14-2011, 03:56 PM
AGtastic's Avatar
Thanks. I was on FW 2.07. Cant remember what my exact settings were prior to this update but panel was always set to mid. After the update the main change I made to settings was to the grey scale and AGC. Also, I have to adjust dave_0's brightness setting to avoid some severe black crush. Brightness is now set around 65. I will apply the 2.2 update per justino's recommendation and see if there is a difference. I thought that 2.2 was only an internet app patch.
Thanks guys!
AGtastic is offline
post #285 of 1341 Old 12-14-2011, 09:28 PM
stang323's Avatar
Who uses 3D and what are your reviews on it?
stang323 is offline
post #286 of 1341 Old 12-15-2011, 10:17 AM
bmanlb's Avatar
I use 3D and now have about 10 movies. I like it! But usually there is only 1 or 2 pop-out scenes in a movie that will make you go wow! Everything else is about depth which is nice. Animated movies seem to shine more in this technology. I think "Tangled" and "Beauty and the Beast" are the best out my movies in this category. Disney is really taking a hold of this... But "Avatar" is by hands down the best 3D movie out of all of them, and perhaps the best movie out there period. A strong second is " Imax's Under the Sea" or "Deep Sea".....nice signature pop-out scenes in those. Sooo.... I like it! That is why I am asking if anyone has calibrated 3D settings.
bmanlb is offline
post #287 of 1341 Old 12-15-2011, 10:31 AM
Pop111's Avatar
New to the forum. I am having troubles updating my GT30. I have downloaded the zip file from Panasonic's site, however when I try to extract, windows can't find the program to open the file. Right now my set is saying the version is 2030. I'm curious if anyone has a solution to this. Thanks y'all!
Modified: DUR! figured it out. Trust me, I'm smarter than this
Pop111 is offline
post #288 of 1341 Old 12-15-2011, 12:29 PM
moxie1617's Avatar
For 3D settings I started with James Cameron's that were linked with the Avatar disc. Then I found Dave_O's settings and have been using them. If you decide to use Dave_O's settings, use a mid panel brightness set. With either Cameron's or Dave_O's settings I have to have the viewing room very dark even with the panel brughtness at mid.
moxie1617 is offline
post #289 of 1341 Old 12-15-2011, 02:33 PM
farahm2's Avatar
just got this TV, it's great! What settings should I have it at when I am wanting to break it in?
farahm2 is offline
post #290 of 1341 Old 12-15-2011, 07:31 PM
stang323's Avatar
What are the James Cameron's settings for.the gt30?
stang323 is offline
post #291 of 1341 Old 12-15-2011, 07:51 PM
moxie1617's Avatar
They are located here.
http://panasonic.net/avc/viera/3d/avatar/index.html
Use the settings for the GT25.
post #292 of 1341 Old 12-15-2011, 08:32 PM
stang323's Avatar
So does installing firmware and using the gt25 settings work? Aren't they different TV sets?
stang323 is offline
post #293 of 1341 Old 12-16-2011, 03:22 AM
ThePrisoner's Avatar
Quoted: 238 Post(s)
Liked: 163
I've been using Dave O's mid panel brightness settings also for 3D. Works great and I also watch in a dark environment.
Dolby Atmos/DTS:X 5.2.4
Samsung 65JS8500 (calibrated by Gregg Loewen); Marantz SR6010 + Onkyo M-5010; Oppo UDP-203; Apple TV (4th Gen); PS4; Definitive Technology BP-8060ST, CS-8060HD, SR-8040BP, Pro-Monitor 800; SVS PC-12NSD (2)
ThePrisoner is online now
post #294 of 1341 Old 12-16-2011, 06:19 AM
gpayne's Avatar
Great advice and settings in this thread. I really like Dave_O's settings with the firmware patch. Very much appreciated - thanks!
gpayne is offline
post #295 of 1341 Old 12-16-2011, 06:50 AM
cpcat's Avatar
Thanks guys!
This is a 65gt30 right?
Be sure you have black level set to "light" and HDMI settings to either auto or
Standard (16-235). Assuming that, and assuming there's not something else weird going on like a source related issue-- brightness at 65 is way too high. It should end up no more than 2 or 3 tics north or south of 50 either in Custom or THX mode.
cpcat is offline
post #296 of 1341 Old 12-16-2011, 07:04 AM
moxie1617's Avatar
They are different TV's, but like I said, I use Dave_O's settings now.
post #297 of 1341 Old 12-16-2011, 05:00 PM
AGtastic's Avatar
This is a 65gt30 August build. I turned the brightness down to around 52 and double checked those settings you mentioned, however on bluray via HDMI and OTA local HD, I still cannot make out the details in the darker areas of the image. The set is relatively new, ~2 months old with <100 hrs. (guessing here).
Thanks for the advice.
AGtastic is offline
post #298 of 1341 Old 12-16-2011, 07:22 PM
cpcat's Avatar
Some of the dark areas are meant to be shadows. In other words, you're not really supposed to see the detail and that's how it was meant to be viewed. If you (inaccurately) raise the brightness to see the details, you increase artifacting and even worse you raise the minimum luminance (black level) of the display. This means contrast ratio suffers and overall pq is reduced--the overall difference between black and whites are less.
The brightness control should be set where the dithering (sparkles) that you see in a 4:3 pillarbox black bar or letterbox black bar just goes away. You'll need to get up close to see this. Drop the brightness control a tic or two below this point. That's your minimum luminance of black. You can double check yourself by using a "pluge" test pattern on a test disc.
cpcat is offline
post #299 of 1341 Old 12-17-2011, 09:23 AM
rob316's Avatar
A request for Dave_O. Do you have any settings for 3D mode for the GT 30 or anyone else for that matter?. I use Dave's settings for regular mode.
rob316 is offline
post #300 of 1341 Old 12-17-2011, 10:29 AM
Dave_O's Avatar
Sorry, I do not.
Dave_O is offline
Panasonic Viera Tc P60gt30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Plasma Hdtv
