The Official Panasonic GT30 Settings Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
post #1291 of 1343 Old 10-19-2013, 09:02 AM
JForge's Avatar
Originally Posted by MiamiBourne View Post
The most recent comments suggest that you need to replace the screws as well with this kit: XYN3+F6FJ-18PK. Siting that the original screws eventually back out and that will cause the board(s) to fail.
Forgot to answer this question. Some have reported that the screws that hold the boards down to the chassis have been loose. Certainly that COULD cause a problem since it is the 'job' of the screw to ensure the 'ground' portion of the board gets connected to chassis ground.
When I opened my GT30, all screws were secure with none loose. All were shiny and looked new. If by chance in some extreme environment, the screw should oxidize, then all s/b replaced. In my case, all screws were re-used and securely tightened. If you look carefully, you should see that the screw makes the contact with the solder-pad and it gets slightly crushed when tightened properly.
Regards . . . Jim
GT30 "Custom" Settings: http://www.controlcal.com/forum/showpost.php?p=6392
GT30 "THX" Settings: http://www.controlcal.com/forum/showpost.php?p=6393
GT30 "Vivid" Settings: http://www.controlcal.com/forum/showpost.php?p=6402
JForge is offline
post #1292 of 1343 Old 10-20-2013, 11:54 AM
Noonin's Avatar
Quoted: 25 Post(s)
Just bought a new laptop and I know it can be connected via VGA, and possibly HDMI, but is there a way to connect wirelessly to my GT30 ala WiFi, or is WiFi only from the router? I have the TV running off the LAN from the router, so WiFi is open. Is Google ChromeCast a solution? Having trouble finding a WiDi card for my laptop, which is a Dell Latitude E6530. I also realize leaving webpages open with static images and borders is not the greatest for a plasma ;-).
Noonin is offline
post #1293 of 1343 Old 10-20-2013, 02:35 PM
Latinoheat's Avatar
Quoted: 1159 Post(s)
Liked: 962
If your tv has DNLA, you can view your videos, pictures and music wirelessly. If it does not than you can't. Also the only way to browse internet web pages on the big screen is to connect it HDMI or using other gadgets as the ChromeCast etc. VGA works also but HDMI will be better. Browsing web pages is not a problem for me, I do it all the time on my GT50. Hope this helps a bit.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #1294 of 1343 Old 10-20-2013, 02:57 PM
Noonin's Avatar
Quoted: 25 Post(s)
Thanks Latinoheat,
Looked at the WiDi solution a bit, and not prepared to spend that much for something I'm not sure I'll use a lot, and Chromecast features look limited (not set up to run regular PC programs). I think I'll try the HDMI option with a 15" Monoprice Ultraslim cable.
Do you find much lasting IR problem on your screen?
Noonin is offline
post #1295 of 1343 Old 10-20-2013, 03:11 PM
Latinoheat's Avatar
Liked: 962
Thanks Latinoheat,
I can honestly tell you No, I browse the net all the time using my HTPC. I constantly open document windows, listen to music, watch movies, tv shows, music videos, and game a little too. Never had a problem. I actually left a XBMC home screen on listening to a 3hr music mix and no IR. It had me a little worried but to my surprise it was fine.
post #1296 of 1343 Old 10-20-2013, 03:24 PM
Noonin's Avatar
Quoted: 25 Post(s)
Great to hear!
Noonin is offline
post #1297 of 1343 Old 10-21-2013, 03:17 PM
JForge's Avatar
========== SOLD ==========
I have two SCAN boards for sale: SU (upper) and SD (lower) boards for three (3) Panny models: P55VT/GT/ST30.
Both boards have been tested my me and are ready to go. Price reduced from $75.00 to $65.00. Picture shows the individual PNs.
They form the solution for the "7" blink problem along with an SC (Y-SUS) board.
Send email to: jforgione@prodigy.net
Regards . . . Jim
JForge is offline
post #1298 of 1343 Old 11-03-2013, 08:36 AM
JForge's Avatar
Here's a few interesting video links for Panny repair. The first is for the xxGT30 chassis so it's directly applicable.
http://www.youtube.com/watch?v=d2gJt8pLFWk
The video troubleshoots a TC-PxxGT30 that has failed with "7" blinks. It's good for general info for replacing the SC board. The drawback I see is that no mention of testing the SU and SD boards before replacing the SC board. As you read in my post (#1285), my SD board was also shorted so it COULD have blown the new SC board.
http://www.youtube.com/watch?v=5c_SyPv3GVs
Here's another TC-P50S30 chassis with 7 blinks. Note the slight difference in the boards. He replaced all of the Y ckt boards, a smart move IMO.
http://www.youtube.com/watch?v=ZS5vH2Q7RVY
This video shows the TC-42PC2 chassis. The SU + SU + SD are all on ONE board . . . Good video for general info.
http://www.youtube.com/watch?v=BY1bUbBcMH0
This one is included b/c it shows what NOT to do: remove ribbon cables from the SU/SD outputs while the TV is "hot" . . . with power on! That's a BIG no-no IMO!
I finally been able to get some decent white balance. New settings in my signature
Regards . . . Jim
JForge is offline
post #1299 of 1343 Old 11-10-2013, 12:43 PM
jlb32's Avatar
How high do you guys set your contrast in THX mode? I pretty much just use THX mode for everything and am pretty happy with it currently but wouldn't mind it being slightly brighter. Don't want to make it grainy looking though.
I have my contrast currently set at around 70. Brightness is around 50-54 on my settings. Do you guys increase your contrast before your brightness settings?
I know this has been talked about many many times but really don't feel like sifting through hundreds of posts looking for info so any input would be appreciated.
jlb32 is offline
post #1300 of 1343 Old 11-11-2013, 09:52 AM
JForge's Avatar
I guess the contrast and brightness settings depend on how well lighted your TV room is.
Personally, I prefer a lighted room so more contrast is needed. Also, I like some
'pop' to my HD video so both modes (Custom and THX) have more contrast than you might like or need.
Currently CUSTOM contrast, brightness settings are 82, 51 and THX settings are 81, 54 respectively.
Technically, one probably should check to see that you are not into "white-crush" with higher contrast levels.
Regards . . . Jim
JForge is offline
post #1301 of 1343 Old 11-18-2013, 12:05 AM
JForge's Avatar
I purchased a replacement HDTV for the bedroom last week, a Samsung 40” LED HDTV to mount on a shelf I constructed in the bedroom. The wall faces the bed so it’s provides a great view angle. Mounted the DTV box underneath and ran the wires up through a hole in the shelf.
I’ve read a lot of comments on how “good” the new LED HDTVs are, so now having one, I can comment on it vs my Panny 55” plasma HDTV. In short, THERE’S NO COMPARISON!!
Yes, it’s bright (depending on the setting chosen) but in terms of “picture quality and fidelity”, it falls very short. With a plasma, even one that is as difficult as mine (b/c of the ‘green’ drive), it still produces a more realistic video reproduction of the presented material.
It appears that LED TVs have a ‘bluish’ (magenta) cast (high red and blue drive) so it is extremely difficult to attain decent white balance. I was able to get “close” but nowhere as close as my plasma.
It’s acceptable for the bedroom and my wife loves it (previous was 25” screen) so she is happy. And you know what they say . . . happy wife, happy life! smile.gif
Regards . . . Jim
JForge is offline
post #1302 of 1343 Old 11-28-2013, 08:30 AM
jlb32's Avatar
Currently CUSTOM contrast, brightness settings are 85, 51 and THX settings are 83, 54 respectively.
Thank you. My set is non calibrated. I love THX mode and am just looking for the best settings people have found using THX mode for the GT30.
Seems some say to set the sharpness at 0.
jlb32 is offline
post #1303 of 1343 Old 12-06-2013, 08:24 PM
Sarlan19's Avatar
@JFORGE
Hi,
it seems like you are pretty good with a GT30 so I dare ask your help.
I'm trying to get my white in order for this set and can't quite manage it frown.gif
I'm running test patterns for blacks and white in XBMC and I can get the blacks flashing from 17 to 25 but I can't see the White flashing
from 230 and up.
also is it possible to post your settings it seems like controlcal as been down for a couple of days
Sarlan19
Sarlan19 is offline
post #1304 of 1343 Old 12-06-2013, 11:54 PM
JForge's Avatar
is it possible to post your settings it seems like control cal as been down for a couple of days
Sarlan19
Current settings are in my signature.
Regards . . . Jim
JForge is offline
post #1305 of 1343 Old 01-09-2014, 09:28 AM
JForge's Avatar
A few words on my 55GT30 . . .
Since the board replacement (SC +SU +SD), the TV's color balance has seemed to 'settle' down since the white balance (w/b) is now "almost" reference!!
If you have read this thread, I've had my share of difficulties getting a proper w/b and I've been able to use "Warm1" where before the 'best' w/b was only obtainable w/ "Normal" color temp.
My center channel speaker was placed on top of the audio cabinet (where the 'brown' colored box is now) but the sound was not as it should be. We all know that audio pros recommend that the center channel speaker is in-line with the tweeters in the main speakers.
The tweeters in the Klipsch ref speakers are positioned on the very top of the speaker (it's a "horn") and so I made a 'shelf' above the TV and mounted the center channel there as shown in the picture below. The tweeters from all speakers are now in the same plain.
Talk about different sound . . the front now seems more transparent and the sound now spreads across all of the speakers. The high freqs from the center channel were 'dead' but now are really well balanced. I'm certainly a believer. Always thought that it would be too high to mount a center speaker but it's not.
Another way of doing this (didn't try it!) is to turn the main speakers up-side-down and place the center channel were is formally was. That also should re-align the tweeters . . .
Regards . . . Jim
JForge is offline
post #1306 of 1343 Old 06-22-2014, 07:58 PM
deadwrong's Avatar
Just great, bought this GT30 on Dec 2011 and now I am already having an issue.
I turn on the TV and it the red light blinks 7 times! 7 blinks of death so I am told.
This is disgusting. Likely a board issue.
Anyone else on this thread go through this issue? Apparently if you haven't gotten it yet, its coming.
deadwrong is offline
post #1307 of 1343 Old 06-22-2014, 08:19 PM
JForge's Avatar
mr deadwrong . . . you obviously don't read . .
The 7 blinks of death is not that hard to fix! It referes to the SC board as the one that's failed. Also need to check the SU + SD boards.
My saga starts at post #1264; the key post is #1270. Suggest you d/l the PDF. All of the Panny blinks are explained.
And watch this video. .
Regards . . . Jim
JForge is offline
post #1308 of 1343 Old 09-14-2014, 02:09 AM
Elevatorguy's Avatar
JForge or anyone else following this thread. What are you using for your most current settings? I have 55GT30 and have been using settings I got here around 3 years ago. Lately, I have been noticing more and more green around/under actors eyes and around their mouths. I'm not sure if it is anything new or if I am just noticing it more. The settings I am using are regular adjustments, nothing done in the service menu. I have the set in a room that is bright during the day but dark at night. Thanks for all replies.
Elevatorguy is offline
post #1309 of 1343 Old 09-14-2014, 04:37 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
The white balance is wonky in custom mode mid (HDMI/OFF) and they use an unorthodox gamma as well.
I got good results calibrating with a colormunki display and HCFR by bringing all W/B High to their lowest points aka desaturate the picture to reduce the weird anomalies in facial and skintones.
Custom Mode Mid...
72
53
47
0
25
Color Space Wide
High
R - -50
G - -43
B - -27
Lows
R - +4
G - 0
B - -1
All enhancements off...
You can bring the contrast to 78 to give you 40 FTL plus...
PeterLewis is offline
post #1310 of 1343 Old 09-14-2014, 09:53 PM
JForge's Avatar
My current settings are in my signature; I use the "CUSTOM" mode but sometimes change to "THX".
I had problems with my 55GT30 from the get-go and finally, about 14 months after it was first turned on, it went "boom" (starting at post #1281 ).
After it was repaired, the TV produces "almost" reference quality so all of the troubles were due to poor quality video cards.
The settings in my signature are current and don't need any Service Menu "tweaks". The "THX" settings produce really good video.
Regards . . . Jim
JForge is offline
post #1311 of 1343 Old 09-14-2014, 10:05 PM
PeterLewis and JForge thank you both for your replies and settings. I will try them all out and see which works best. Take care.
post #1312 of 1343 Old 12-29-2014, 10:36 AM
NicGordon's Avatar
Liked: 0
Here's hoping JForge or someone with a similar experience sees this post.
My 55" GT30 just recently stopped working and is giving the 7-blinks indicating I likely need to replace the SC, SD, & SU boards in my set. Do you have any recommendations as to where I can source new boards, or have mine repaired? Thanks for any help you may be able to provide.
NicGordon is offline
post #1313 of 1343 Old 12-29-2014, 05:01 PM
JForge's Avatar
The '7' infamous blinks of death!!!
The good news is that you can replace the boards (SC + SD + SU) and get the "smile" back again.
It's been about 1-1/2 years or so since mine died but after repair, the picture is better than it ever was even when it was brand new!
I bought my boards from the Internet by doing a search so do one and see what you find.
The following search shows a lot of Panny boards:
http://www.ebay.com/bhp/panasonic-sc-board
I'm sure you'll find replacements. Let me know how it goes . . .
Regards . . . Jim
JForge is offline
post #1314 of 1343 Old 12-29-2014, 05:20 PM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
I've heard people talk about shopjimmy.com for tv parts.
whipit is offline
post #1315 of 1343 Old 12-30-2014, 03:08 PM
ggsantafe's Avatar
Quoted: 222 Post(s)
Liked: 176
Back in late August we had a nearby lightning strike that wiped out the HDMI Board on my GT 30!- I looked on the Panasonic website and located an authorized repair shop near my house. While the unit was no longer under warranty, the shop was able to install a new board- I think it cost about $350, it's as good as new, if not better. While I was waiting for the repair to be completed, I tested a Samsung F5300 plasma from BestBuy that was on sale for $547 - while it was decent (no 3D or "smart" features) I still felt it made sense to restore the GT 30. Good luck with your repair!
ggsantafe is offline
post #1316 of 1343 Old 12-30-2014, 04:12 PM
NicGordon's Avatar
Liked: 0
Thanks everyone for the quick response. Most places are out of stock on even refurb units, and I'm leary of fleabay. I found a lot of good info in this thread too:
Panasonic VT30 Plasma - 7 Blinks + Picture Issues
Several people there had good luck with ModusLink PTS. They offer a repair and return service package for like $200. You send them your SC, SD, SU, and SS boards. They test them, repair if necessary, and return them to you. So I may try that route. The biggest challenge apparently is getting all the ribbon cables seated properly in the SU/SD boards.
post #1317 of 1343 Old 12-30-2014, 04:14 PM
NicGordon's Avatar
Liked: 0
Oh, and it's recommended to also install the new screws that have lock washers.
Panasonic part# is: XYN3+F6FJ-18PK
and they are available direct from Panasonic at their Encompass parts website for like $10
Link: https://panasonic.encompass.com/item...tand_Screw_Kit
post #1318 of 1343 Old 12-30-2014, 11:11 PM
JForge's Avatar
Never heard of "ModusLink PTS" but checking them out, that looks to be a good solution. If it's $200, the price is definitely right!
I bought my boards from Ebay . . all worked perfectly as they were "pulls" from non-working TVs. If you read my writeup, you can check the boards very easily with an ohmmeter. In other words, you can be sure in advance which boards are bad and only have them repaired.
The new screws won't hurt but they are not needed.
When you disassemble the TV, pay attention to how the cables are seated. The trick is to make sure that the 'clip' that locks the cable, is fully open. When you seat the cable, make sure it goes all the way in.
You DON'T need the SS board only the SC + SU + SD boards for "7" blinks.
Let us know what happens.
Regards . . . Jim
JForge is offline
post #1319 of 1343 Old 12-30-2014, 11:30 PM
NicGordon's Avatar
Liked: 0
I'll post back when it's all done, or sooner if I have problems. Thanks for all your help Jim.
post #1320 of 1343 Old 12-31-2014, 06:42 AM
DR.DTS's Avatar
Quoted: 25 Post(s)
Our faithful and trusty 55" GT30 died a little over a week ago with the "Dreaded 7 Red Blinks of Death". I searched around for hints and clues as to the cause and what to look for. I found references to the 'SD & SU" boards and ShopJimmy was always mentioned as a go-to site for the boards. however when I looked up what I needed about every board for the GT30 series was showing Out of Stock and B/O.
We ended up getting a Sony projector but the Panny Plasma is tucked away for now until I figure out which boards to replace, cost and when. The set produced a heck-of-a-picture and I'm not parting ways with so easily So to clarify I need...
SD + SU + SC Boards correct?
Where besides ShopJimmy if they still don't have them? I'm in no rush right now but I don't deal with E-bay anymore Does Panasonic not stock or carry these anymore? Thanks
Kenny J
DR.DTS is offline
Panasonic Viera Tc P60gt30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Plasma Hdtv
