The Official Panasonic GT30 Settings Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 1341 Old 12-02-2011, 04:13 AM
ped
ped's Avatar
Originally Posted by Audiophile@Birth View Post
I too would also like to know this!
I just installed 2.1 via the link posted by the other member. Now I am about to put 2.2 back on. Will it over ride the professional patch??
You can install 2.2 over 2.1 with no issues, the luminance patch portion of 2.1 is retained.
ped is offline
post #212 of 1341 Old 12-02-2011, 10:44 AM
jagz5586's Avatar
I just got my Gt30 and it has a april build date does the 2.1 professional patch also fix Fluctuating Brightness or do I need to get a Panny tech guy to come by
jagz5586 is offline
post #213 of 1341 Old 12-02-2011, 11:05 AM
FantaXP7's Avatar
Quoted: 44 Post(s)
Liked: 38
Panny tech guy.
FantaXP7 is offline
post #214 of 1341 Old 12-02-2011, 11:52 AM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1320
Where did you purchase it?
DavidHir is online now
post #215 of 1341 Old 12-02-2011, 12:23 PM
jagz5586's Avatar
Thanks for the quick reply
I Bought it of Amazon My areas best buy does not carry the gt30.
So I figured I would have a 50/50 shot of getting a august build but I didn't
Now the Panny customer service said it might take anywhere from a week to a month to get someone out to my house. I wish the Fix was available online but I guess Ill just run the slides until the Tech guy gets here
jagz5586 is offline
post #216 of 1341 Old 12-02-2011, 12:31 PM
justinto's Avatar
Quoted: 22 Post(s)
Did both the 2.1 then did the 2.2 firmware updates. The 2.1 update did the trick. Flesh tones are no longer too intense and look real while the rest of the picture also looks good.
Justin
LG OLED 65B6P; LG OLED 55B6P
Denon x4200W; (2)
Aperion Verus Grand Speakers
justinto is offline
post #217 of 1341 Old 12-02-2011, 06:35 PM
J0HNNY H0PK1NS's Avatar
Can someone either post stock/factorySM Offsets
R-DRV: ?
G-DRV: ?
B-DRV: ?
R-CUT: ?
G-CUT: ?
B-CUT: ?
Original values were stored in my computer and something went wrong. If stock/factory is not known because all panels are allegedly all "unique" then possibly more of a recommendation for these so I can adjust from there? Settings are currently F-d and I'm no NOOB at this. Just asking for a little assistance. Thanks in advance
Everything else < Kuro PLASMA
J0HNNY H0PK1NS is offline
post #218 of 1341 Old 12-02-2011, 07:18 PM
rob316's Avatar
Between the 2.1 firmware patch and Dave_O's mid panel settings not only does 2D look awesome, so does 3D. I was watching Toy Story 3 off my cable provider Comcast and the picture was amazing, I was completley immersed into the picture. I am so glad I bought this tv, and also glad that I am a member of this forum. Throughout the years, this forum has been invaluable to me when it comes to HT.
rob316 is offline
post #219 of 1341 Old 12-02-2011, 10:16 PM
Wermey's Avatar
R-DRV: ?
G-DRV: ?
B-DRV: ?
R-CUT: ?
G-CUT: ?
B-CUT: ?
Play some SD content and then go into your sm offsets, they should be untouched, copy those settings down, and then play some hd content, and enter your sm offsets from your sd source into your hd source and you should be good to go, SD and HD offsets are the same, but when you change one, you dont change the other, so you should be safe there.
Wermey is offline
post #220 of 1341 Old 12-03-2011, 02:01 PM
Dave_O's Avatar
Applied the Custom 2.1 FW today. Measured THX and Custom low panel and high panel brightness on GT30 pre and post the 2.1 FW upgrade. No significant change to THX and low panel measurements. Mid panel brightness did change quite a bit, with the major change being that minimal Gamut Luminance errors now occurred at Color setting of 49 instead of 46. The WB settings also needed a re calibration. As stated before, no improvement to Gamma in Mid Panel brightness was noted.
Dave_O is offline
post #221 of 1341 Old 12-03-2011, 02:03 PM
gadianton's Avatar
So for for a noob, is it worth installing that update?
gadianton is offline
post #222 of 1341 Old 12-03-2011, 02:30 PM
Dave_O's Avatar
If you use THX mode, which is very good, I'd say no.
If you use custom mode with low panel brightness, I'd say no.
If you use custom mode with mid or high panel brightness, and will calibrate the set, I'd say yes.
Most folks who have applied the patch comment that the set looks significantly better. I firmly believe that measurements are just a baseline for video quality, and do not tell the full story. I cannot believe that very experienced calibrators and Panasonic video engineers would have worked this hard just to have the set look good at a color setting of 49 instead of 46
Dave_O is offline
post #223 of 1341 Old 12-03-2011, 02:37 PM
Dave_O's Avatar
Here are settings for the GT30 with Panel Brightness set to Mid Level after applying the Custom 2.1 Firmware.
Date 12/3/2011
Picture Mode Custom
Temperature Warm2
Panel Brightness Mid
Contrast 80
Brightness 50
Sharpness 25
Color 49
Tint 0
Gamma 2.2
Black extension 0
Color management Off
Video NR Off
Contour emphasis Off
CATS Off
AGC 0
Block NR Off
Mosquito NR Off
Motion smoother Off
Black Level Light
Grayscale
High R -1
High G 0
High B 3
Low R 0
Low G 0
Low B -1
Measured Luminance is 44 FL, but is really about 54 FL per D-Nice's conversion factor for 2011 Panasonic Plasmas
Best custom Calibration -Mid Brightness, after custom FW 2.1.pdf 258.748046875k . file
File Type: pdf Best custom Calibration -Mid Brightness, after custom FW 2.1.pdf (258.7 KB, 197 views)
Dave_O is offline
post #224 of 1341 Old 12-03-2011, 03:24 PM
ggsantafe's Avatar
Quoted: 194 Post(s)
Liked: 162
Thanks for the updated settings for the Luminance Patch. Just input your corrected version - watching the Georgia - LSU game & boosted the W/B LowG to +10 to make the Georgia Dome turf palatable! May revise once I've had an opportunity to view additional content. Nice work - much appreciated!
I did revert back to your 0 suggested setting - looks like CBS made some adjustment during the broadcast & the fairways & putting greens looked just right at 0 as well during the Chevron Invitational.
ggsantafe is offline
post #225 of 1341 Old 12-03-2011, 04:10 PM
ped
ped's Avatar
Hi Dave,
Do you have a link to this info and discussion?
ped is offline
post #226 of 1341 Old 12-03-2011, 04:14 PM
stang323's Avatar
Recalibration for 3D
Is this normal?
THX contrast 60 brightness 50
THX 3D contrast 40 brightness 60
Both done at night viewing with DVE bluray
Do you guys use different calibration when watching 3D vs non 3D ?
Help guys! I'm bringing my GF tonight to check it out and want to impress her lol
stang323 is offline
post #227 of 1341 Old 12-03-2011, 05:05 PM
rob316's Avatar
Is this normal?
You rock Dave
rob316 is offline
post #228 of 1341 Old 12-03-2011, 05:14 PM
Dave_O's Avatar
Originally Posted by ped View Post
Hi Dave,
This forum blocks the exact URL of the 'other' forum. Remove the * from this URL to get the post.
http://www.high*defj*unkies.com/show...l=1#post290107
Dave_O is offline
post #229 of 1341 Old 12-03-2011, 06:08 PM
Scott101's Avatar
Hi,
Wondering if someone could answer a few questions….
I have a GT30 set and ran the 100 hour panel prep. I also ran D-Nice’s calibration and applied his settings for the THX mode. I have had the set for about 2 months.
- If I apply this 2.1 firmware, will it make the THX picture better, worse or will it remain the same?
- Would I have to change any of the SM vales for the THX mode after this firmware is applied?
- Would I have to change any of the picture settings for the THX mode after this firmware is applied?
- Should I apply the 2.2 firmware after 2.1?
I do enjoy the THX picture for movies (2d/3d) but would like custom settings for sports. As it stands now, I cannot get the custom picture settings right for watching tv/sports. I find the THX mode a little dark for TV viewing.
Thanks in advance.
Scott101 is offline
post #230 of 1341 Old 12-03-2011, 06:31 PM
umeweall's Avatar
Originally Posted by A-Gon View Post
Quite frankly, I've used settings posted here and a few other sites. Never really cared for any of them. What I see in THX mode is more than pleasing to my eye.
My panel is wall mounted, the room receives light from 2 separate outside sources. I keep my mount tilted slightly downward, so reflection is not an issue. Viewing the TV during the day has never been a problem and with the slight downward title of the panel it's even more of a non-issue. Having it be THX certified is one of the main reasons why I purchased the GT30. I want to watch my TV, not spend countless hours screwing around with the settings. Just my $.02.
I agree. For viewing, I believe that what is acceptable for one person might not necessarily be good for another person. This is based primarily on what the person likes to see, and where the set is placed for viewing (light vs. dark areas). I plan to have my set calibrated by BB, which offers the service.
umeweall is offline
post #231 of 1341 Old 12-03-2011, 06:47 PM
ken325i's Avatar
Date 12/3/2011
Picture Mode Custom
Temperature Warm2
Contrast 80
Brightness 50
Sharpness 25
Color 49
Tint 0
Gamma 2.2
Black extension 0
Video NR Off
CATS Off
AGC 0
Block NR Off
Mosquito NR Off
Motion smoother Off
Black Level Light
Grayscale
High R -1
High G 0
High B 3
Low R 0
Low G 0
Low B -1
Great settings! Changed while watching the SEC championship, and was very pleased! Great work!
Ken
ken325i is offline
post #232 of 1341 Old 12-03-2011, 08:37 PM
jerome8283's Avatar
If the GT30 is unplugged from an electrical outlet will it retain settings for some pre-determined time?
jerome8283 is offline
post #233 of 1341 Old 12-03-2011, 09:11 PM
wondervamp's Avatar
Hey Ken, is this for TXH settings or Custom? Thanks
Originally Posted by ken325i View Post
Installed the 2.1 patch........and I am very pleased! Color saturation issues are dramatically improved and total picture quality has taken a giant step forward. I would recommend all to install this upgrade. Not oly are skin tones improved, but (to my eye) the whole color gamut is improved. MID now has a more natural picture, yet still has pop -- which is missing in THX. I am very pleased with the changes!
Ken
wondervamp is offline
post #234 of 1341 Old 12-04-2011, 04:29 AM
ken325i's Avatar
custom
ken325i is offline
post #235 of 1341 Old 12-04-2011, 10:27 AM
Dave_O's Avatar
With a bit of further analysis, it now seems that the 2.1 FW does improve THX mode in a way that may make it a perfect fit for folks without plans to calibrate. With past measurements on my set, trying to get more brightness in THX mode by moving the Contrast to 75 resulted in a degraded Gamma at high IRE. After FW 2.1, this is much less. It provides a 46FL measured (56 FL with D-Nice's correction).
I noticed changes in THX mode after 2.1, but at default settings they were not significant enough to mention.
For rooms with dim lighting, the Custom settings for Low panel brightness provide better results than THX, with lower light output that works well in those environments.
For folks wanting higher light output, using the 2.1 patch with THX Contrast at 75 and Color bumped down to 48 or 49 is a great option.
Gotchaa, based on your knowledge of the 2.1 FW does this make sense?
THX Default after 2.1 - High Contrast.pdf 257.005859375k . file
File Type: pdf THX Default after 2.1 - High Contrast.pdf (257.0 KB, 95 views)
Dave_O is offline
post #236 of 1341 Old 12-04-2011, 01:06 PM
FantaXP7's Avatar
Quoted: 44 Post(s)
Liked: 38
These Dave O settings are starting to grow on me. I threw them on for the football today and they look fantastic. I think I may use THX mode for movies and Dave O for live tv.
FantaXP7 is offline
post #237 of 1341 Old 12-04-2011, 03:41 PM
ken325i's Avatar
This is the best my 50GT30 has looked since I got it. Thks to Dave O for his tim and calibration reports/settings! I really enjoy college/pro football, and the colors are the best/most natural. And the 2.1 patch has eliminated the red/brown push (red faces). I still believe my 42PX600U is better, even at 720P. But at least the GT30 has gotten to an acceptable level.
I think Panasonic fell very short in 2011.....and maybe all plasma's - they seem to really be falling short. Compared to 4 years ago, price is down, but quality/performance seems to be as well. It seems they are want to "just get by".
Anyone hear about the Samsung 55" OLED announcement??
Ken
ken325i is offline
post #238 of 1341 Old 12-04-2011, 05:03 PM
stang323's Avatar
Can someone share their 3D settings? I'm trying to get best pic
stang323 is offline
post #239 of 1341 Old 12-04-2011, 09:07 PM
entrer1's Avatar
I downloaded the new 2.1 patch and did Daves mid pannel settings and this has given me the best picture I have ever seen on any TV I have ever owned. The only problem I am having is on my Xbox 360 for games like battlefield 3 the shadow detail is too dark along with the enemy's to the point I can not see anything. I have tried several settings and am about to pull my hair out, lol. Had to hook my Xbox back up to my LCD computer monitor to get my kd ratio back in the positives :-) . does anyone have any suggestions to brighten things up? I am using game mode btw.
entrer1 is offline
post #240 of 1341 Old 12-04-2011, 10:06 PM
Ferrinbonn's Avatar
Can't you adjust your gamma in game (not on the TV) in the display settings?
Ferrinbonn is offline
Panasonic Viera Tc P60gt30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Plasma Hdtv
