Cracked screen on Samsung plasma - AVS Forum | Home Theater Discussions And Reviews
Old 07-22-2011, 11:18 AM - Thread Starter
tcraig72's Avatar
I just found a huge crack in my plasma screen. Its a 2010 PN50b860. Am I SOL? Are there any do-it-yourself options I can try? The repair tech. Said it wouldn't be worth the repair price. Please help!
tcraig72 is offline
Old 07-22-2011, 12:09 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
How did the crack get there? There are dozens of reports from owners where their Samsung panel spontaneously cracked on it's own while watching TV.
Is it still under the manufacturer's warranty? If so, file a claim, If it's beyond the one year warranty, did you buy it using a credit card that adds one year to the manufacturer warranty? If not, and you're on the hook for repairs, then the tech is correct in that it's not worth the expense to have the panel replaced.
PS: This thread might be relevant:
http://www.avsforum.com/avs-vb/showthread.php?t=1348871
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 07-22-2011, 12:47 PM
schan1269's Avatar
Yep...
"spontaneously cracking Samsung plasma" is all over the internet now. Samsung will do everything in their power to say "your fault" on it.
Hope you have an extended warranty.
schan1269 is offline
