Annoying picture issue with my Philips plasma HDTV? - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2011, 06:36 PM - Thread Starter
stizo900's Avatar
I am having a very annoying issue with my Philips 42PFP5332D/37 where the HD picture is very distorted. It almost looks like all the black in the picture is substituted with white or something. This happens using both component and HDMI using any input source. It has happened with my Xbox 360, PS3, Blu-Ray Player, and my MacBook. Whenever I set the output to a resolution of 1024x768 (the TV's native resolution) or higher, the picture and color becomes distorted/inverted. But the thing is, it's fine in 480p! I would like to know if anyone else has seen this problem, knows of the source of the issue, or has a solution to the problem. Thanks.
480p: Attachment 218367
Attachment 218370
720p: Attachment 218368
1080i: Attachment 218369
stizo900 is offline
Old 07-25-2011, 07:22 PM
74f100's Avatar
Have you checked firmware version?
That would be the first check.
If it varies by resolution it has to be in either the SSB or "possibly" the logic pcb.
Jim
74f100 is offline
Old 07-26-2011, 03:25 PM - Thread Starter
stizo900's Avatar
Thanks for the reply! Anyway, I currently have the latest firmware version. I am trying to find a solution that doesn't involve replacing my logic board. I have already had to do that once, and I can't afford to pay for another replacement.
stizo900 is offline
Old 07-26-2011, 05:09 PM
surap's Avatar
Are you shure it is a plasma-TV?
surap is offline
Old 07-26-2011, 06:29 PM
MikeBiker's Avatar
Quoted: 12 Post(s)
It's this set.
MikeBiker is offline
Old 07-27-2011, 04:22 PM
74f100's Avatar
LCD's during that time used PFL in the model, Plasmas used PFP.
74f100 is offline
Old 07-27-2011, 11:18 PM - Thread Starter
stizo900's Avatar
@mikebiker yes it is that set. Definitely a plasma
stizo900 is offline
Old 07-28-2011, 02:58 AM
surap's Avatar
Can it be issues with the bit-depht of the source? 24 vs 36? If I remember correctly, it is possible to change the bit-depth(color) on PS3.
surap is offline
