Samsung Aspect Ratio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-20-2011, 07:05 PM - Thread Starter
Toested's Avatar
I have a Samsung PN63C8000 plasma. I am having a weird problem when trying to view widescreen, non-anamorphic DVDs in either my Samsung BD-C5900 or my PS3. When fiddling with the Aspect Ratio from 16:9, Wide, 4:3, Fit, etc... No matter what, I can not get the right aspect for the movie I am watching. Both devices are connected to HDMI. Some movies, for example:
The Abyss
Star Trek Generations
If you have any suggestions, please let me know.
Thank you,
Michael
Toested is offline
post #2 of 4 Old 08-21-2011, 01:27 AM
Cypherus21's Avatar
The Abyss
Thank you,
Michael
Seems like either your Blu ray player, DVD player, or PVR is not set at 16x9 aspect ratio within the settings menu.
Cypherus21 is offline
post #3 of 4 Old 08-21-2011, 06:23 AM
BillP's Avatar
Quoted: 221 Post(s)
Liked: 169
Not sure what you mean. Many movies are shot wider than 16:9, and thus have black bars on the top and bottom (it's normal). Is that what you mean?
BillP is offline
post #4 of 4 Old 08-21-2011, 09:00 AM
jdcrox's Avatar
Quoted: 74 Post(s)
Liked: 99
With a non-anamorphic DVD, you will have black bars on all 4 sides of the image, this is also known as "window-boxing", as opposed to "letter-boxing", which will have bars on only the top and bottom.
The only solution I know of is to zoom the image in.
What happens is that the DVD is a 4:3 image, with a widescreen movie letter-boxed in side it. Hence the bars on both sides and top/bottom.
jdcrox is offline
taboola here
