Two game related questions from a new plasma owner - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2011, 02:45 PM - Thread Starter
Amphion's Avatar
Hi, I just bought a 50GT30 and I have two questions:
1) for the 360, which is the recommended Reference Level to use, Standard, Intermediate or Expanded?
2) How do I save individual picture settings for separate sources? For example I want my game mode to be brighter on my 360 source than on my PS3 source, but every time I adjust one, the other is adjusted also. Doesn't the GT30 have this option? I thought all TVs do now.
Amphion is offline
Old 09-24-2011, 09:52 PM
Dathon's Avatar
1. Expanded is what you want for deep blacks.But you need to also calibrate the tv properly to ensure you dont end up with crushed blacks. The standard mode sets black level to IRE 16, which would give you a dark grey color for black, depending how you calibrate the set. switch the modes back and forth. you will see the colors getting deeper when you choose expanded. just make sure you calibrate.
Dathon is offline
Old 09-24-2011, 09:53 PM
all clear's Avatar
Quoted: 166 Post(s)
Liked: 69
expanded will give you black crush..just try it and see if it works with you
all clear is offline
Old 09-25-2011, 09:00 AM - Thread Starter
Amphion's Avatar
ok, thanks guys. What about this question, can anyone answer this please?
Amphion is offline
Old 09-25-2011, 03:52 PM
elmalloc's Avatar
Quoted: 101 Post(s)
Liked: 73
if you do expanded then your TV should also be set to full/expnaded
Current projects:
IN PROGRESS (50%) - Theater room (Sim2 HT380, CIH 14ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Coming soon:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
Old 09-25-2011, 05:02 PM
Dathon's Avatar
Yes, as long as you set the TV and XBOX both to the same level, then there wont be any crushed blacks. everything will look fine as long as you calibrate afterwards.
Dathon is offline
