Resetting Trap Switch on Pioneer plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-04-2011, 01:31 PM - Thread Starter
DigitalKnight's Avatar
Buddy of mine took cover off back of his PIONEER KURO PDP-LX608G and now needs to reset it.
I did find these instructions:
1. Press the display button then release the display button.
2. Wait between 3 and 7 seconds
3. Press and release the <, ^, <, >, and power buttons in sequence.
Panel will now turn on in service mode.
4. Press muting button 3, 4 or 5 times depending on model you are working on.
Until the display shows the initialize page.
5. Press and hold the display button until the error indicator (red LED) on
either the panel or the media receiver goes out.
6. Exit service mode by pressing the power button on the remote.
But they are for a PDP-5050sx
Is it the same for all Pioneer plasma sets?
_DK
DigitalKnight is offline
post #2 of 10 Old 10-04-2011, 02:01 PM
EG3
EG3's Avatar
Never heard of that model.
Try the procedure and see.
The procedure should work from G3-G8 models.
EG3 is offline
post #3 of 10 Old 10-04-2011, 03:56 PM - Thread Starter
Thanks, I will have him try it after he replaces the power supply in the unit.
post #4 of 10 Old 10-04-2011, 11:06 PM
Jin-X's Avatar
That's nuts, I just came in here to ask about this. I have a 4280 and it turned out the fan was not working and that's why it wouldn't work properly, but then the dreaded trap switch thing came up.
Jin-X is offline
post #5 of 10 Old 01-08-2013, 08:06 AM
sjpurdy's Avatar
Works with a PDP-4270HD.
Thank you very much for the post
sjpurdy is offline
post #6 of 10 Old 02-02-2013, 01:22 PM
DWills1972's Avatar
Thanks so much for the reset code! I just used it on a pioneer pdp-4340 plasma and it worked!
I had bought a new power supply, but that seemed to give the same problem as the old. It turns out that the only problem was the physical on/off button. I didn't know how to fix that, so I just jumped it (cut the wires and connected them permanently). I can only switch off to standby mode, but at least now the tv works and except for the shipping to return the un-needed power supply, it was a free fix. smile.gifbiggrin.gif
DWills1972 is offline
post #7 of 10 Old 02-02-2013, 06:48 PM
feedxyzok's Avatar
yeah,me too,Thanks so much for the reset code! I just used it on a pioneer pdp-4340 plasma and it worked! 10.gif
feedxyzok is offline
post #8 of 10 Old 07-04-2013, 08:14 AM
DoomBot's Avatar
Where is the trap switch on a pioneer pro-506pu and does anyone have the service manual for this?
DoomBot is offline
post #9 of 10 Old 10-01-2014, 05:52 AM
cggoldens's Avatar
Originally Posted by DigitalKnight View Post
Buddy of mine took cover off back of his PIONEER KURO PDP-LX608G and now needs to reset it.<br><br>
I did find these instructions:<br><br><br>
1. Press the display button then release the display button.<br>
2. Wait between 3 and 7 seconds<br>
3. Press and release the &lt;, ^, &lt;, &gt;, and power buttons in sequence.<br><br>
Panel will now turn on in service mode.<br>
4. Press muting button 3, 4 or 5 times depending on model you are working on.<br>
Until the display shows the initialize page.<br>
5. Press and hold the display button until the error indicator (red LED) on<br>
either the panel or the media receiver goes out.<br>
6. Exit service mode by pressing the power button on the remote.<br><br>
But they are for a PDP-5050sx<br><br>
Is it the same for all Pioneer plasma sets?<br><br>
Thanks,<br><br>
_DK
Thanks DK,
Don't know what caused my problem, but your suggestion fixed things. I was ready to buy a new TV, figured a repair to a set this old isn't worth it. Working just great now (but I think I should start doing some research into new TVs).
Willi
cggoldens is offline
post #10 of 10 Old 04-01-2015, 01:15 PM
josephmama's Avatar
Originally Posted by DWills1972 View Post
Thanks so much for the reset code! I just used it on a pioneer pdp-4340 plasma and it worked!<br><br>
I had bought a new power supply, but that seemed to give the same problem as the old. It turns out that the only problem was the physical on/off button. I didn't know how to fix that, so I just jumped it (cut the wires and connected them permanently). I can only switch off to standby mode, but at least now the tv works and except for the shipping to return the un-needed power supply, it was a free fix. <img alt="smile.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/smile.gif"><img alt="biggrin.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/biggrin.gif">
DWills,
How did you jump the on/off switch? I had a power supply failure and then swapped that out (the first replacement didn't work, and then on the second board i accidentally tripped the switch). Now when I try to restore using the above sequence I still only get a blinking standby light so I'm wondering if that is my issue too? It's an old pioneer that has worked great until now, pdp-433pu. Thanks
Mike
josephmama is offline
