Official 2011 Panasonic Settings/Issues Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 12-13-2011, 03:14 PM
dherrick's Avatar
Originally Posted by tcc View Post
Thanks dherrick. Interesting that you got that prompt since that hasn't happened to me yet.
When I check via the tv to see if there's an update it says there is (2.200 I think) yet when I got on to Panasonic's site I don't see it. do you have a link?
tia
Here is the link to ver 2.200
http://panasonic.jp/support/global/c.../down_na1.html
dherrick is offline
Old 12-13-2011, 04:24 PM
mapesaudio's Avatar
Originally Posted by D-Nice View Post
My GT settings do not tell you to change your G Drive setting to 0. My GT settings are offsets not absolute values. -6 means to reduce whatever your R Drive value is by six.
Guys please make sure you fully understand how to input my settings before attempting to do so.
Just completed 100 hour slide breakin, moving on to second step, I will be using your settings for my Eprom updated MJ VT30.
I realize I will be making these changes in the user menu, and want to be sure that each number I enter will be as it appears, for example,10 point W/B 10W/B R:-5, I will enter it as -5 and not as a reduction of a given number, or am I misunderstanding this?
Mark C. (mapesaudio)
Mark C.
mapesaudio is offline
Old 12-13-2011, 04:33 PM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
For the VT30, all settings start at 0, so moving to +5 or -5 is very easy. There are a lot of settings to change! It took me about 30 minutes to make all the changes for all 4 HDMI inputs (I obviously spent more time on the 1st HDMI input than the others, figuring it all out, since they are not in the same order in the menu as listed in p. 1 of this thread).
BillP is offline
Old 12-13-2011, 05:00 PM
mapesaudio's Avatar
Thank you. I didn't realize that they are in a different order, thanks again for the heads up.
mapesaudio
Mark C.
Old 12-13-2011, 08:05 PM
musicmafia's Avatar
hey everybody, just ordered my 55VT30 and had a couple questions about the slides, break-in etc.
when i plug in the usb drive containing the slides, will they appear on screen and start playing automatically or will i have to choose the usb input and locate a setting to play a slideshow?
more importantly, do i need to change any settings or make any adjustments or choose any certain modes BEFORE playing the slides or just play the slides in the default mode?
after playing the slides, it appears the settings are based on eprom or non-eprom. i dont know what that is and how will i know which to use?
thanks
musicmafia is offline
Old 12-13-2011, 10:45 PM
tcc
tcc's Avatar
Thanks. I was able to update it via ethernet using powerline devices
.......*edit* ok, another question Being a noob and not wanting to fubar the TV, how do I go about adjusting the w/b, gamma, and cms once I get into the service menu?
tia
Anyone??
tcc is offline
Old 12-14-2011, 06:27 AM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
tcc, in all honesty, if you don't know what you are doing in the SM, don't go there. You can very easily ruin your display. I love that on the ST30 and VT30, you don't have to go into the SM.
BillP is offline
Old 12-14-2011, 08:21 AM
tcc
tcc's Avatar
Fair enough but I would just like to know how to navigate to the different sections as mentioned in the SM.
So there is no need to go into the SM to input D-Nice's values after running the slides? If so I cannot find the w/b, gamma, and cms settings as outlined.
tcc is offline
Old 12-14-2011, 09:15 AM
superstein61's Avatar
Originally Posted by moshock View Post
D-Nice... Any way we could get you to calibrate an ST30 on Mid Panel Brightness to the best of your ability?
And yes, I already know it won't be as accurate as your existing settings... But I'll try anything to get my 60ST30 brighter... it's just soooo daarrrrkkk..
But I guarantee dozens from this board would really, really appreciate it! And others at HDJ, and lurkers around the world...
+1 - The settings are great but it is too darn dark
superstein61 is offline
Old 12-14-2011, 12:34 PM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
With the ST30 and VT30, yes, you can input all of D-Nice's settings in the User Menu (including Pro settings) in Custom mode, without going into the SM. For the GT30, you need to go into the SM.
BillP is offline
Old 12-14-2011, 01:09 PM
DavidHir's Avatar
Quoted: 1725 Post(s)
Liked: 1335
To calibrate the ST30's Cinema mode's grayscale, individual color points, and gamma, are there service menu controls for those?
DavidHir is online now
Old 12-14-2011, 01:19 PM
mark62's Avatar
Liked: 88
im quite sure you can adjust those settings in the SM.
mark62 is offline
Old 12-14-2011, 02:21 PM
donnymac51's Avatar
SM controls only for the grayscale.
Precision Video Calibrations
THX Certified Video Calibrator
Calibrating Florida and Georgia
donnymac51 is offline
Old 12-14-2011, 02:32 PM
DavidHir's Avatar
Liked: 1335
Interesting. I've seen mixed reports on Custom mode for calibration. Any preference with this vs Cinema mode?
Old 12-14-2011, 03:55 PM
mapesaudio's Avatar
Help, anyone!
Just started to set up my VT30 after breakin slides. I'm thoroughly confused. Do I need to go into the SM for some of these settings, (dnice mj updated VT), because I don't see the 10 point Gamma adj.,or the 10pt. W/B adjustments. Not in my owners manual either. I was able to do CMS except it's caled color detail adjustment.Advance picture I could do, but the 3:2 pull down is grayed out...I set Gamma 2.2 Blk xten.Agc, etc. But didn't see the above mentioned settings. Is this in the Service Menu? Please help!!
Mapesaudio
Mark C.
Old 12-14-2011, 04:36 PM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
No, not in the SM, but in the Pro settings (one of the options in the regular User Menu). You have to put in the settings, in Custom mode, for each HDMI input you use (I needed to do it for all 4 HDMI inputs).
BillP is offline
Old 12-14-2011, 04:45 PM
mapesaudio's Avatar
I understand it's in the pro settings, the 10 point gamma and the 10 point W/B are not showing up, I was wondering if there is something I have to activate to make that happen?
Mark C.
Old 12-14-2011, 05:31 PM
IPWinsor's Avatar
Hi everyone,
I bought a TCP60GT30 about 2 weeks ago and have watched it for about 40 hours or so before stumbling across this thread.
Is it too late for me to use the break-in slides and settings now?
IPWinsor is offline
Old 12-14-2011, 06:01 PM
mark62's Avatar
Liked: 88
so the SM for cinema is the same as custom in the user settings. if you look at D-Nice's cal report custom calibrates nicely. i think some of the reviews were trying to calibrate the ST in MID panel brightness and of course it is junk.
mark62 is offline
Old 12-15-2011, 05:43 AM
godzen's Avatar
download ST30 slide files. Unrar said corrupt?
godzen is offline
Old 12-15-2011, 07:29 AM
DavidHir's Avatar
Liked: 1335
Can any of the calibrators discuss how the Panasonics and namely the ST30 drifts over time? What concerns me is, since there is no gamma control and CMS per se, that as the set drifts over time, it will be impossible to maintain as tight of a calibration as when the set is new. This happened on my SXRD as there was no way to control the drifting color points over time (although that display had other issues) and they never were as accurate as when I first bought the set. Perhaps Panasonics are pretty good at holding gamma and color points over time.
Old 12-15-2011, 07:38 AM - Thread Starter
D-Nice's Avatar
Quoted: 83 Post(s)
Liked: 320
CIE color points and gamma do not change on these panels. Only grayscale
D-Nice is offline
Old 12-15-2011, 07:55 AM
DavidHir's Avatar
Liked: 1335
Great. Thank you. I don't want to go down that SXRD path again. lol
Old 12-15-2011, 10:59 AM
rkavanau's Avatar
Posted this in the ST30 thread, but haven't heard back. Anyone here have any ideas?
I've noticed something odd the past couple of days, and after playing around, a way to fix it, but I'm not sure if there's a bigger problem.
A couple of days ago I noticed "static" on black screens that were included in the signal. By that I mean that it doesn't appear in the black bars of letterbox or 4:3. It's hard to describe but up close it looks like red moving pixels within the black. It spans the entire screen. At first I thought it was a handshake issue so I switched to a different HDMI cable, but it was still there. Next, I changed from the uverse box to the ps3 and started a blu ray. The static was still there. I paused the TV on a screen where it was noticeable and started playing with the settings (the static continues to "move" while it's paused). I found that the static is only visible on mid or high panel brightness. I also found that I can eliminate it by bumping up the black extension. At 4 it's visible, at 5 it disappears. I also tried changing all the various noise reduction settings, but none of those had any effect.
Does anyone know what this is? I'm at work and don't have my exact settings on hand, but this should be pretty close (WB might be +/- 1).
Picture Mode: Custom
Contrast: 85
Brightness: 55
Color: 47
Tint: 0
Sharpness: 0
Color Temp: Normal
Photo Enhancement: Off
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: +2
W/B High G: +4
W/B High B: +6
W/B Low R: +2
W/B Low G: +4
W/B Low B: -4
Black Extension: + 2
Gamma Adjustment: 2.4
Panel Brightness: Mid
Contour Emphasis: Off
AGC: 1
HDMI Settings
- all auto
Advance Picture
Block NR: Off
Mosquito NR: Off
Motion Smoother: Off
Black Level: Light
3:2 PullDown: Auto
rkavanau is offline
Old 12-15-2011, 11:18 AM
tcc
tcc's Avatar
This is the same issue I'm having thus my comment on the SM.
When I go into the pro settings I don't see the 10 point w/b, gamma or CMS, there's only 3 each. Unless I have my system hooked up wrong since it is mentioned you have to do it for each hdmi input. I have all my hdmi sources going into a Denon AVR3312 and then outputting the hdmi from the rcvr to the vt30.
tcc is offline
Old 12-15-2011, 03:19 PM
mapesaudio's Avatar
I now believe the 10IRE, then 20IRE, ad so on, with gain below it is the W/B gain/ Go to the gamma adjustment and you will see the same thing. Adjusted mine that way and it really looks great. I still used the Dnice settings....BRAVO, Dnice!!
Only difference I made was to run Gamma at 2.0 instead of 2.2.
Very little lighter blacks with allot more shadow detail. IMO.
Mapesaudio
Mark C.
Old 12-15-2011, 04:17 PM
tcc
tcc's Avatar
now believe the 10IRE, then 20IRE, ad so on, with gan below it is the W/B gain/ Go to the gamma adjustment and you will see the same thing. adjusted mine that way and it really looks great. I still used the Dnice settings....BRAVO, Dnice!!
Ahhhhh, gotcha. Thanks, will try that out later
tcc is offline
Old 12-15-2011, 06:19 PM
DavidHir's Avatar
Liked: 1335
D-Nice,
Do the VT30, GT30, and ST30 in their calibrated 'optimal' picture modes offer equal resolution and detail? Also, any difference in phosphor lag? (talking 2D).
Old 12-15-2011, 09:48 PM
Maxs_dad's Avatar
50 inch st30 here and am trying out dnice's settings (btw thanks), and my daughter has been experiencing some eye strain fairly quickly. We will be experimenting with room lighting, and perhaps bias lighting, but I wanted to ask the question if any of the settings (contrast perhaps) might be relatively aggressive from this standpoint. 7 year old child sitting about 8 feet away without any problems (recently been to eye doctor) until this tv, though the tv is in a different room than before. Previously had a 42 inch edtv sitting 11 feet away.
Maxs_dad is offline
Old 12-16-2011, 05:48 PM
byteflood's Avatar
Does anyone know if going into the service menu on the GT series is something that voids the warranty or something that you should *really* know what you are doing before you go in? (Seems a tad unfair to penalize GT owners in this case. My opinion.)
byteflood is offline
Panasonic Viera Tc P42st30 42 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P46st30 46 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P55st30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65st30 65 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60gt30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P55gt30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65gt30 65 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65vt30 65 Inch 3d Plasma Hdtv , Panasonic Viera Tc P55vt30 55 Inch 1080p 3d Plasma Hdtv
