Official 2011 Panasonic Settings/Issues Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 1088 Old 04-02-2013, 07:52 AM
Wasswa Noe's Avatar
my panasonic tc-55st30 pictures a very unclear running downwards how can i fix it
this happens when i connect external devices like dvds,antenna or decoder but the usb output is good
Wasswa Noe is offline
post #1082 of 1088 Old 07-16-2013, 06:01 AM
Tom Riddle's Avatar
Quoted: 513 Post(s)
Liked: 428
I'm sorry for such a late response; you will most likely have to get your television serviced if the line is a constant on all inputs - it sounds like an HDMI issue if that is what your are using fork hookups. Call Panasonic and they will setup service, but you will have to pay out of pocket for the repair. Look into a warranty from Squaretrade for the future - cheap and reliable.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #1083 of 1088 Old 01-16-2014, 04:59 PM
cpc
cpc's Avatar
Sorry to bring this back. I notice that the new Break-in slides for the 2013 Plasma are different than the ones from 2011. I guess they are simplified?
Anyhow, is the brightest white slide in the original D-Nice Evangelo's USB/SD Card files linked in this thread a full screen 100 IRE white slide?
cpc is offline
post #1084 of 1088 Old 03-08-2014, 04:42 PM
terzaghi's Avatar
Can someone remind me how to tell if my 65vt 30 is the EEPROM updated or non EEPROM updated version? Thanks
terzaghi is offline
post #1085 of 1088 Old 03-08-2014, 05:02 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 123
August builds and beyond with seriel numbers begining with #1215 have the new eeprom installed from factory.
If you have an earlier build you need to go in the service menu to see which eeprom flash number you have.
Search this forum for a member named TFoltz, he goes into great detail on how to verify which number you have.
If you have an older version, you are gonna have to work something out with panasonic to get a tech to your house to get it flashed.
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #1086 of 1088 Old 03-08-2014, 05:25 PM
terzaghi's Avatar
Thanks. I'm a nob build MJ series do looks like it has updated EEPROM like I suspected all of these years.
terzaghi is offline
post #1087 of 1088 Old 03-08-2014, 05:25 PM
terzaghi's Avatar
I have a nov*
terzaghi is offline
post #1088 of 1088 Old 03-08-2014, 05:36 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 123
I have a nov*
Your all set...
Panasonic Viera Tc P42st30 42 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P46st30 46 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P55st30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65st30 65 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60gt30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P55gt30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65gt30 65 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65vt30 65 Inch 3d Plasma Hdtv , Panasonic Viera Tc P55vt30 55 Inch 1080p 3d Plasma Hdtv
