Official 2011 Panasonic Settings/Issues Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1088 Old 11-08-2011, 07:47 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
****UNDER NO CIRCUMSTANCE SHOULD THESE SETTINGS BE USED WITH ANY OTHER SOURCE MATERIAL BEYOND THE PANEL PREP USB/SD CARD FILES****
Recommended 100 Hour Panel Prep Settings for North American Panasonic TC-PxxST30/GT30/VT30 models (ONLY to be used with Evangelo's USB/SD Card files!!!!!!!!)
*****Note: This procedure is designed to prepare your display for the reference settings listed below by aging all pixels equally with the same content. This procedure is NOT designed nor recommended to be used as Break-in, Image Retention and/or Burn-in prevention.*****
Photo Settings
Picture Mode: Custom
Contrast: 100
Brightness: 50
Color: 70
Tint: 0
Sharpness: 50
Color Temp: Cool2
Photo Enhancement: Off
C.A.T.S: Off
Video NR: Off
Pro Settings
***Leave all settings in this menu at their default***
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Motion Smoother: Off
Slideshow Settings
Frame: Off
Photo Effect: Off
Transition Effect: Off
Photo Size: Normal
Burst Playback: Off
Display Interval: Slow
Repeat Playback: On
D-Nice is offline
post #2 of 1088 Old 11-08-2011, 07:47 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
North American TC-PxxST30 Reference Settings
*****Note: These settings are designed exclusively to be used on North American TC-PxxST30 displays after completing the Panel Prep procedure listed post #1. Please do not use these settings unless you have follow post #1 entirely.*****
Contrast: 78
Brightness: 54
Color: 45
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: +10
W/B High G: 0
W/B High B: +10
W/B Low R: +2
W/B Low G: 0
W/B Low B: -8
Black Extension: 0
Gamma Adjustment: 2.2
Panel Brightness: Low
Contour Emphasis: Off
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
D-Nice is offline
post #3 of 1088 Old 11-08-2011, 07:48 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
North American TC-PxxGT30 Reference Settings
*****Note: These settings are designed exclusively to be used on North American TC-PxxGT30 displays after completing the Panel Prep procedure listed post #1. Please do not use these settings unless you have follow post #1 entirely.*****
Picture Mode: THX
Contrast: 60
Brightness: 54
Color: 45
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
SM Access Instructions (ENTER AT YOUR OWN RISK!!!!)
  1. Turn on the TV.
  2. While holding down the Vol - (minus) on the back, right side of the display, press the “info” button on the remote 3 times.
  3. The service menu appear after a few seconds.
  4. Press 1 on the remote twice to get to the “WB-Adjust” screen.
  5. Press 7 on the remote until the color temperature says “Warm“.
  6. Press 3 on the remote to cycle through R-DRV, G-DRV, B-DRV, R-CUT, G-CUT and B-CUT and enter the offset values below (DO NOT CHANGE THE ALL-DRV and ALL-CUT VALUES).
Note: These offsets must be entered for both Color matrixes (HD/SD). You access the different matrixes by using a 1080i/p signal for the HD matrix and 480i/p signal for the SD matrix.
SM Offsets
R-DRV: Vol - (minus) 6 times
G-DRV: 0
B-DRV: Vol + (plus) 8 times
R-CUT: 0
G-CUT: 0
B-CUT: Vol - (minus) 5 times
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: On
D-Nice is offline
post #4 of 1088 Old 11-08-2011, 07:48 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
Non EPROM Updated LH Series North American TC-P55VT30 Reference Settings
*****Note: These settings are designed exclusively to be used on North American TC-P55VT30 displays after completing the Panel Prep procedure listed post #1. Please do not use these settings unless you have follow post #1 entirely.*****
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -8
10 W/B G: 1
10 W/B B: -24
20 W/B R: 0
20 W/B G: 0
20 W/B B: -1
30 W/B R: 3
30 W/B G: 0
30 W/B B: 1
40 W/B R: 1
40 W/B G: 0
40 W/B B: 1
50 W/B R: 3
50 W/B G: 1
50 W/B B: -1
60 W/B R: 0
60 W/B G: 0
60 W/B B: -3
70 W/B R: 1
70 W/B G: 0
70 W/B B: 2
80 W/B R: -1
80 W/B G: 0
80 W/B B: 6
90 W/B R: -3
90 W/B G: 0
90 W/B B: 0
100 W/B R: -4
100 W/B G: 0
100 W/B B: 5
10 Point Gamma
10 Gain: -50
20 Gain: -24
30 Gain: -18
40 Gain: -34
50 Gain: -32
60 Gain: -27
70 Gain: -30
80 Gain: -23
90 Gain: -6
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -2
R-Lum: 10
G-Hue: 6
G-Sat: 11
G-Lum: 9
B-Hue: -16
B-Sat: 37
B-Lum: 19
Y-Hue: 23
Y-Sat: 3
Y-Lum: -15
C-Hue: -8
C-Sat: -41
C-Lum: 3
M-Hue: 3
M-Sat: 5
M-Lum: 13
Black Extension: 0
Panel Brightness: Mid
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
Non EPROM Updated MH Series North American TC-P55VT30 Reference Settings
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -12
10 W/B G: 2
10 W/B B: -21
20 W/B R: -2
20 W/B G: 0
20 W/B B: -3
30 W/B R: -5
30 W/B G: 0
30 W/B B: -2
40 W/B R: -1
40 W/B G: 0
40 W/B B: -1
50 W/B R: -3
50 W/B G: 1
50 W/B B: -4
60 W/B R: -2
60 W/B G: 0
60 W/B B: -2
70 W/B R: -6
70 W/B G: 0
70 W/B B: -3
80 W/B R: -7
80 W/B G: 0
80 W/B B: -1
90 W/B R: -3
90 W/B G: 0
90 W/B B: -4
100 W/B R: -10
100 W/B G: 0
100 W/B B: 3
10 Point Gamma
10 Gain: -50
20 Gain: -24
30 Gain: -18
40 Gain: -33
50 Gain: -31
60 Gain: -26
70 Gain: -31
80 Gain: -24
90 Gain: -11
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -4
R-Lum: 37
G-Hue: 7
G-Sat: 15
G-Lum: -49
B-Hue: -16
B-Sat: 35
B-Lum: 46
Y-Hue: -15
Y-Sat: 8
Y-Lum: -17
C-Hue: 33
C-Sat: -29
C-Lum: -11
M-Hue: 9
M-Sat: 5
M-Lum: 14
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
Non EPROM Updated MJ Series North American TC-P55VT30 Reference Settings
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -4
10 W/B G: 1
10 W/B B: -21
20 W/B R: 4
20 W/B G: 0
20 W/B B: 2
30 W/B R: 8
30 W/B G: 0
30 W/B B: 4
40 W/B R: 6
40 W/B G: 0
40 W/B B: 3
50 W/B R: 8
50 W/B G: 0
50 W/B B: 1
60 W/B R: 3
60 W/B G: 0
60 W/B B: -2
70 W/B R: 6
70 W/B G: 0
70 W/B B: 5
80 W/B R: 3
80 W/B G: 0
80 W/B B: 6
90 W/B R: 3
90 W/B G: 0
90 W/B B: 3
100 W/B R: 0
100 W/B G: 0
100 W/B B: 6
10 Point Gamma
10 Gain: -50
20 Gain: -24
30 Gain: -18
40 Gain: -34
50 Gain: -32
60 Gain: -27
70 Gain: -30
80 Gain: -22
90 Gain: -6
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -4
R-Lum: 42
G-Hue: 6
G-Sat: 11
G-Lum: -50
B-Hue: -17
B-Sat: 38
B-Lum: 50
Y-Hue: -9
Y-Sat: 9
Y-Lum: -22
C-Hue: 28
C-Sat: -33
C-Lum: -15
M-Hue: 10
M-Sat: 2
M-Lum: 9
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
D-Nice is offline
post #5 of 1088 Old 11-08-2011, 07:48 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -5
10 W/B G: 0
10 W/B B: -4
20 W/B R: 0
20 W/B G: 0
20 W/B B: 3
30 W/B R: 1
30 W/B G: 0
30 W/B B: 15
40 W/B R: -1
40 W/B G: 0
40 W/B B: 8
50 W/B R: 1
50 W/B G: 2
50 W/B B: 11
60 W/B R: -2
60 W/B G: 0
60 W/B B: 6
70 W/B R: -3
70 W/B G: 0
70 W/B B: 6
80 W/B R: -3
80 W/B G: 0
80 W/B B: 12
90 W/B R: -6
90 W/B G: 0
90 W/B B: 0
100 W/B R: -5
100 W/B G: 0
100 W/B B: 12
10 Point Gamma
10 Gain: -50
20 Gain: -10
30 Gain: -3
40 Gain: -24
50 Gain: -20
60 Gain: -21
70 Gain: -29
80 Gain: -23
90 Gain: -9
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -1
R-Lum: 43
G-Hue: 6
G-Sat: 9
G-Lum: -50
B-Hue: -15
B-Sat: 29
B-Lum: 40
Y-Hue: -20
Y-Sat: 10
Y-Lum: -16
C-Hue: 40
C-Sat: -20
C-Lum: -15
M-Hue: 10
M-Sat: 1
M-Lum: 20
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
D-Nice is offline
post #6 of 1088 Old 11-08-2011, 07:49 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
Non EPROM Updated LH Series North American TC-P65VT30 Reference Settings
*****Note: These settings are designed exclusively to be used on North American TC-P65VT30 displays after completing the Panel Prep procedure listed post #1. Please do not use these settings unless you have follow post #1 entirely.*****
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -8
10 W/B G: 0
10 W/B B: -26
20 W/B R: 10
20 W/B G: 4
20 W/B B: 8
30 W/B R: 8
30 W/B G: 0
30 W/B B: 5
40 W/B R: 11
40 W/B G: 0
40 W/B B: 2
50 W/B R: 7
50 W/B G: 1
50 W/B B: -4
60 W/B R: 13
60 W/B G: 0
60 W/B B: 7
70 W/B R: 4
70 W/B G: 0
70 W/B B: -8
80 W/B R: 10
80 W/B G: 0
80 W/B B: 6
90 W/B R: 2
90 W/B G: 0
90 W/B B: -1
100 W/B R: 8
100 W/B G: 0
100 W/B B: 2
10 Point Gamma
10 Gain: -50
20 Gain: -19
30 Gain: -14
40 Gain: -36
50 Gain: -32
60 Gain: -22
70 Gain: -24
80 Gain: -22
90 Gain: -5
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -2
R-Lum: 40
G-Hue: 6
G-Sat: 11
G-Lum: -48
B-Hue: -16
B-Sat: 31
B-Lum: 45
Y-Hue: -21
Y-Sat: 5
Y-Lum: -15
C-Hue: 31
C-Sat: -21
C-Lum: -13
M-Hue: 17
M-Sat: 3
M-Lum: 14
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
Non EPROM Updated MH Series North American TC-P65VT30 Reference Settings
Contrast: 72
Brightness: 55
Color: 50
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -12
10 W/B G: 2
10 W/B B: -22
20 W/B R: -7
20 W/B G: 0
20 W/B B: -10
30 W/B R: -4
30 W/B G: 0
30 W/B B: -8
40 W/B R: -2
40 W/B G: 0
40 W/B B: -4
50 W/B R: -2
50 W/B G: 1
50 W/B B: 0
60 W/B R: -4
60 W/B G: 0
60 W/B B: -3
70 W/B R: -3
70 W/B G: 0
70 W/B B: 2
80 W/B R: -5
80 W/B G: 0
80 W/B B: 0
90 W/B R: -5
90 W/B G: 0
90 W/B B: 0
100 W/B R: -8
100 W/B G: 0
100 W/B B: 1
10 Point Gamma
10 Gain: -50
20 Gain: -42
30 Gain: -36
40 Gain: -19
50 Gain: -13
60 Gain: -6
70 Gain: -6
80 Gain: -2
90 Gain: 3
100 Gain: 0
CMS
R-Hue: 5
R-Sat: -2
R-Lum: -5
G-Hue: 7
G-Sat: 7
G-Lum: -49
B-Hue: -16
B-Sat: 36
B-Lum: -1
Y-Hue: -11
Y-Sat: -10
Y-Lum: -9
C-Hue: 24
C-Sat: -39
C-Lum: -2
M-Hue: 8
M-Sat: -9
M-Lum: 19
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
Non EPROM Updated MJ Series North American TC-P65VT30 Reference Settings
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -8
10 W/B G: 0
10 W/B B: -18
20 W/B R: 5
20 W/B G: 0
20 W/B B: 12
30 W/B R: 3
30 W/B G: 0
30 W/B B: 4
40 W/B R: 7
40 W/B G: 0
40 W/B B: 2
50 W/B R: 5
50 W/B G: 0
50 W/B B: 5
60 W/B R: 7
60 W/B G: 0
60 W/B B: 1
70 W/B R: 5
70 W/B G: 0
70 W/B B: 3
80 W/B R: 2
80 W/B G: 0
80 W/B B: 1
90 W/B R: 6
90 W/B G: 0
90 W/B B: 6
100 W/B R: 0
100 W/B G: 0
100 W/B B: 9
10 Point Gamma
10 Gain: -50
20 Gain: -24
30 Gain: -22
40 Gain: -37
50 Gain: -38
60 Gain: -24
70 Gain: -34
80 Gain: -24
90 Gain: -9
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -2
R-Lum: 38
G-Hue: 6
G-Sat: 9
G-Lum: -50
B-Hue: -13
B-Sat: 21
B-Lum: 47
Y-Hue: -25
Y-Sat: 11
Y-Lum: -17
C-Hue: 37
C-Sat: -7
C-Lum: -27
M-Hue: 10
M-Sat: 3
M-Lum: 7
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
D-Nice is offline
post #7 of 1088 Old 11-08-2011, 07:49 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
Contrast: 72
Brightness: 55
Color: 36
Tint: 0
Sharpness: 0
Color Temp: Warm2
C.A.T.S: Off
Video NR: Off
Pro Settings
Colorspace: Normal
W/B High R: 0
W/B High G: 0
W/B High B: 0
W/B Low R: 0
W/B Low G: 0
W/B Low B: 0
10 Point W/B
10 W/B R: -10
10 W/B G: 0
10 W/B B: -14
20 W/B R: 5
20 W/B G: 0
20 W/B B: 18
30 W/B R: 3
30 W/B G: 0
30 W/B B: 7
40 W/B R: 6
40 W/B G: 0
40 W/B B: 13
50 W/B R: 5
50 W/B G: 0
50 W/B B: 18
60 W/B R: 7
60 W/B G: 0
60 W/B B: 8
70 W/B R: 2
70 W/B G: 0
70 W/B B: 7
80 W/B R: 6
80 W/B G: 0
80 W/B B: 15
90 W/B R: -1
90 W/B G: 0
90 W/B B: 6
100 W/B R: 3
100 W/B G: 0
100 W/B B: 9
10 Point Gamma
10 Gain: -50
20 Gain: -10
30 Gain: -3
40 Gain: -24
50 Gain: -26
60 Gain: -20
70 Gain: -24
80 Gain: -25
90 Gain: -5
100 Gain: 0
CMS
R-Hue: 3
R-Sat: -3
R-Lum: 50
G-Hue: 7
G-Sat: 14
G-Lum: -49
B-Hue: -13
B-Sat: 22
B-Lum: 49
Y-Hue: -24
Y-Sat: 5
Y-Lum: -19
C-Hue: 36
C-Sat: -14
C-Lum: -15
M-Hue: 16
M-Sat: 7
M-Lum: 15
Black Extension: 0
AGC: 0
HDMI Settings
Advance Picture
Block NR: Off
Mosquito NR: Off
Black Level: Light
3:2 PullDown: Auto
D-Nice is offline
post #8 of 1088 Old 11-08-2011, 07:49 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
D-Nice is offline
post #9 of 1088 Old 11-08-2011, 07:49 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
D-Nice is offline
post #10 of 1088 Old 11-08-2011, 07:49 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
D-Nice is offline
post #11 of 1088 Old 11-08-2011, 07:50 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
D-Nice is offline
post #12 of 1088 Old 11-08-2011, 07:52 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Did we just jump back to March of 2011?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #13 of 1088 Old 11-08-2011, 08:03 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
No. AVS has gotten better over the past few months and my settings being posted here will benefit the community. A lot more to come
D-Nice is offline
post #14 of 1088 Old 11-08-2011, 09:09 AM
DavidHir's Avatar
Quoted: 2053 Post(s)
Liked: 1677
D-Nice,
Panasonic claims the rising blacks are fixed. Cnet's tests only go up to 1500 hours. Have you been able to test any 2011 Panasonics beyond the 1500 mark and if so, how is the MLL measuring? Thanks.
DavidHir is offline
post #15 of 1088 Old 11-08-2011, 09:14 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
D-Nice,
I'm pretty much done with Panasonic in that manner. I have not nor will I be doing this type of monitoring for Panasonic products.
D-Nice is offline
post #16 of 1088 Old 11-08-2011, 09:36 AM
sloppojoe's Avatar
Awesome! Thanks for taking the time to do this!
sloppojoe is offline
post #17 of 1088 Old 11-08-2011, 10:24 AM
Jimmy's Avatar
Thanks "D", good to see your work again.
Jimmy is offline
post #18 of 1088 Old 11-08-2011, 10:29 AM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
Thanks so much for this. During the setting up of my ST I ended up right where you were and was left with a green push using default W/B, so the W/B settings overcame that. Now I'm left with a tv that is very pleasing to watch. Nice cal report you left at the 'other' site. I really appreciate what you have done here
whipit is online now
post #19 of 1088 Old 11-08-2011, 12:45 PM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
Glad to be back
D-Nice is offline
post #20 of 1088 Old 11-08-2011, 12:46 PM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
I will have the cal reports for each model up by tomorrow.
D-Nice is offline
post #21 of 1088 Old 11-08-2011, 06:13 PM
phillyswirl's Avatar
Just a few days too late haha! picked up my gt30 last tuesday. been running the slides for a while now (just hitting 200hrs now) but i was running them at the default picture values for picture mode Standard. You think it would be acceptable to do the settings you have listed here? if not, i'll leave it on THX.
phillyswirl is offline
post #22 of 1088 Old 11-09-2011, 01:02 PM
sloppojoe's Avatar
I downloaded these slides from the other forum last week and it seems that slides 3 & 4 of the red group are the same shade. Anyone else notice this? Not sure it matters, just an observation.
post #23 of 1088 Old 11-09-2011, 01:03 PM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
Thanks. Its known and does not affect anything.
D-Nice is offline
post #24 of 1088 Old 11-09-2011, 01:04 PM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
It does not hurt to try. However, I do not know what the end result will be.
D-Nice is offline
post #25 of 1088 Old 11-10-2011, 07:28 AM
Jimmy's Avatar
"D", if we have a newer build ST, mine is October, will your settings pretty much be the same? I am assuming that you were working with a "fixed" display and everything is the same. BTW/ compared to my VT25, your ST settings are pretty damn good. Thanks again.
Jimmy is offline
post #26 of 1088 Old 11-10-2011, 07:58 AM - Thread Starter
D-Nice's Avatar
Quoted: 712 Post(s)
Liked: 1510
You should be ok, but I do need to provide updated setting for the later ST models.
D-Nice is offline
post #27 of 1088 Old 11-10-2011, 08:42 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
hmm, my VT25 has not been stable.
I am hoping when it reaches 2500hrs, it will finally behave.
Loving D65
CalWldLif is offline
post #28 of 1088 Old 11-12-2011, 01:54 PM
sloppojoe's Avatar
Just got my replacement VT30 from best buy (replacing panel with a 1" scratch on the backside of the glass) and the line bleed is horrible! The menu shoots across the screen while running break-in slides. Has anyone else experienced this? I don't recall seeing this on the first set. Also not sure I am calling the issue by it's appropriate term, but when the menu is on the screen it changes the shade of the background color (slide) across the screen.
Kind of bummed right now.
First set- screws were cross threaded and stripped by installers (why do these guys use screw guns?).
Second set- 1" scratch, or plastic, or whatever behind glass.
Third set- worst line bleed I have ever seen.
The build date is August 2011 serial number MJ1214
Any thoughts?
post #29 of 1088 Old 11-12-2011, 02:40 PM
cpcat's Avatar
Sounds normal to me. I've seen this on
every plasma I've had and I'm sure the
break-in slides/torch settings show it much
more. If you don't have anything else significant
wrong I wouldn't worry.
cpcat is offline
post #30 of 1088 Old 11-12-2011, 02:51 PM
sloppojoe's Avatar
Good to know. Does it vary from set to set?
Panasonic Viera Tc P42st30 42 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P46st30 46 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P55st30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65st30 65 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P60gt30 60 Inch 1080p 600 Hz 3d Plasma Hdtv , Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P55gt30 55 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65gt30 65 Inch 1080p 3d Plasma Hdtv , Panasonic Viera Tc P65vt30 65 Inch 3d Plasma Hdtv , Panasonic Viera Tc P55vt30 55 Inch 1080p 3d Plasma Hdtv
