TV Tuner on Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-08-2011, 12:11 PM - Thread Starter
christnp's Avatar
This may be a ridiculous question, but does a Plasma TV usually have a TV tuner? In particular, I'm looking at the Panny P42ST30, but I can't find in its specs that it has a built-in tuner (even though I'd think that was standard on a TV). Thoughts?
christnp is offline
post #2 of 10 Old 11-08-2011, 12:15 PM
Possumgirl's Avatar
Liked: 58
Yes it has ATSC and, I believe, NTSC & QAM. I use the ATSC tuner for digital OTA. TVs have tuners, monitors do not.
Possumgirl is offline
post #3 of 10 Old 11-08-2011, 12:18 PM
Phil Tomaskovic's Avatar
Quoted: 35 Post(s)
Integrated ATSC Tuner Yes under Technical Specs
http://www2.panasonic.com/consumer-e...702#tabsection
However I have a friend has a plasma with no tuner (monitor) so perhaps this is more common with plasma sets vs leds?
Phil Tomaskovic
Phil Tomaskovic is offline
post #4 of 10 Old 11-08-2011, 12:25 PM - Thread Starter
christnp's Avatar
That is what I thought and this is one reason I would purchase the TV vs a Monitor (I currenlty use a monitor, but sold my PC tuner card)... and this is why I was sure my question was rediculous; but for the life of me I could not find that information (granted, I was only looking on Amazon ). Thanks for the link too!
christnp is offline
post #5 of 10 Old 11-08-2011, 02:06 PM
Steve S's Avatar
Liked: 46
For future reference, if the device is marketed as a TV set it must have at least an ATSC (ota) digital tuner. Most also have QAM digital tuners that will access unscrambled digital cable channels. If the device is marketed as a monitor it is not required to have a tuner. Commercial plasmas meant for use in stores etc. usually are classified as monitors.
Steve S.
Steve S is offline
post #6 of 10 Old 11-09-2011, 08:58 AM
rxheaven's Avatar
Panny doesn't (on the 2010 model anyway) have any support for any on-screen guide whatsoever (TVGOS or PSIP etc).
So, really not the most OTA-friendly brand, even for models you pay a few thousand dollars. Pressing the INFo button on the remote will only give you part of the title of what's on right now (but no program description and even the title is limited to something like 15 characters).
I emailed them about it and was told to F off.
rxheaven is offline
post #7 of 10 Old 11-09-2011, 07:09 PM - Thread Starter
christnp's Avatar
Yeah, I thought it was just standard that a TV had a tuner -- but then I saw one advertised as having a built-in tuner (which some monitors will say, but this was advertised as a TV). So then I got worried
christnp is offline
post #8 of 10 Old 11-09-2011, 07:27 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
That is the very reason I choose Samsung over Panasonic for OTA viewers. Complete program information and channel list built in. No cable box, only OTA antenna.
tylerSC is offline
post #9 of 10 Old 11-10-2011, 07:54 AM
rxheaven's Avatar
Ya, OTA wasn't a priority when I bought the TV, but now I use 95% of my TV viewing through OTA, the remaining 5% with cable STB.
So, it's annoying. I don't understand why they won't at least have an APP for it. I have all those APPs, there's even more than one weather app (accuweather and another one) but nothing for TV programming.
That blows )o:
I am shopping for a very cheap (probably LCD even) TV for the bedroom. It certainly will not be a Panny.
rxheaven is offline
post #10 of 10 Old 11-10-2011, 02:10 PM
tylerSC's Avatar
Quoted: 721 Post(s)
Liked: 166
Samsung PN43D450 makes a good bedroom TV.
tylerSC is offline
