LG Plasma Panel tweaks for better blacks. - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #721 of 1476 Old 01-11-2012, 11:50 AM
Voz
Voz's Avatar
Originally Posted by Collusion View Post
I did this operation today for my friend's european 50PK350. The initial MLL @60Hz was 0,13cd/m2 and after two attemps we got it stable at 0,034cd/m2. I didn't measure the MLL at @24Hz or @50Hz since we were in a bit of hurry. The outcome was really welcome though as the contrast ratio almost quadrupled
Only Set_Up and Vy potentiometers were trimmed.
Thanks for the report! What did you feed the TV with while doing the tweaking - 24p, 50Hz or 60Hz? If you tested them all, which one was the hardest to get stable?
Voz is offline
post #722 of 1476 Old 01-11-2012, 01:30 PM
Collusion's Avatar
An X-rite i1Display 2 meter was taking constant measurements of the MLL while I trimmed the two pots. AVS HD709 BD 'black bar' scene was used to prevent the TV from entering into power saving mode.
I stopped at 0,028cd/m2 and then checked a 24hz source from PS3. The where some pixel misfires, so I trimmed the Set_Up potentiometer bit backwards and checked again - no misfires. All the 50hz inputs tested were also clean of misfires. So, the final result was 0,034cd/m2.
I think there is still room for a small enchantment, but this wasn't my tv set and the time was rather limited Someone already got below 0,03cd/m2 with more careful trimming.
Collusion is offline
post #723 of 1476 Old 01-11-2012, 03:08 PM
rpauls's Avatar
Fyi for those of us using English units, 1 cd/m2 = .292 ftL.
So .034 cd/m2 = .010 ftL
I got .007 ftL with only set_up/dn but only in 60Hz mode. My 24fps is much higher at .018ftL. TV is USA 60PK540.
rpauls is offline
post #724 of 1476 Old 01-12-2012, 07:00 AM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Sounds about right, a properly calibrated stock PK/PX950 should begin with a slightly better contrast ratio to than the PK550 (although reports have varied) and I've achieved a lower black level than the Panasonic ST30 which I believe is at .006.
Just trying to decide if I stay with the results that I got with just the Set_up or take er down again and fiddle with the Set_dn to see if I can get it even lower.
Robert
Toronto, Ontario
rob80b is online now
post #725 of 1476 Old 01-12-2012, 07:28 AM
rpauls's Avatar
Your results are already excellent, but if you want to experiment further perhaps you should buy or borrow an i1 probe to guide you. Otherwise you will always be guessing at whether your new black is lower than before.
You can get one new here for 149. I'm sure there are used ones too. I have this one and it works great.
http://www.amazon.com/X-Rite-EODLT-E...6378306&sr=8-3
rpauls is offline
post #726 of 1476 Old 01-12-2012, 08:01 AM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Not too sure I want to go lower, I've already knocked my Guinness over 2 or 3 times while watching movies, that never happened prior to tweaking.
But you're right, without a meter ones always guessing or wishful thinking.
Robert
Toronto, Ontario
post #727 of 1476 Old 01-12-2012, 02:45 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
According to current information on the PM970T plasma for 2012
"The new plasma series can, thanks to a new type of phosphorus, improving image quality at several points. With the new Super Black Panel technology is the black 40 percent darker than before, and with a new algorithm improves the contrast so that the colors are brighter and the blacks are darker."
http://www.flatpanels.dk/nyhed.php?s...&id=1326125436
http://translate.google.com/translat...d%3D1326125436
Well we know LG can produce much lower black levels, but will they, the proof will be in the pudding
Robert
Toronto, Ontario
post #728 of 1476 Old 01-12-2012, 03:25 PM
Collusion's Avatar
This doesn't actually tell if the contrast is better in ambient light conditions (new filter) or they've messed with the pre-discharge circuits to produce lower MLL.
post #729 of 1476 Old 01-12-2012, 03:41 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Exactly.
Robert
Toronto, Ontario
post #730 of 1476 Old 01-12-2012, 04:01 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Panasonic's claims appear more rewarding.
"the VT50 series, offers some of the best contrast, color saturation and black levels I've ever seen in a TV at a trade show demo"
"The black level improvement can be attributed to an enhanced pre-discharge control that enables the panel to get darker and reach these black levels faster than previous models."
http://www.bigpicturebigsound.com/Pa...V-Series.shtml
Robert
Toronto, Ontario
post #731 of 1476 Old 01-12-2012, 04:11 PM
rpauls's Avatar
"The black level improvement can be attributed to an enhanced pre-discharge control that enables the panel to get darker and reach these black levels faster than previous models."[/i]
Isn't that what we're doing with set_up/set_dn? Enhanced pre-discharge control? :-)
rpauls is offline
post #732 of 1476 Old 01-12-2012, 04:18 PM
Collusion's Avatar
Judging from the information Panasonic has already released, it seems that the consumer line in 2012 will be using same technology as the professional / custom install series. There was actually a picture posted earlier here on avs, which shows the difference in MLL on 55GT30 (left) and 65VT50 (right).
post #733 of 1476 Old 01-12-2012, 04:34 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Yep
Robert
Toronto, Ontario
post #734 of 1476 Old 01-12-2012, 04:36 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
I have to say my PX950 looks like the one on the right
Robert
Toronto, Ontario
post #735 of 1476 Old 01-12-2012, 04:38 PM
rpauls's Avatar
Definitely. I don't know what that set is on the left, but it needs to have its set_up adjusted ;-)
rpauls is offline
post #736 of 1476 Old 01-12-2012, 04:41 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Sorry, with that much white my set would look "black-black"
Robert
Toronto, Ontario
post #737 of 1476 Old 01-12-2012, 06:10 PM
Big Brad's Avatar
Quoted: 300 Post(s)
Liked: 419
I was finally able to get my Eye One LT to produce a useable and sustainable reading on a 0 IRE test pattern using Color HCFR. Honestly, I'm not sure what I was doing wrong before (I've never had issues like the in the past), but now I never get the "No data from sensor message" at all.
Well, the results are quite impressive. I measured my 50PK550 yesterday a few times over the course of the day. The 0 IRE read a consistent .005 MLL. I'm amazed at how low that is. Overall effective contrast has almost quadrupled, going from 1900:1 pre-tweak to a little over 7000:1 post tweak.
I initially thought that maybe I could get it a little lower with a bit more tweaking, but I decided to not attempt it as my OCD personality would never let it rest (which is why I kept at it with my Eye One LT). .005 is very, very good if you ask me. I was actually impressed with the way my greyscale and primaries/secondaries have held up. It's been about a year since I did my last calibration, and I've decided to hold off on the calibration until my TV replaces my old projector in my theater room. But it looks like I'll just need to do a few things to get it back into spec. My gamma is still spot on at 2.20.
PSN ID/XBOX Live! Gamertag: BiffCo
My SD/HD movie collection
Big Brad is offline
post #738 of 1476 Old 01-12-2012, 06:48 PM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
Thanks for the update Brad.
Robert
Toronto, Ontario
post #739 of 1476 Old 01-12-2012, 07:19 PM
lifesun's Avatar
Great results! Is this measurement at 24p or 60hz?
lifesun is offline
post #740 of 1476 Old 01-12-2012, 07:34 PM
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Brad,
Have you changed any of your settings post tweak?
ratm is offline
post #741 of 1476 Old 01-12-2012, 08:15 PM
Big Brad's Avatar
Quoted: 300 Post(s)
Liked: 419
This measurement was done first at 24p, and that's where the .005 reading was obtained. My 60p measurements were slightly higher at .008. I know it should be the other way around, but I'm one of the few that get slightly lower MLL at 72Hz. I don't know why that is but I'll take it.
Originally Posted by ratm View Post
Brad,
None actually. I rechecked the pluge pattern on the AVS disc as well as DVE HD Basics and my brightness didn't need to be adjusted at all. I believe it's currently 52 for my PS3 and 50 for my 360 (both calibrated with my Eye One LT in Expert 1 and 2 picture modes). Going any lower on either picture modes results in the 17 bar on the AVS HD brightness pattern disappear completely, which isn't what you want.
A question was asked earlier in the thread in regards to my backlight setup. It's not as high-end as it may sound. I use an 18-inch fluorescent under-cabinet light with a 6500K bulb (both purchased at Wal-Mart). I fabricated a housing for it to not only help it sit on my TV stand, but to control light spill. Having a glossy base for the TV stand makes for some really bright reflections. The light is nearly against the wall, so spill is now kept to a minimum and there is a nice, light "glow" coming from behind the TV. A local friend has an Idealume backlight that I compared it to. My DIY version is not an exact match to his 6500K backlight, but it's so close to my eyes that I think anyone would have a hard time discerning a difference if not compared directly.
Big Brad is offline
post #742 of 1476 Old 01-13-2012, 01:26 AM
ubersonic's Avatar
Hey BB,what tweaks did you do on your pk550.I have had my 50pk550 since may 2010 and have noticed the black level has gone up.I found this thread and have read through it but it seems that every one has a little different method for the tweak.I love my pk550 and have contacted Chad B to do a pro calibration but if I can get the results that you and others have gotten I may hold off on having chad come by.
thanks,Uber.
ubersonic is offline
post #743 of 1476 Old 01-13-2012, 06:41 AM
lifesun's Avatar
My pv450 has lower MLL with 24p as well, That's why I was curious.
lifesun is offline
post #744 of 1476 Old 01-13-2012, 08:01 AM
rpauls's Avatar
thanks,Uber.
My experience is that the MLL tweak has no significant effect on the calibration except perhaps the slightest adjustment in brightness (+-1).
However, I would imagine Chad would be very interested in the success we've been seeing with these pot tweaks. You may want to ask him to perform the adjustment for you as part of the calibration?
rpauls is offline
post #745 of 1476 Old 01-13-2012, 08:05 AM
rpauls's Avatar
Most people reporting lower MLL at 24p seem to have a 50" model. However somebody last week had this same on a 60". Was that you lifesun?
I wish I could get my 24p lower, but I can not.
.007 at 60
.018 at 24
60PK540
rpauls is offline
post #746 of 1476 Old 01-13-2012, 08:18 AM
lifesun's Avatar
.007 at 60
.018 at 24
60PK540
Yes my set is a 60pv450
lifesun is offline
post #747 of 1476 Old 01-13-2012, 09:27 AM
schaefferdavid's Avatar
Have you measured the MLL of a 24fps input yet?
I finally go around to measuring it. It is slightly higher at .009 FtL.for 24 hz source (compared to .006 FtL. for 60 hz source). This is for a 60px950.
schaefferdavid is offline
post #748 of 1476 Old 01-13-2012, 09:30 AM
Kadajo's Avatar
Hi everyone, my first post here.
After spendnig whole day reading this wonderful topic i want to ask u that my PV350 has this tweak avaible also.
I dont wanna lose waranty and find out that its not possible with this set.
TV is from Poland.
Also can i ask u all to post some pics of yours tweaket sets in completly dark room with only black picture dispalyed.
Thnak you
My picture look like on this screen:
and this is i want at least:
Kadajo is online now
post #749 of 1476 Old 01-13-2012, 09:52 AM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
It would be informative to know which sources are being used, for Blu-ray I’m still using a Sony BDP S-500 and for streaming Netflix the Apple TV2 . Not too sure I’ve noticed a difference in MLL when switching between the two on a regular bases but a few times with the Sony and Blu-Rays I’ve noticed a slight shift in levels, not huge but noticeable even though the LG showed 24p/1080p each time as the source.
What is interesting though while viewing my brother’s Panasonic ST30 there was a major shift with streaming Netflix, especially between the Apple TV2 at 720dpi and the X-box at 1080dpi, the Apple TV was black but the X-box showed a very noticeable rise in MLL, like changing the brightness setting from 50 to 75 for example, Blu-rays on the X-box looked fine though.
Robert
Toronto, Ontario
post #750 of 1476 Old 01-13-2012, 10:06 AM - Thread Starter
rob80b's Avatar
Quoted: 65 Post(s)
Liked: 44
TV is from Poland.
Thnak you
Hi Kadajo
We all want that, 0 black.
Each set is different and results will vary, photos unfortunately can never tell the real story.
On my PX950, viewing black slides the screen is just a slight notch above 0 black before going to black (one only gets a second or two to see this), alternating between a black slide and a color or white slide, the black slide will of course appear as if the set has turned off as the eye needs a few second to adjust.
In any case you will get an improvement in MLL with the pot adjustments, how much is hard to predict.
Robert
Toronto, Ontario
