Help, glass screen on Samsung plasma is sliding down - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 11-16-2011, 05:52 PM - Thread Starter
Nebakanezzar's Avatar
All,
got this crazy issue, out of nowhere the glass screen on my pn50a650 is sliding down, now there is about a 1/2" gap where the plasma panel is exposed! (see attached pic)
called Samsung, TV is out of warranty so they wont fix it...anyone experience this issue before and/or have any idea how to get this fixed on the cheap?
thanx.
Little angel, go away...
Come again some other day...
Devil has my ear today...
I'll never hear a word you say...
He Promised I would find a little solace and some peace of mind...
Whatever. just as long as I don't feel so...
desperate and ravenous. I'm so Weak and powerless over you...
Nebakanezzar is offline
post #2 of 22 Old 11-16-2011, 06:18 PM
sloppojoe's Avatar
*edit*
Did not realize it was a three year old set.
sloppojoe is offline
post #3 of 22 Old 11-16-2011, 07:11 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
His tv is 3 years old what do you want them to do?? Get a repair tech out there everything is still functioning it seems there is probably some type of adhesive they can use to secure it back in place.
CaTaSTrOphiK is offline
post #4 of 22 Old 11-16-2011, 08:39 PM
yrly's Avatar
Have someone familiar with taking it apart do just that and slide the piece back into place. I'm not sure however how they mount the protective glass, that is another story.
yrly is offline
post #5 of 22 Old 11-16-2011, 08:48 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
turn it upside down
Loving D65
CalWldLif is offline
post #6 of 22 Old 11-16-2011, 09:00 PM
Sweetmeat's Avatar
Quoted: 302 Post(s)
Liked: 73
Wow, of all the things to go wrong and you have this problem. Crazy. I hope there's a cheap permanent fix.
PN59D8000 and JVC RS420 with Elite 120" screen
Receiver - Yamaha RX-A3060, WXA-50 MusicCast Amp for Zone 2
Front - CM9, Center - CMC2, Side Surrounds - DS3, Rear Surrounds - CM5, Front/Rear Atmos - CCM663, Subs - PB12+ and PB13 Ultra
Remote/Streaming Media Players - Harmony Elite, Apple TV 4, Nvidia Shield Pro - use with HDHomeRun Connect/Extend and Plex
Sweetmeat is offline
post #7 of 22 Old 11-17-2011, 08:30 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 521 Post(s)
Liked: 776
Samsung build quality FTL
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8 of 22 Old 11-17-2011, 10:47 AM
JoeBlow74's Avatar
Quoted: 14 Post(s)
Liked: 39
Has anybody ever felt the heat coming from any of the Samsung plasma TV's? They are all space heaters. I have noticed the thinner the Samsung plasma the hotter the screen is. I wonder if the heat has anything to do with this issue.
X-Box Live name: OGgamer1974
If you want to be friends on through xbox network, just send me a request through X-Box Live and mention AVS in the request.
Cheers
JoeBlow74 is offline
post #9 of 22 Old 11-17-2011, 11:50 AM
dlplover's Avatar
Probably. It sounds like they're just sticking the screen to the bezel with adhesive rather than framing it so it doesn't move. Either that or the plastic they were using to hold it in place was so cheap it just broke.
Actually, I would get that fixed STAT since depending on the cable layout and internals that could pose risk of ribbons being torn and/or something touching that's not supposed to, excess heat etc.. If it were me, I would not use that until it was remounted properly.
dlplover is offline
post #10 of 22 Old 11-17-2011, 12:00 PM
greenjp's Avatar
Quoted: 33 Post(s)
Liked: 38
No they're not. Space heaters put out 1,500 watts. Samsung plasmas probably run in the 200-350 watt range, and don't use anymore than a Panasonic or LG. What part of the TV that energy is concentrated in and how that affects your perception of the warmth may vary but rest assured there's no difference with other brands.
As to this particular set, this is obviously an unusual manifestation (I don't recall seeing anyone report anything like this on any set in my 4 years visiting) of a fabrication mistake or part failure. If this was a design flaw or materials issue (like those peeling screen coatings) we'd be hearing about it a lot more.
jeff
greenjp is offline
post #11 of 22 Old 11-17-2011, 12:17 PM
jrn23's Avatar
A bit off topic here, but I found it a bit humorous that the picture seems to capture the cheerleaders watching the screen drop.
pokekevin likes this.
jrn23 is offline
post #12 of 22 Old 11-17-2011, 01:00 PM
tomwil's Avatar
Liked: 26
Originally Posted by Nebakanezzar View Post
The glass screen on my pn50a650 is sliding down ...
The service manual is available free here. Although it doesn't explicitly tell you how to remove the front bezel to reposition the glass, it appears it is as simple as removing the back cover and removing the screws that hold the front bezel.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #13 of 22 Old 11-17-2011, 11:08 PM - Thread Starter
thanx all,
i have a call in to a tech, hopefully its a cheap fix...probably makes more sense to just buy a new one if not...maybe ill try seeing if it is easy to take apart myself.
post #14 of 22 Old 05-21-2013, 06:47 PM
jetfish's Avatar
I have this exact same issue with my 6 series samsung plasma, about 5 years old. Did you every get it fixed and if so how? This just happened by itself. First we noticed the remote could not turn off the tv, then a week later the glass dropped.
jetfish is offline
post #15 of 22 Old 08-24-2013, 06:30 PM
larryiscrazy51's Avatar
I also have this issue. I tried to take apart and get glass back. It worked temporarily,but rently fell again. Did you ever get yours fixed?
larryiscrazy51 is offline
post #16 of 22 Old 08-25-2013, 10:35 AM
loopguru's Avatar
I have a low-end this year's model from Samsung (PN43F4500) and in 'Standard' (Energy Star) mode, this plasma is quite a bit cooler than the smaller, 5 year old Sony Bravia LCD it replaced.
Good luck with the glass, OP!
loopguru is offline
post #17 of 22 Old 08-27-2013, 08:03 AM
TwoPlusone's Avatar
Get a repair tech out there everything is still functioning it seems there is probably some type of adhesive they can use to secure it back in place.65pFOdI don't recall seeing anyone report anything like this on any set in my 4 years visiting
TwoPlusone is offline
post #18 of 22 Old 11-18-2013, 11:17 AM
StillwaterTownie's Avatar
LOL, now the exact same problem has happened to my 50" Samsung plasma as pictured below. Like one other poster had, I was having some trouble with the remote before it happened. It wasn't always responsive. Since the last posting about it is so old, I don't have much hope for an easy fix. However, upon further inspection, the frame is loose at one corner from the adhesive strips no longer adhering. It appears I need to lay the set down on the its back side, pull off the frame, realign the glass in his proper place and find new adhesive to glue the frame back on. But what kind of adhesive? Ordinary adhesive strips?
StillwaterTownie is offline
post #19 of 22 Old 11-18-2013, 11:51 AM
ljmart's Avatar
Liked: 184
same here. my 2009 LG 42" LCD put out considerably more heat than my F8500 51" (not even in eco mode) sammy plasma!
Samsung PN51F8500 ~ Marantz SR5008 ~ Oppo BDP 103D ~ EMP Tek R55TiB LR, R56CiB, R55WiB ~ Sennheiser Momentum ~ Sennheiser 598
ljmart is offline
post #20 of 22 Old 11-18-2013, 11:58 AM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
This. haha
Any luck though with the repair? The last 2 plasmas I've bought always seemed to have issues after their warranty ended...Philips and those darn capacitors lol
pokekevin is offline
post #21 of 22 Old 02-04-2014, 12:05 PM
Hybrid AWD's Avatar
Same tv too: PN50A650.
Anyone has some input on a fix?
IMG_0244.JPG 1349k .JPG file
Hybrid AWD is offline
post #22 of 22 Old 06-24-2015, 03:00 PM
Liked: 0
I have the same issue exactly. I called Samsung they had a tech call me and were willing to pay labor. But the freakin Bezel can part they want to change is $1000. LOL They have a design flaw and are not dealing with it. As far as the guy who said "Its 3 years old get a tech" I don't think I want to pay $1000 every few years for a bad design flaw in their cabinet. Will be looking for a different Brand then next one. Sony LG I don't know. I don't ever remember Sony have badly designed products.
Willnnawlins is offline
