Clarity of the GT30 - why does my picture seem a bit blury?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-06-2011, 10:41 AM - Thread Starter
ryandz5's Avatar
Question, specifically for those who own or have calibrated the gt30 (I have the 60"). My problem is this - the TV doesn't seem as clear or sharp or as "high def" as I expect. This is especially true over Fios TV and dish network (I've had both connected), but I'm also not entirely impressed with the blu-rays I've watched - Tron, Dark Knight, Elf, among others. When a scene has a closeup on someones face, the clarity is close to what I'd expect, but on scenes where they show people zoomed out a little (head to toe), it almost seems blury. Color, brightness, etc. are fine, it's just clarity. But combing through the various boards, I've NEVER seen a similar complaint.
I have had this TV for about 3 weeks now and am getting near the end of my return period. I'm freaking out a little not knowing what to do. Returning is a little bit of work since it was delivered and I have a somewhat custom setup using the supplied brackets in a custom fashion with my own stand. Every day I stare and am less impressed. I plan to go to other stores today to do some more staring at their sets. My understanding is that it should be clearer at home connected directly to my blu-ray under dim lights. Any comments or suggestions would be appreciated, especially on your own take on how clear your sets are. And should calibration make any noticable differnce in clarity (I'm running THX mode with the settings from CNET, and I've played around extensively with modifying them and with other modes).
ryandz5 is offline
post #2 of 11 Old 12-06-2011, 11:19 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Do you have the TV's HD Size setting set to HD Size 2 (which gives 1:1 pixel mapping?). That makes the image crisper than using HD Size 1.
Are you sending a 1080i or 1080p signal to the TV? Or are you sending it at 720p? I've found that forcing all my sources to output only 1080i fixed makes everything a little crisper and more detailed than when it comes through at 720p.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 11 Old 12-06-2011, 03:06 PM - Thread Starter
ryandz5's Avatar
I am using HD size 2. And I am forcing 1080i from fios and forcing 1080p from blu ray.
ryandz5 is offline
post #4 of 11 Old 12-06-2011, 03:30 PM
Dierkdr's Avatar
Liked: 54
...TV doesn't seem as clear or sharp or as "high def" as I expect. This is especially true over Fios TV and dish network...
Size seems to matter, and am not surprised to hear of "cable" tv showing softness &/or increased artifacts: we recently moved from a 50" to a 60" in our "home theater" and the 60 definitely is not as "forgiving" of program flaws as the 50" was!
That sounds more problematical: No. 2 Son has a 55" GT30 and PQ on blu-rays is Great - and they are using almost exactly the Default THX settings. "Motorcyle" sequence in Dark Knight was particularly impressive: nice deep blacks, lots of shadow detail, and clearly evident color on Joker's outfit.
Our 60" ST is not quite as impressive during that same sequence - but it is reasonably close, and certainly would NOT complain about "softness" on the blu-rays (or HD-DVDs) we've sampled thus far...
Dierkdr is offline
post #5 of 11 Old 12-06-2011, 08:40 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
The HD 2 setting isn't applicable in the full screen mode. At least not on my set. Regardless, I would recommend you set your Fios receiver to native and let your TV do all the scaling. Double scaling can introduce artifacts:
http://www.avsforum.com/avs-vb/showt...1#post21283891 (point 4)
Also, make sure your Blu-Ray player is set to 1080p rather then auto, with some players the auto setting may not pixel map as well as doing it direct.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #6 of 11 Old 12-07-2011, 10:55 AM - Thread Starter
ryandz5's Avatar
Ian
Thanks for the info Ian. Based on some earlier research, I have 'set fios to native' on my list of things to do. I haven't determined how to do that yet. I've heard it may be available in a software update I dont yet have (1.9a).
ryandz5 is offline
post #7 of 11 Old 12-07-2011, 11:29 AM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
Do you have an HDTV listing on your Fios receivers set up menu? If you do, that it is probably the most likely place you will find that setting.
Ian
mailiang is offline
post #8 of 11 Old 12-07-2011, 01:59 PM
IamAnoobieCheez's Avatar
Location: I come from a distant space where no one has gone before. The temperature is aight. The planet has a purple sky tho and the gravity is slightly less than that of earth. Oh yeah I got plenty of gas.....
ANYTHING on cable TV, dish, or anything like, will have crappy soft blurry pictures.
If you use component cable for the blu-ray player it will give you softer (blurry) pictures.
You have to use DVI + PC and play video files off it. That is the only way it will give you clearest sharpest crispiest crunchiest pictures.
This is hilarious...
IamAnoobieCheez is offline
post #9 of 11 Old 12-07-2011, 02:00 PM
Oh and 1:1 pixel mapping.
LMAO
post #10 of 11 Old 12-07-2011, 03:03 PM
mailiang's Avatar
Quoted: 970 Post(s)
Liked: 641
Hilarious?
Since he took the trouble of going on C-Net to get help with his THX picture settings, I assume he is using HDMI. I have DTV and most HD programs are not blurry. Many of the satellite stations (non OTA) are very good and some shows like AMC's Hell On Wheels and Starz's Strike Force are close to BD quality. I would think based on the ratings, (ie: consumer reports, JD Power) that Fios would also offer similar PQ.
Ian
mailiang is offline
post #11 of 11 Old 12-07-2011, 03:56 PM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 126 Post(s)
Liked: 89
Most 1080i delivered to my Panny 65" is crisp and clear (and I am fussy). Most BD is fantastic in terms of clarity.
42" in the dining room. 50" in the bedroom. 80" in the living room. 65" in the family room. 70" in the family room. 106" in the family room "This is the voice of world control" Video Modes:EDTV-XGA-HDTV-4K HDR
Star56 is offline
