Windex, plasma, and 1 idiot - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 12-28-2011, 06:24 PM - Thread Starter
Wowza's Avatar
Originally Posted by RicheyPoor View Post
I know this is risky, but have you thought of using the same product to remove the rest of the filter? If it came off that easy, it shouldn't be hard to do. You'd probably get more glare but at least it wouldn't drive you nuts every time you saw it. Of course, it might just make it worse - tough call...
You've been reading my mind. I actually think I could take it off fairly easily but you're right...I could make it worse. I'm thinking that in the interst of science I will try it and report back. I wish I could post pictures that would accurately capture this mess.
Wowza is offline
Old 12-28-2011, 06:26 PM
Otto Pylot's Avatar
Quoted: 1363 Post(s)
Liked: 854
Would that void your warranty should it not work well and you want to return it?
Otto Pylot is offline
Old 12-28-2011, 06:29 PM - Thread Starter
Wowza's Avatar
[quote=KidHorn;21408118]If you can't notice anything when the TV is on, then stop being anal and just live with it. Who cares what it looks like when it's off? It's a big ugly black rectangle and nothing you did could possibly make it any uglier.[/
I would've thought the same thing when I was 19.
Wowza is offline
Old 12-28-2011, 06:31 PM - Thread Starter
Wowza's Avatar
This set came with the house so that's a non issue. I'm not even sure how old the set is. Any way to tell from the model?
Wowza is offline
Old 12-28-2011, 06:48 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
There was a nutjob here called something like IamNoobieCheez that took a buffer to his Panasonic's AR filter to remove it and he said he liked the picture better without the filter. A long time ago another guy used a razor blade to scrape his damaged filter off - it took him several hours and i think it left scratches in the glass. I would just continue to remove the rest of the AR filter until it's just plain glass (don't scrape with razor blades). The current entry level model (TC-P42X3) does not come with an AR filter and it still looks pretty good (albeit pretty reflective).
FWIW, the TH-42PX20U is a 2004 model that was selling for over $4,000 back then. I almost bought one as my first plasma but i chickened out
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 12-28-2011, 07:06 PM - Thread Starter
Wowza's Avatar
That is hilarious. I think that's what I'll do sans razor blades. This is the most useful and helpful forum ive ever seen, btw.
Wowza is offline
Old 12-28-2011, 07:49 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
That outer glass that the AR filter is applied to is separate from the actual glass plasma panel underneath, and there is probably about a quarter inch of space between the two panes of glass so don't press too hard on the outer glass as there's nothing supporting it in the middle.
If you're handy, you could completely remove the outer bezel and that damaged outer glass (requires removing the rear cover first IIRC) if you want to do a thorough job of removing the filter from edge to edge (instead of trying to remove it right up next to the bezel).
And if you destroy it, used 42" plasmas are available on Craigslist for only a few hundred bucks
Randy
Old 01-02-2012, 11:58 AM
mook_johnson's Avatar
Just for reference I use Stoners Invisible glass and a good soft microfiger cloth.
I've wiped down the screen of my 58PZ800u dozens of times with this and never had a streak or marring. It even cleans the shinny black bezel around the screen flawlessly.
mook_johnson is offline
Old 01-02-2012, 02:24 PM
obveron's Avatar
Quoted: 17 Post(s)
If you wanted to wash the whole AR coating off, just get some pure ammonia and go for it.
My GF once wiped my CRT HDTV with Windex and put streaks into the AR. I bit the bullet and washed the AR completely off. In my mind I wanted it uniform, either perfect AR or none at all. Once I had the AR coating off, it was a breeze to clean it afterwards so that was a bonus.
obveron is offline
Old 01-04-2012, 12:58 PM - Thread Starter
Wowza's Avatar
Well, the report: I also bit the bullet and took the AR coating completely off. It came off relatively easy, which leads me to wonder whether this coating becomes less stable (and thus easier to remove) over time. Who cares, I hope to never have to find out again. Anyway, the result is great, crystal clean glass. The days are still pretty short here in Maine, so the lack of AR doesn't yet seem to bother me. Frankly, I agree with whoever noted another member who liked it better without the AR. I do too.
Anyway, thanks for the help, and I've learned a valuable lesson, and tips, for cleaning my next plasma...which won't be far off. Thanks all.
Wowza is offline
Old 01-04-2012, 02:38 PM
Otto Pylot's Avatar
Liked: 854
Glad it finally worked out for you. A lesson for us all.
Old 01-04-2012, 04:55 PM
LanceX's Avatar
Quoted: 84 Post(s)
Liked: 30
how did u remove it wow?
LanceX is offline
Old 01-05-2012, 05:22 AM - Thread Starter
Wowza's Avatar
I used the same product I initially used to start this whole mess: Windex Powerized Original with Ammonia-D. I think this stuff would strip oil based paint from a 300 year old New England church if you're a painter in a pinch.
Wowza is offline
Old 01-05-2012, 06:15 AM
GSDTrainer's Avatar
Ahhh that explains this whole thread, you're a Mainiac!!!!
OT: What do you call a woman in Maine with all her teeth?
A tourist!!!!
Sorry Im from NH I couldnt resist!
GSDTrainer is offline
Old 01-05-2012, 02:00 PM - Thread Starter
Wowza's Avatar
I'm from Falmouth, so not so much.
You know you're from New Hampshire if you don't think a liquor store in the middle of the highway is unusual.
Wowza is offline
Old 01-05-2012, 03:31 PM
GSDTrainer's Avatar
You mean they are not supposed to be on either side of major highways???? I am shocked I say, SHOCKED!
Old 01-06-2012, 08:55 AM
ttwomotor's Avatar
FWIW - Windex now has a product they claim is for cleaning TV screens, computer monitors, etc. Work at an ACE Hardware support center - put it in an order for the first time yesterday, plus they now have a line of dry and wet cleaning cloths for the same electronics.
Twomotor
ttwomotor is offline
Old 01-06-2012, 09:16 AM
sigma1038's Avatar
Is it worth getting the monoprice Blister pack for a few bucks? What about an anti-static brush?
Universal Screen Cleaner (Large bottle, blister pack) for LCD & Plasmas TV, iPads, iPhones, Galaxy Tabs, and smartphones
You may not have noticed, but after a while, your bright and beautiful screen may have lost some of it's original luster. Much of that is probably due to air-borne dust and dirt that have accumulated on the screen's surface. This thin layer of dirt reduces your screen's clarity, brightness and color accuracy. The solution is simple. Give it a good cleaning.
But many household cleaners contain active ingredients that can damage your screens sensitive surface. Many screens have special coating that can be broken down if you use the wrong cleaning cleaners and clothes. These cleaners are great for all kinds of LCD displays including portable devices like the IOS devices (iPad/iPhone/iPod), smartphones, Galaxy Tabs, etc. Monoprice cleaning kits come with specially formulated solutions designed specifically for modern electronics and microfiber cleaning clothes that will not scratch delicate surfaces. The cleaning liquid is alcohol free and leaves a streak free finish. Easily remove the fingerprints and grime from your screen.
Features:
200mL Non-Drop Cleaning Liquid
Alcohol-free solution
30X30cm Microfiber Cloth
One set in blister packing
sigma1038 is offline
Old 01-06-2012, 07:06 PM
lifesun's Avatar
To the OP, glad you got the issue worked out! I had a mess myself one time cleaning the mirror inside a CRT RPTV, I had streaks and film everywhere from Windex......learned my lesson way back. It took hours to get it clean!
So.....ever since then, I took the advice from the RPTV forum years ago, and now I use this product on all of my sets, Plasma and LCD and have never had streaks or any issues: http://www.spraywayinc.com/products.php?id=050 Its also cheap, less than 3$ a can at Walmart.
Also, I tried the monoprice cleaner with the microfiber cloth.....terrible, left streaks everywhere...
lifesun is offline
Old 01-11-2012, 02:44 PM
superstein61's Avatar
the monoprice cleaner and MF cloth works great for me
superstein61 is offline
Old 05-22-2013, 10:24 PM
mj0626's Avatar
I know this has been a long time since you posted, but I did the same thing a few months ago. Did not read owners manual and without thinking sprayed my new 50" plasma with Windex. I noticed the next time I was cleaning that I had small spots on it that looked like specs of wax or something. Being stupid, I again did not look at the owners manual and sprays Windex on cloth then wiped. At this point my husband started to mention that he saw streaks on screen when it was off. It was then that I decided to took at the manual and saw my oops. I had nowhere to turn, tried water, soap and water, almost thought it was permanent. We just tried vinegar and water, and dried with lint free cloth. It seems to have fixed it. Hope everything worked out for you.
mj0626 is offline
