Panasonic GT30 60" with Monoprice 6517 Mount - AVS Forum | Home Theater Discussions And Reviews
Old 12-26-2011, 09:36 AM - Thread Starter
marley1's Avatar
I have purchased the ST30 60" and need an articulating mount. I have used Monoprice ones before and like the quality and pricing. I was looking at the 6517 http://www.monoprice.com/products/pr...seq=1&format=2 but have read some comments that it requires modification. Is that going to the be the case? Will it be easy modification or should I look at another brand?
marley1 is offline
Old 01-16-2013, 09:11 PM
sackling's Avatar
Hi Marley, Did you ever end up buying this mount and if so did you have to modify it?
I am looking to get it for the next years model so I assume similar VESA pattern etc.
sackling is offline
