Buzzing panasonic st30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-27-2011, 02:16 PM - Thread Starter
cohenrs's Avatar
Hi
Please can someone advise me. Just bought a 50" st30 yesterday and had to return because the buzzing was driving me mad. I sit about 10 foot away and had turn the vol up to 20% plus before the buzzing was in audible. In terms of positioning, it is about half a foot from the wall. I can hear the fan but as its a constant it is not so annoying but the buzzing was crazy up an down depending on the contrast.
I have ordered another (got it a little cheaper too) hoping it is just a clanger. Can someone tell me is this going to be a problem that will not go away and should I just sack off Panny's altogether. I currently have a37" px70 and the buzzing is so slight I have never noticed it
Thanks in advance
Rich
cohenrs is offline
post #2 of 10 Old 12-27-2011, 04:35 PM
Dierkdr's Avatar
Liked: 54
Other than on a couple of solid-color slides - with no other background noise - buzzing has NOT been audible on our 60" ST30 at normal viewing distance of about 9 feet.
Wish I could say the same for the Visibility of the Green Blob & Pink Tint this set suffers from - and for which it will doubtless be returned.
Green IS getting better - but Pink is most certainly getting worse...
Dierkdr is offline
post #3 of 10 Old 12-27-2011, 07:48 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Originally Posted by cohenrs View Post
HiPlease can someone advise me. Just bought a 50" st30 yesterday and had to return because the buzzing was driving me mad. I sit about 10 foot away and had turn the vol up to 20% plus before the buzzing was in audible. In terms of positioning, it is about half a foot from the wall. I can hear the fan but as its a constant it is not so annoying but the buzzing was crazy up an down depending on the contrast.
That TV was defective. It's not normal to be able to hear it at 5 feet away much less 10 feet. I recently set up a friend's 60ST30 and it's virtually silent at 3 feet away which is as it should be and we can't hear it at all at 8 feet even while watching the slides. I know two other people with ST30s and they report no problems and no buzzing. Your replacement will probably be fine.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 10 Old 12-28-2011, 01:04 AM - Thread Starter
cohenrs's Avatar
Thanks for the feedback
Rich
cohenrs is offline
post #5 of 10 Old 01-09-2012, 01:23 PM
CSIG1001's Avatar
Liked: 25
I have buzzing but you have to put your ear up to the back of the tv. Plus i am currently driving the panel at 100 contrast doing the burn in procedure might make it louder. When you are in front of the tv you cant really hear anything. I dont think panasonic makes a tv that doesnt buzz. Although my 50GT25 was alot quieter . To hear a buzz at 8-10 feet would be pretty bad. Is that actually possible lol
CSIG1001 is offline
post #6 of 10 Old 01-17-2013, 05:30 PM
feadin's Avatar
Just wanted to let you know that my buzzing issue was fixed (and paid by Panasonic, under warranty). A technician first tried to change some screws, but that didn't work, so a new power board was brought in and that did the trick!
feadin is offline
post #7 of 10 Old 01-17-2013, 06:13 PM
sloaphone's Avatar
yeah.A technician first tried to change some screws, but that didn't work, so a new power board was brought in and that did the trick! 1.gif
sloaphone is offline
post #8 of 10 Old 12-27-2014, 07:21 PM
taxi_driver's Avatar
my 46" st30 has had the buzzing off and on, though more recently gotten louder and worse. I'm out of any warranty and a major tech noob so my options are somewhat limited.
any sage advice or ideas?
taxi_driver is offline
post #9 of 10 Old 12-28-2014, 12:29 PM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
It may be a simple fix (possibly loose board screws, or a bad board in the upper corner). Here are a few threads with info:
How much buzzing is acceptable on a panasonic plasma?
Panasonic ST30 55" Buzzing
Randy
post #10 of 10 Old 12-28-2014, 06:00 PM
I did read these and even at that level, I'd feel much better leaving the work in the hands of a professional.
