Question about new plasma TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-28-2011, 08:25 PM - Thread Starter
TvNoob24's Avatar
My apologies if this has been answered before. I picked up a 43" Samsung 720p Plasma TV on boxing day, model code: PN43D450. I hooked it up to my Xbox 360 through component cables and set the console setting to 720p. After playing a few games I noticed the text to be a bit on the pixelated side out of curiosity I changed the Xbox settings to 1080p and it looks much better now. When I press the INFO button on my remote it does indeed say 1080p. I'm just curious as to why it would look better when set to 1080p if it's a 720p TV. Lastly, I know I may sound paranoid here but will this harm my TB in any way if I keep my Xbox setting to 1080p? Sorry if this are really basic questions, I'm really clueless when it comes to TV's thanks in advance!
TvNoob24 is offline
post #2 of 8 Old 12-28-2011, 10:31 PM
thewayout2217's Avatar
Im not sure why it displays better in 1080p but since your samsung is a 720p tv, there is no possible way to display 1080p as your tv does not have the resolution to produce that. Basically, it is not displaying in 1080p. The "1080p" message you see on the screen is just the resolution of your input (in your case the xbox input is set at 1080p, you should change it to 720p) All your TV is doing is automatically converting it to 720p to put a 1080p picture on your screen. Also, 1080p (if your set was a 1080p tv) can only be displayed using an HDMI cable, components are not capable of handing that.
If 1080p was able to be produced on a 720p set, there would be no reason for 1080p tvs and their added cost
thewayout2217 is offline
post #3 of 8 Old 12-29-2011, 12:44 AM
Joxer's Avatar
Those sets are not usually truly 720p (1280x720) they are sold as "720p class" usually since the actual native resolution is often higher 1366x768.
So scaling is involved no matter if you input 720p or 1080i/1080p sources.
Its preferable to scale down from a higher resolution source as you saw. No harm at all in doing that, in fact its recommended.
What a TV shows as information is about the source input resolution (like 1080p) not what the display's actual output resolution is however.
Joxer is offline
post #4 of 8 Old 12-29-2011, 01:01 AM
ChuChu Flamingo's Avatar
I wonder why they make it 1366 x 768 instead of 1280 by 720? Baffles me.
ChuChu Flamingo is offline
post #5 of 8 Old 12-29-2011, 05:22 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
It's just panasonic that can't handle that. The 360 has a component cable for it's ability to output 1080p to a display. Since I have a panny I need a hdmi cable, kind of silly I know, leaving that feature out.
whipit is offline
post #6 of 8 Old 12-29-2011, 07:00 AM
KidHorn's Avatar
Quoted: 1375 Post(s)
Liked: 883
Leave the output at 1080p. No matter what the input resolution is, your TV will always convert the signal to it's native resolution.
KidHorn is offline
post #7 of 8 Old 12-29-2011, 09:37 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
To be honest it's no big deal. I actually have a 32" Toshiba with a static resolution of 1280X720 and it doesn't look any better then on a 768p set.
I agree. And if you are using a top box for your broadcasts ( ie: Cable, Fios, Satellite) for best results, set it to native. You don't want more then one devise in your signal chain to be doing the scaling, which can introduce artifacts.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #8 of 8 Old 12-29-2011, 11:25 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Ian
From what I've seen on my cable dvr it all looks sharper with the DVR outputting 1080i, but my tv is 1080 so THAT can be a difference, not sure about the 720 tv's. Damn, so many options anymore, not simple like it used to be, hehe.
whipit is offline
