thomson wysius 42 plasma help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-02-2012, 11:42 AM - Thread Starter
jeno1976's Avatar
i have thomson wysius 42 plasma one of the first plasma with the separate tv tuner box which i have now got rid of so im left with the monitor its self which has rgb in and out and dvi in all at the back my question is i want to connect a sky or cable box etc into the dvi socket at the back so i connected a hdmi to dvi socket from the cable box to connect them with no results just unsupported format on the screen im guessing my tv monitor isnt hd but id still get a picture right ? but nothing so does anyone know of any video converters that would convert a hdmi to dvi succesfully as im not good with things like this but im sure its not just a lead i need if only it where that simple any help or advice on getting this working this way id be very grateful the monitor itself has no scart socket and the vga lead is taken for an xbox so i need it to be connected on the monitor dvi socket and the cable end not much option hdmi socket or scart ???
jeno1976 is offline
post #2 of 4 Old 04-26-2012, 03:49 AM
johnnyboy jo's Avatar
hello did you sort this out? i have the same problem ??
johnnyboy jo is offline
post #3 of 4 Old 11-13-2012, 06:17 AM
Mark Perry31's Avatar
did you have any joy connecting your thomson plasma to sky box using dvi to hdmi ,ive got the same problem
Mark Perry31 is offline
post #4 of 4 Old 11-13-2012, 08:34 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
We don't have this model here in NA - try the UK-based AVForum instead: http://www.avforums.com/forums/plasma-tvs/
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
