***STUMPED - Samsung PN50B650S1 - Vertical Green Line of single pixels - WHY? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Davlee1972
  • 1 Post By AVNYC
  • 1 Post By SlamKeys
post #1 of 24 Old 01-04-2012, 07:42 AM - Thread Starter
ckennel's Avatar
Hi there. First time post but hoping someone can help me speak a bit more educated to a TV Repair shop.
I have a Samsung PN50B650S1 Plasma which is about 2.5 years old (out of Warranty) and this past weekend a single line of green pixels has shown up from the top to the bottom of the screen. The lines are present on all inputs but they do go away now and then depending on what is on the screen.
Does anyone have any ideas on what part of my TV is malfunctioning? I would like to get this repaired if I can but I don't know where to start.
I have uploaded two photos that hopefully illustrate my issue.
Many thanks for any advice and if anyone has an honest TV Repair shop in LA (Westside) let me know.
-Christian
ckennel is offline
post #2 of 24 Old 01-04-2012, 11:47 AM
eagle-sas's Avatar
I have Samsung PS50B550, one year old.
In my opinion there is a fault in the Column (TCP) Driver Integrated Circuit.
I think is not worth repairing this two and a half years old plasma.
I am not an expert, in point of fact.
a
eagle-sas is offline
post #3 of 24 Old 10-25-2012, 08:28 PM
Davlee1972's Avatar
Did you figure out the problem? I have a 2 or 3 year old Samsung PN58B650 which has the same problem. Exact same green vertical line a couple pixels wide..
I'm thinking some dust got inside from some recent construction and something may need to be cleaned..
Davlee1972 is offline
post #4 of 24 Old 10-25-2012, 09:24 PM - Thread Starter
ckennel's Avatar
Ha...this one's pretty funny. I didn't find any info on my issue online so I unplugged everything and took it in to a small reputable repair shop here in Santa Monica. I showed the repair guy the photos and he said my plasma was broken and it wasn't worth fixing. "That's what I get for buying a cheap plasma". I have actually been quite happy with my Samsun up until this point. I was kind of bummed as I drove home partly because I feel like TV's should last longer than 2-3 years but I guess I am in the minority because everyone told me that my Plasma was 2 years old and of course it's going to be bad. Shocking. Anyway, here's where it gets funny. I wasn't sure what I was going to buy next so I figured I would plug the TV back in and suffer along while I did some research. To my amazement, the green line was gone and has never come back. Too funny. I think it must have rumbled around in my car just enough to make a difference. I still have an issue where my TV signal will lose connectivity when I am using my DVR heavily with lots of skipping forward and backward but I just unplug the HDMI cable and it seems to reset the issue. That is an entirely separate issue and I haven't bothered to see if anyone else has any issues. Let me know how it goes.
Cheers!
ckennel is offline
post #5 of 24 Old 10-25-2012, 09:45 PM
ATC7's Avatar
Hope it stays that way, although from my past experience with what looks like the exact same thing, it may get worse.
My old two Panasonic plasmas (PZ77 and a G15, both 50") both developed the same thing, at around 26 months of ownership. (sorry for the large pics)
Only in my case it never went away, but a few weeks later it progressed and became an inch-wide black (dead) vertical bar in roughly the same location.
On both occasions, the Panasonic tech came out and diagnosed it with a panel failure (maybe the wrong diagnosis?) and recommended a complete panel replacement ($2000+ repair estimate), of course it was under a store extended warranty and the store replaced the TV outright. Hope your issue is different.
ATC7 is offline
post #6 of 24 Old 10-26-2012, 11:55 AM
Davlee1972's Avatar
I did some research last night and even went into the service menu to run the different test patterns.
This is what I found out.
The green vertical line is a result of a dead red subpixel. On the horizontal test pattern with white, red, green and blue bands the white band had a faint green vertical line, green band was fine, the blue band was fine and the red band had a vertical black line running through it which meant the red pixels were not firing.
I think a single dead pixel can sometimes cause an entire line of pixels to go dead so the problem is somewhere in the panel.
I had a recent construction job which kicked up a lot of wood dust and the TV was not properly covered. I'm hoping that the pixel is not really dead and a good internal cleaning / massage will reactivate the pixel in the pnael
That 1 inch black vertical band looks like a problem with the circuit board or the pannel connector. The circuit board can probably be replaced, but a bad panel is not worth fixing.
Here are some photos from my testing.
post #7 of 24 Old 10-26-2012, 01:04 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Sometimes this is caused by a loose or poorly seated ribbon cable connector where it attaches to the panel module. Re-seating it or wiggling it may fix the issue.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8 of 24 Old 10-27-2012, 01:23 AM
Davlee1972's Avatar
Took me three hours but I fixed it. Traced problem from the center logic board to the panel.
Checked main logic board by disconnecting ribbon cables.
Checked ribbon cable between main logic board and middle panel logic board by flipping it around.
Checked middle panel logic board by connecting ribbon cable from right panel logic board to middle panel logic board.
Checked display ribbon cables to middle panel logic board.
One of those ribbon cable connectors needed to be cleaned. No more dead line of pixels.
vavan likes this.
post #9 of 24 Old 10-27-2012, 06:32 AM
ATC7's Avatar
Wow, that's awesome. If my set is out of warranty I'd definitely try that. I recall when my TV developed this issue and the Panasonic rep came out, he did take off the back cover and tinkered with boards and cables for over an hour before before diagnosing a complete panel failure. IIRC he did swap out at least two boards and a few cables. I guess in my case it was a bad panel.
ATC7 is offline
post #10 of 24 Old 12-23-2012, 08:06 AM
cootertwo's Avatar
After VERY MUCH READING, have found that many manufactures, mine is a 42" Panasonic TH42PX75U, have TINY IC's "made" into the ribbon cables that come out of the panel. NOT REPAIRABLE. Cwappy design, but it's what it is.
cootertwo is offline
post #11 of 24 Old 05-02-2013, 08:11 AM
comatosevessel's Avatar
I have this exact same issue except it's farther right on the screen. So did you unconnect those cables at the bottom of the panel and clean them and reattach them? Or did you just somehow magically clean them and not unattach them? If you cleaned them what did you use and was it easy to disconnect and connect the ribbon cables? Did it look like it obviously needed cleaning?
Chris
comatosevessel is offline
post #12 of 24 Old 09-26-2013, 07:58 AM
mumbles3k's Avatar
Hello,
I'm having this issue too with a 4 year old Samsung PN50A510. I've had a light blue line about an inch from the edge on the right side for years now. That one doesn't really bother me. But yesterday, while watching a movie, a dark purple line appeared much closer to the middle of the screen, and it's far more distracting.
Here's the thing. About a week ago, I had a massive power surge during a storm which took out a PS3, a hard drive, and little light which were all plugged into the same surge protector as the TV. The TV seemed to be unharmed. My insurance covers power surge damage, but I have a $500 deductible, so I haven't put in a claim. However, if this line is a result of the surge, then I definitely should.
So my question is, could this new line have been caused by the power surge?
mumbles3k is offline
post #13 of 24 Old 02-18-2015, 01:33 PM
Liked: 0
I didn't know if it was better to bump this thread or start a new one, but considering that I'm having the same exact issue I thought it might be worthwhile to bump it.
I'm having this issue on an out-of-warranty Samsung PN51D490A1D. I tried disconnecting every ribbon cable and cleaning them with isopropyl alcohol (a few times) with no luck.
I'm mostly just wondering if this is for sure a panel issue, or if a certain board tends to fail. It seems like board failures present symptoms far worse than this, but electronics repair isn't exactly my specialty so I only know what I've read thus far (which has been far more people complaining about problems than solutions.)
Any thoughts?
NoDoz is offline
post #14 of 24 Old 03-01-2015, 03:10 PM
je2ep's Avatar
I have an exact same issue. The TV is brand new, less than 4 months PN51F8500, so their top of the line and it had a blue/green line running thru the middle. Have scheduled a service call but they don't have the part in stock, so still waiting, will update once they fix it.
je2ep is offline
post #15 of 24 Old 03-05-2015, 11:23 PM
je2ep's Avatar
The tech. came out and replaced the panel. He said this is not a common problem though I have my doubts. The Samsung support knew exactly what was wrong just from my 1 call. That has got me worried that what's the life of these Samsung panels. I have not had any issues with my 2 Panasonic Plasmas.
I did get a Korea panel this time. The original panel was a Mexico panel, though it seems all their panels are made in Korea.
je2ep is offline
post #16 of 24 Old 05-15-2016, 03:29 PM
Liked: 0
thin vertical line
hi,,,
i have samsung f8500 64inch with thin vertical line on the left side of the screen ( near the middle ) ,my tv suffering from this for about 1 to 2 weeks,first time its gone ,but now it came back ? using the tv for about 20 months,,,, do you think the problem from the panel ? or ? and how much it will cost ? does changing the panel help to fix ( problems ) from the old panel like (image retention or some image burn) ? my tv now have a little image burn because i am using it as a pc monitor ,
sorry for my english
componenty is offline
post #17 of 24 Old 05-17-2016, 10:39 AM
mrkevindang's Avatar
Wow, so my Samsung Plasma TV just started having this problem.... green line down the screen. It doesn't sound like there's a guaranteed fix, but will try cleaning out the TV and reconnecting the ribbon cables.
mrkevindang is offline
post #18 of 24 Old 05-18-2016, 01:52 AM
je2ep's Avatar
Originally Posted by componenty View Post
hi,,,
If the problem is with the panel it is not worth getting fixed. Some folks have tried reconnecting cables which has worked for them.
je2ep is offline
post #19 of 24 Old 05-19-2016, 08:05 PM
andy2000's Avatar
A vertical line is usually caused by the failure of one of the column driver ICs. These ICs are part of the ribbon cables which are permanently bonded to the panel, so it means you have to replace the whole panel. Technically they could be replaced, but not without some very specialized equipment and expertise that you're unlike to find outside of a plasma panel factory. Back when they cost $10,000 I'm sure they sent the bad panels back to the factory for repair, but those days are long gone.
I suspect that sometimes the failure is in one of the connections between the IC chip and the ribbon cable, or where the cable is bonded to the panel. In that case, disturbing the cable by unplugging it to clean it, or the vibration from a car ride might be enough to have it make contact again. It probably won't last, but you might get lucky.
andy2000 is offline
post #20 of 24 Old 10-14-2016, 01:00 PM
AVNYC's Avatar
Liked: 1
I've had the Samsung PN51F8500 for 3 years and recently a thin vertical green/blue line appeared right down the center of the display. Of course the plasma TV is out of warranty and I feel so cheated by Samsung because this problem sounds quite prevalent and it probably should have been recalled. But in light of the recall fiasco with Samsung's Note 7 phone exploding and catching fire, it doesn't sound like Samsung as a company cares about putting out great products; it seems like speed and greed to get something into the marketplace is their modus operandi.
Based on threads posted in AVS Forum, I decided to take the back panel off, cleaned every ribbon cable contact, re-seated every cable to ensure that they were secure with the HOPE that this effort would resolve the issue BUT in my case it was an exercise in futility; the problem still persists.
I will NEVER EVER buy a Samsung product again!!!
Name:	Samsung PN51F8500-1.jpg
ID:	1716249   Click image for larger version
Name:	Samsung PN51F8500-2.jpg
vavan likes this.
AVNYC is offline
post #21 of 24 Old 10-14-2016, 04:56 PM
Mathesar's Avatar
A shame Samsung couldn't make a reliable plasma, they had great picture quality while they lasted.
The crappy part is I had convinced a friend to buy Plasma back in 2013 (they were planning on LCD) and they ended up with a Samsung PN64E533, Amazing picture quality but awful reliability.. after the 4th (!!) failure in 3 years the warranty company ended up replacing it with another brand TV altogether (Hitachi 65 "LCD), The LCD can't compete in terms of PQ but they're just happy that it actually works (so far).
Mathesar is offline
post #22 of 24 Old 04-07-2017, 04:41 PM
Liked: 1
My PS51F8500 (EU) is affected too. The first time it appeared was when still it was in warranty and Samsung replaced the panel. Now that the warranty has expired I have a beatiful line again and the yoffer my a "repair" for 750€. Because they don't have any more panels they have to offer me a new TV (paying the 750€ of course). After 2 weeks I don't know which tv are going the send be but in terms of quality it will be veeeery worse.
I don't know how things work in the USA but here the manufacturer must have replacement parts for at least 5 years after the product has stopped production. This is why they MUST offer me something if I want to repair it
noizer is offline
post #23 of 24 Old 04-23-2017, 11:23 PM
SlamKeys's Avatar
Did you look at the green board at the very bottom of the panel? I don't know what it's called but it isn't readily accessible. Anybody know what that board is called or what part number it is? I saw it when I took the back panel off of my PN51F8500 but I didn't try to expose it to see if it has ribbon cables attached to it. There must be some ribbons along that axis though.
Why shouldn't we list our equipment in our signatures? That's weird.
SlamKeys is offline
post #24 of 24 Old 04-27-2017, 10:02 PM
SlamKeys's Avatar
I found this explanation from an ebay electronics seller about the board that runs along the bottom of the PN51F8500 panel. This aligns with everything I've read about vertical line issues on the Samsung plasma:
Complete board set for all Samsung Televisions which include "PN51F8500" in the model number. These parts have all been personally tested by me. The only boards not included are the long, thin driver boards which run the bottom length of the plasma panel. These boards are not considered serviceable because they are glued by a special process performed at the factory to the flexible "ribbon" PCB's which are integrated into the panel itself. If you would like me to include these driver boards anyway, please indicate so at checkout. Please be warned however, that they will likely be damaged during the removal process. If you are experiencing thin narrow vertical lines, this board set will not correct the problem because the failure is most likely caused by a defective IC inside the flexible PCB itself, therefore the entire panel is considered defective. Sometimes pushing the defective "ribbon" into a different orientation will get rid of the lines. For a (most likely) temporary fix, You may attempt to retain the ribbon's new orientation by supporting it with a piece of foam, etc. I believe that any other problem than the thin vertical line issue can be fixed with this board set. Good luck!!
vavan likes this.
SlamKeys is offline
Samsung Pn50b650 50 Inch 1080p Plasma Hdtv
