How to watch cable on tv without coaxial connector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-05-2012, 05:41 AM - Thread Starter
Max-Powers's Avatar
I have a tv that does not have a coaxial cable connector. It has antenna, hdmi, vga, and rca. How can I get the coaxial cable into it? I do not have an old vcr. Is there any simple adapter?
If a TV does not have a coaxial connector, does that mean it does not have a tv tuner built in?
Max-Powers is offline
post #2 of 7 Old 01-05-2012, 06:57 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 780
What is the brand and model number of your TV? If it does not have a tuner then it's a monitor, not a TV.
How can it have "antenna" yet no coaxial RF cable connector? That doesn't make sense. "Antenna" is usually an RF connector. And it doesn't have a Component input (red/blue/green RCA)?
Are you intending to view basic cable service straight from the wall (no cable box)? If so, here are two QAM-capable/ATSC/HD converter boxes with HDMI output that should work:
http://www.solidsignal.com/pview.asp...-Tuner-CM-7001
http://www.epvision.com/HDTVSTB/phd205LEmain.htm
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 7 Old 01-05-2012, 08:48 AM
GSDTrainer's Avatar
More than likely the antenna input is used for cable also. You would just go into the TV's menu settings and do an auto channel search with "cable" selected instead of "air"
GSDTrainer is offline
post #4 of 7 Old 01-05-2012, 01:07 PM
Steve S's Avatar
Liked: 46
It would help tremendously if you posted the make/model of the set.
Years ago some sets had separate RF connectors for antenna and cable, nowadays they just have a single connector for both. If you still have the owner's manual for the set it might clear up your problem. If not, you can go to the set's mfg's website and download the manual.
Steve S.
Steve S is offline
post #5 of 7 Old 01-05-2012, 01:43 PM - Thread Starter
Max-Powers's Avatar
It is a hitachi l20a980a
That is the model. We cannot figure out how to connect the cable to it.
post #6 of 7 Old 01-05-2012, 02:27 PM
gregzoll's Avatar
Liked: 33
What country are you in? Here is what it says that this set has:
Video System: PAL, SECAM, NTSC3.58, NTSC4.43, PAL60, N-PAL, M-PAL
HDTV Compatibility: Yes
TV Scan Lines: 480i/p, 576i/p, 720p(50/60), 1080i (50/60)
TV Tuner: NTSC-M SECAM B, G / D, K / K1 PAL B, G, H / I / D, K
CableCARD Slot: No
http://www.bhphotovideo.com/c/produc...ti_System.html
Not going to work here in the USA.
gregzoll is offline
post #7 of 7 Old 01-05-2012, 02:34 PM - Thread Starter
Max-Powers's Avatar
it was bough over seas and we use a plug adapter to make it work.
so it wont work at all? not even with an adapter?
