How to: Access Samsung Service Menu 2011 'D' Models - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-11-2012, 10:52 PM - Thread Starter
chikoo's Avatar
Samsung Consumer Models
2011 "D" Models :
While the TV is in standby mode:
Press the {MUTE}, {1}, {8}, {2} & {POWER} buttons.
The TV will turn on with the Service Menu displayed.
Use the {UP} or {DOWN} buttons to select "SVC"
"PANEL DISPLAY TIME" will be one of the items listed.
To exit, press the {POWER} button.
NOTE: After exiting, all picture settings will be reset to
default values. So make sure to write down custom
adjustments before accessing the Service Menu.
Warning: Perform at your own risk. Nobody but you will be responsible for the good and bad that you end up doing!!
chikoo is offline
