Panasonic P42s2 10 blink error fix? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-12-2012, 10:27 AM - Thread Starter
Tdog1970's Avatar
I am new and need some help finding out what replacement parts I need for a 10 blink power light error on a Panonsonic P42s2 Plasma Flat screen and direction as to where to find a service manual if one is needed. From some of the posts I have read most of the parts are simply plugged in not soldered. I had the TV for 14 months before it just stopped working and its been sitting the last 5 months for me to figure out what to do with it. Please help! Thanks!!
Tdog1970 is offline
post #2 of 9 Old 01-12-2012, 12:12 PM
tomwil's Avatar
Liked: 26
Panasonic TC-P42S2 Service Manual
Panasonic TC-P42S2 Technical Guide
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #3 of 9 Old 01-12-2012, 03:53 PM
AVerFan's Avatar
Just got my P42U2 back from repair. ( warranty ) It was the SC board. Service manual, however, for 10 blinks, lists 4 boards to check; A, SC, SS & P boards. Suspect you'll find the same for 'S' unit.
AVerFan is offline
post #4 of 9 Old 01-13-2012, 02:24 AM
Tamarak's Avatar
I also just had the 10 blinks of death. Repaired under warranty last week and it was the SC board also. Repair guy said it was the most common part that went on these.
Tamarak is offline
post #5 of 9 Old 01-13-2012, 10:12 AM - Thread Starter
Tdog1970's Avatar
Thanks for the useful info! I bought the Repair manual online and it really does not tell how to determine which one of the four components is bad. Anyone out there have an idea of how to tell? Also does any one know if there is a suffix at the end of the part number for the SC Board or doesn't it matter. I have read posts on other models where the suffix matters but the part numbers online do show any suffixe for these. Maybe I sould just roll the dice and buy the SC card.
Tdog1970 is offline
post #6 of 9 Old 01-13-2012, 02:15 PM
Tamarak's Avatar
For our repair the receipt listed the part# TXNSC1LHUU for SC Board and part# TXNSC11DEK for Sub.
Tamarak is offline
post #7 of 9 Old 01-13-2012, 03:06 PM
tomwil's Avatar
Liked: 26
Not sure why you bought the service manual when the links I provided above were available for free.
Anyway, the technical guide link provided will give you troubleshooting steps to determine which board is defective.
tomwil is offline
post #8 of 9 Old 07-23-2012, 10:30 PM
PANASONICSUX's Avatar
MY TCP42U2 JUST DIED WITH THE 10 RED BLINKS OF DEATH! NO WARRANTY, PANASONIC CAN SUCK IT! THEIR TVS ARE GARBAGE!!!!!! mad.gif
PANASONICSUX is offline
post #9 of 9 Old 05-19-2015, 11:46 PM
Liked: 0
Power Supply testing tips
Someone here gave some tips on how to test the transistors on the LSEP1287 board in the P42S2, but I did not bookmark it and now can't find it.
Alternatively, is there an online source on how to do these kind of tests?
KeithMcClary is offline
Panasonic Tc P42s2 42 Inch 1080p Plasma Hdtv
