New plasma problem, looking for advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-17-2012, 07:17 PM - Thread Starter
corvetteken's Avatar
I just took delivery of my new 55 inch VT30 and encountered a problem.
I started running break in slides and noticed a small vertical line about two inches long on the right side. It mainly showed up on bright slides.
I gave it 100 hours on slides hoping it would go away and it did not so I called Panasonic.They have a tech scheduled for Friday. In the meantime I told my wife of the problem and had her take a look. To my surprise she noticed a scratch (possible crack) where the line would show up. The TV is in a dark room and I never did the "flashlight" inspection on delivery. The packaging was perfect. Now I don't know what to do.I have had the TV a week.
Any advice is appreciated.
corvetteken is offline
post #2 of 10 Old 01-17-2012, 07:22 PM
greenjp's Avatar
Quoted: 32 Post(s)
Liked: 37
Weird lines and a possible scratch or crack? Exchange it.
greenjp is offline
post #3 of 10 Old 01-17-2012, 09:49 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Originally Posted by greenjp View Post
weird lines and a possible scratch or crack? Exchange it.
+1 asap.
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #4 of 10 Old 01-17-2012, 10:47 PM
Fanaticalism's Avatar
Where did you buy it?
Fanaticalism is offline
post #5 of 10 Old 01-17-2012, 10:55 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Unfortunately it sounds like it might be physical damage and if so, it wouldn't be covered under warranty and wouldn't qualify for exchange from a retailer unless it could be proven that the damage occurred before the TV was signed for. Hopefully it's a physical defect in the panel or the glass.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 10 Old 01-17-2012, 11:03 PM
If he purchased the panel from a big box, I am sure it won't be a problem getting an exchange.
post #7 of 10 Old 01-18-2012, 06:05 AM - Thread Starter
I purchased it from Expo Electronics.
When you look close with a flashlight it looks like it got scratched at the factory because the line is uneven. I can't tell if it is a crack.
With the TV on you can't see it from 6 feet away so it's not large.
The packaging was good so it had to hapen at the factory.
My concern is they will say it is my problem.
I was going to call them today.
They have a 14 day no question return policy.
Or do I call them and simply say I want to send it back and not even get into it. it may not concern someone who is not fussy (like me).
Not sure what to do.
post #8 of 10 Old 01-18-2012, 06:08 AM
mfrey0118's Avatar
You're doing it. Let the tech look at it and go from there.
60" 1080p 3D Plasma Panel
3D 1080p Blu-Ray player
4K 7.2 Channel AVR
mfrey0118 is offline
post #9 of 10 Old 01-18-2012, 08:14 AM
"Don't PM Me Bro"
Quoted: 501 Post(s)
Liked: 768
If you honestly feel that it's a factory defect in the outer glass or the plasma panel's glass underneath, i'd return it for sure and not gamble that Panasonic will cover it, or hassle with having them replace the outer glass or the plasma panel (whichever is scratched).
If it is a defect in the plasma panel's glass then it could possibly get worse as it goes through several heat/cooling cycles as you continue to use the TV.
Randy
post #10 of 10 Old 01-18-2012, 09:45 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
I agree. I've done a lot of business with Expo and if you tell them the defect was there right out of the box they will exchange it.
Ian
mailiang is offline
