Recommend a wall mount for 65ST30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-21-2012, 06:37 AM - Thread Starter
Campindog's Avatar
A 65" Panasonic was delivered last night (it's awesome!). It's big, heavy and the power cord sticks way out the back.
What's a good wall mount for this thing that doesn't interfere with the cord and keeps it tight against the wall? No tilt wanted.
Campindog is offline
post #2 of 4 Old 01-21-2012, 10:33 AM
jnelsonwhat's Avatar
TV Wall Mount Reviews might have information on a wall mount your looking for. The Cheetah has a little tilt, but not much at all and is relatively cheap.
J
jnelsonwhat is offline
post #3 of 4 Old 01-21-2012, 11:56 AM
eonibm's Avatar
Why not just buy 4 keyhole metal brackets rated for at least 1/4 the weight of the plasma and 4 bolts from Home Depot. Screw the keyholes into the wall, the bolts into the TV and hang it? Probably cost you less than $15.
eonibm is offline
post #4 of 4 Old 01-29-2012, 06:17 PM
Rich_NY's Avatar
I ordered a 5920 from monoprice for mine....on its way.
Rich_NY is offline
