3d Plasma help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-23-2012, 06:25 AM - Thread Starter
langers_2004's Avatar
Hi,
I have a samsung pn50c490 and want to get some more glasses for it.
I know the models are ssg2100ab or ssg2200ar. However it is pretty hard to get hold of the samsung ones now and where you can they are around £60.
I was wondering if anyone knows of good alternate makes?
I found these and was wondering if people had tried them?
http://www.ebay.co.uk/itm/2508599509...84.m1423.l2648
langers_2004 is offline
post #2 of 2 Old 01-24-2012, 12:55 AM - Thread Starter
Ive also now been offered a replacement tv as my buzz was annoying me.
It has to be samsung but what should i get as a replacement.
I want it to be 3D and same size or bigger, which model should i push for from them. Im guessing it has to be of similar spec.
