Panasonic VieraCast DLNA issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-24-2012, 11:44 AM - Thread Starter
anthonybme's Avatar
I've been copying my DVD collection to MPEG-4 now that I have this DLNA device- the Panasonic Viera P60S30 with VieraCast. But I'm appalled at the issues I'm having with in-screen playback: several videos that play fine on my computer have audio a second or two ahead of the video on the Plasma.
Iron Man started fine, but about 7 or so minutes in, there was a glitch and the sync drifted. Legend of the Guardians, off by over a second- unwatchable. Tested watching Gone With the Wind, disc 1, and after a few moments, it quits out and I'm watching TV without pressing a button. I tried several times, fast forwarding to different places to try and test for audio sync. Each time, kicked back out to watching the RF input.
As I said, I open that same Legend of the Guardians file on the computer and it's perfect. So I don't know what the TV is doing differently, or what it is having trouble with.
I'm using Handbrake to rip my DVD's. I think I'll have to raise the bitrate for my MP4 rips because the color banding in the skies/darks is aweful at under 2 Mbps. But how do I fix the audio sync problems in the screen? The audio drift is not constantly off by the same amount. And the quitting out of playback has me stumped.
I've been using the standard Normal profile in Handbrake, that makes an H.264 m4v file. Some movies are more widescreen than others. Should I not have Handbrake crop the movie & leave the black in the ripped video? Should I be making an MKV file?
"Can you hear me now?"
anthonybme is offline
post #2 of 14 Old 01-31-2012, 02:20 PM - Thread Starter
anthonybme's Avatar
Really? No one else having problems?
post #3 of 14 Old 01-31-2012, 06:32 PM
ptstek's Avatar
My VT30's implementation of mkv's sucks also. I don't know why manufacturers insist on including broken 'features' like this. No problems with PS3 Media Server, by the way.
ptstek is offline
post #4 of 14 Old 02-01-2012, 09:05 AM
adone36's Avatar
Liked: 37
mkv and various other formats are merely "containers" for combined a/v. The specs of the files within them can vary (esp audio). Anybody who expects a TV to playback the dozens of different combinations perfectly is daydreaming. Anyone who has a serious collection of a/v files, etc uses a media pc which can have dozens of codecs and software that insures the proper one is used.
Tony
adone36 is offline
post #5 of 14 Old 02-02-2012, 09:42 PM
ptstek's Avatar
OK, so explain to me why my LG Bluray player can play all of my mkv's yet the tv cannot?
ptstek is offline
post #6 of 14 Old 02-03-2012, 07:43 AM
adone36's Avatar
Liked: 37
It has a matching codec. How's the picture on it?
Tony
adone36 is offline
post #7 of 14 Old 02-04-2012, 09:05 AM
jass5150's Avatar
I'd say a media server is the only sure way to go if you if you want reliable performance. It doesn't have to be a dedicated PC. I run it off one of my workstations using serviio because I am lazy and the pc has a lot of extra disk space. Eventually, I'll get around to building a dedicated unit. I use .vob but it will run any format with no problems so far, as long. As long as the codec library is up to date I don't expect any issues.
jass5150 is offline
post #8 of 14 Old 02-04-2012, 10:14 AM
mfrey0118's Avatar
The DNLA on my ST30 is a crap shoot. I never know what format it's going to play. It plays some .mov files and then does not play others, same with .avi and .mkv
Very frustrating.
60" 1080p 3D Plasma Panel
3D 1080p Blu-Ray player
4K 7.2 Channel AVR
mfrey0118 is offline
post #9 of 14 Old 02-04-2012, 02:25 PM
robnix's Avatar
Quoted: 755 Post(s)
Liked: 556
Very frustrating.
I use a dedicated HTPC. No issues with playback of any container. However, on a lark I tested out the DLNA feature. The only way I could make it work consistently was by using a DLNA server that handles Transcoding. Best of the lot was Twonky Media Server. Played anything I threw at it with zero issues. The menu system is still wife unfriendly, so we'll stick with mediabrowser for now.
Looky here!
robnix is online now
post #10 of 14 Old 09-16-2012, 10:49 PM
PhilippZ's Avatar
I use http://www.videohelp.com/tools/PS3Muxer to convert the mkv into a m2ts which is then visible in Windows Media Player/DLNA and play in my TC-P55GT30. Takes less than a minute to convert.
In my living room: Verizon FiOS, TiVO HD, Panasonic TC-P55GT30, Slingbox Classic, PS3, Sennheiser RS160
PhilippZ is offline
post #11 of 14 Old 09-17-2012, 05:56 PM
sheshechic's Avatar
Quoted: 114 Post(s)
Liked: 167
I gave up on trying to make my GT50 & BDT310 work right with DLNA. I couldn't get them to even see my computer, they could see my husband's but not mine (Windows 7 Pro issue?) So I switched to Tversity and I at least got in there, but couldn't watch anything. I'm now back to Roku and using Plex. I looooove Plex! It's like running Netflix with very little organizing work at all.
I think Samsung and LG both offer Plex. What is the problem with Panasonic?
sheshechic is offline
post #12 of 14 Old 01-29-2013, 07:58 PM
roobieroo's Avatar
Same issues here with my VT30. The only way to get reliable audio is to not pass the mp4 or m4v files straight through but to force the server to transcode on the fly. The video quality doesn't look as good as when the files go straight through but it works. Fortunately I have a PS3 which handles the mp4 and m4v files with no transcoding required and they look and sound fantastic. Given how long my TV has been around since the last software update I'd say Panasonic doesn't care about how well DLNA works, just that it's a feature you can select so they can check off another feature box.
roobieroo is offline
post #13 of 14 Old 01-04-2014, 09:03 AM
roobieroo's Avatar
I think the issue is with material that is not encoded at a framerate that matches the original source. In my testing, I think that applying detelecining and setting a variable frame rate results in a file that plays at 24.55fps instead of the original 29.97fps. If I encode the exact same material but set it for a constant framerate that matches the source, the mp4 files play back just fine on my TV. That being said, every other player I've used the problem files on doesn't have audio sync issues but the Panasonic TV does. At least now I can ensure usable files for encodes that I do myself.
post #14 of 14 Old 01-05-2014, 12:13 PM
Zcars's Avatar
Quoted: 102 Post(s)
Liked: 48
I know this an old thread, but I have just gone through the process of ripping all my DVDs to play on my S60 via an external HDD.  Some films, like the Lord of the Rings and Harry Potter series, had a jerky playback when done in Handbrake or Freemake as "same as source" to MP4.  By selecting Constant Framerate in Handbrake the playback was smooth, regardless of choosing "same as source" or 30 fps.  My 3 Stooges collection also had jerkiness and audio ahead of the video.  The only thing I found to correct the audio out of sync issue was to process it through Makemkv as a mkv file, then process in either Handbrake or Freemake as 25 fps, same as source.
Zcars is offline
Panasonic Viera Tc P60s30 60 Inch 1080p Plasma Hdtv
