Samsung D series FBr fix discussion - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #331 of 1653 Old 02-03-2012, 07:30 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1052
zoyd is offline
post #332 of 1653 Old 02-03-2012, 07:45 AM
FlasHBurN's Avatar
Quoted: 77 Post(s)
Liked: 40
FlasHBurN is offline
post #333 of 1653 Old 02-03-2012, 07:55 AM
MikeK78's Avatar
Quoted: 74 Post(s)
Liked: 62
Zoyd.. Just out of curiosity...
Since the timing board update fixes the issue, what does the rest of the firmware do? If you manually flashed the timing board and kept older firmware would the result be the same?
Mike
MikeK78 is offline
post #334 of 1653 Old 02-03-2012, 07:57 AM
hamiltonpl's Avatar
FlasHBurN says: Kudos to Samsung for finally fixing this
Correct me if I am wrong on this but KUDOS go to:
Credits
Zoyd - I did not do this alone! Thanks go to the following -
Rainer Ullrich, aka skyteddy (ruSamsungcomminucator)
LarryInRI (found method to activate usb d/l function on panels
Moderators at samygo.tv (firmware decrypting software)
Forum members (testing and reporting results - that was a great help!)
Samsung Support was MIA as far as I can tell or very slow to respond.
hamiltonpl is offline
post #335 of 1653 Old 02-03-2012, 08:08 AM - Thread Starter
zoyd's Avatar
Liked: 1052
Mike
My guess is the main FW was only to deliver the TCON update since that was what people were complaining about and also the rev #'s were minors (1024.3->1024.8 etc.). If they are smart they'll bundle it in the next major rev. assuming they can fix the bug that wouldn't allow it to install on some displays.
zoyd is offline
post #336 of 1653 Old 02-03-2012, 08:10 AM - Thread Starter
zoyd's Avatar
Liked: 1052
Credits
I did add this to the credits as I feel they do deserve credit for addressing the issue.
Samsung (for making superb plasmas and finding a way to improve them)
zoyd is offline
post #337 of 1653 Old 02-03-2012, 08:56 AM
hamiltonpl's Avatar
Yes. But. This has gone on for months with SAMSUNG not acknowledging publicly that there was an issue.
I presume you got the TCON .bin files from SAMSUNG? How? If so, then at least they provided them. The fix works albeit a bit complicated for most owners of the TV (i.e. not plug and play) - and it was self serviced by us. Chat knows nothing about this. Service techs seem to know nothing about this from what has been posted.
I have always been pleased with price and perfrormance of my Sammy. The pops to me were very annoying. The pictrue now is even more awesome.
Again Zoyd, thanks for all of you coodination on this thread.
By the way, sure would've been nice if there was some way to have entered INFO+FACTORY with the TV Remote via key combos or something.
post #338 of 1653 Old 02-03-2012, 10:13 AM
kheovnien's Avatar
updating via USB stick last night before i went to bed (59D6500). update was smooth and easy. shut off then turned back on and i thought it was finished, then it shows this
Checked the SW version and it's now 11-04-11. Just want to say thanks to everyone who helped out and for their knowledge! there should be a donate button.
kheovnien is offline
post #339 of 1653 Old 02-03-2012, 10:34 AM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
i presume you got the tcon .bin files from samsung? How? If so, then at least they provided them.
rif
AvidHiker is offline
post #340 of 1653 Old 02-03-2012, 11:37 AM
Randroid's Avatar
One question Zoyd, just for the sake of science i would love to try and use your fix method on my 59d550,even though i already installed the 1019.5 firmware and got the optimization screen.
So far i think it solved the problem, but since i want to test your method, I wanted to ask you if its safe or should i leave it as it is.
As far as i can tell the 1019.5 fw worked for me, although im not sure if the firmware (King5six1 1019.5) i used was only intended for 64 inch models and US models only.
And since i have a PL59d550 purchased in Mexico, i dont know if i should redo the fix using the Zoyd method to get better results from what i have.
Maybe using King5six1 fw on my plasma screwed something i havent realized yet.
Thanks. If you tell me is best to use your method i will post all the results.
Cheers.
Randroid is offline
post #341 of 1653 Old 02-03-2012, 12:04 PM - Thread Starter
zoyd's Avatar
Liked: 1052
zoyd is offline
post #342 of 1653 Old 02-03-2012, 12:06 PM
muslimi's Avatar
PS43D490
Panel version: DH
Logic SW: 11-04-25
0xE868
FW 1018.1
1019.5 will not work?
muslimi is offline
post #343 of 1653 Old 02-03-2012, 12:10 PM - Thread Starter
zoyd's Avatar
Liked: 1052
I don't know if 1019.5 works on 400 series, you can try it and if it doesn't work try the logic board update instructions in first post.
zoyd is offline
post #344 of 1653 Old 02-03-2012, 12:19 PM
Randroid's Avatar
The main firmware you used doesn't matter, what's your logic software version?
Heres all the info:
PL59D550
Panel version: DS
Logic ID: A824
Logic SW Version: 11-11-04
Logic SW Checksum: 0xE09B
Randroid is offline
post #345 of 1653 Old 02-03-2012, 12:20 PM - Thread Starter
zoyd's Avatar
Liked: 1052
Originally Posted by Randroid View Post
Heres all the info:
PL59D550
Panel version: DS
Logic ID: A824
11-11-04->you are all set then, no need to try different FW.
zoyd is offline
post #346 of 1653 Old 02-03-2012, 12:22 PM
Randroid's Avatar
You are a genius
Thank you for everything!.
Randroid is offline
post #347 of 1653 Old 02-03-2012, 01:02 PM
the_real_7's Avatar
update on to logic board 59d8000 worked great , now running Logic SW Version: 11-11-04 , pop free ,
THANK YOU FOR THE FIX
Samsung PN60F8500 Plasma
Samsung PN59D8000 Plasma Calibrated with fbr fix
Samsung ln52b750 Lcd ccfl
the_real_7 is offline
post #348 of 1653 Old 02-03-2012, 01:46 PM
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
How long does it take for Samsung to send the USB stick? It's been a whole week already for me.
jbug is offline
post #349 of 1653 Old 02-03-2012, 03:00 PM
Roby7108's Avatar
Zoyd Hello, I installed the fix on my 51D8000 in Italy (Europe model)
Logic SW Version: 11-10-31
pop free, Thanks to you and Larry
I would ask you, since in the U.S. the TV works with different voltages compared to Europe, if there is any contraindication to upgrade the TV firmware with an American firmware.
On my tv the picture looks slightly changed ...
Initially I had the feeling that the black level was raised, but then, after two days, it seems to me that black is always the same and instead changed the picture in general ... for the better.
Roby7108 is offline
post #350 of 1653 Old 02-03-2012, 03:22 PM - Thread Starter
zoyd's Avatar
Liked: 1052
hello and nice to hear it worked for you. The logic boards are the same for NTSC and PAL, they can handle both frequencies. The difference is in the power supply voltages (different board) and mains connection so the update works for all regions. Other people have reported slight changes in the picture after the update including a very small reduction in mll and slight increase in contrast which may require you to tweak those controls. There really haven't been any negative reports yet so I think all is good.
cheers
zoyd is offline
post #351 of 1653 Old 02-03-2012, 03:43 PM
calculus1918's Avatar
Worked for me as well with a U.S. Pn59d7000
I used McMuffin's file 1014.6 from 1st page, lucky that I didn't have to update the logic board since my firmware was 1013, got the optimization screen :-), and now a very happy customer, thanks so much for everything!!!
calculus1918 is offline
post #352 of 1653 Old 02-03-2012, 08:18 PM
chikoo's Avatar
I received the usb from Samsung for my PN59D6500 and the version info file contains this line
SWU_T-MST5AUSC_001014_I01_ES000_111206
Does it mean the software version is 11-12-06 if updated using the usb?
chikoo is offline
post #353 of 1653 Old 02-03-2012, 08:20 PM - Thread Starter
zoyd's Avatar
Liked: 1052
zoyd is offline
post #354 of 1653 Old 02-03-2012, 08:49 PM
chikoo's Avatar
If you upload the file I'll take a look and see if the .bin files are any different.
11-12-06 is the creation date of the file.
Here you go
https://docs.google.com/open?id=0Bxd...hiMTk4ZWU3ZjFj
chikoo is offline
post #355 of 1653 Old 02-03-2012, 09:03 PM
kanpol's Avatar
I did the logic board update on my 51d6500. I never got any pops since buying the tv back in july but was feeling left out so I did it anyways, it worked. I didnt see any optimizing screen though, not sure if you see that when doing from the logic board. Now Mr. Zoyd sir I have to try your voltage tweeks. I'm just waiting for the wife to be gone for the day. Just in case I do a booboo I can put the back on and play dumb. Great job to you and larry and to this whole forum for not giving up and figuring it out ourselves
kanpol is offline
post #356 of 1653 Old 02-03-2012, 09:06 PM - Thread Starter
zoyd's Avatar
Liked: 1052
Originally Posted by chikoo View Post
Here you go
yep, .bin files are identical to those in first post.
@kanpol cool, good luck. Yrr makes the most difference if you don't want to mess with the voltages.
zoyd is offline
post #357 of 1653 Old 02-03-2012, 09:16 PM
chikoo's Avatar
Originally Posted by kanpol View Post
i did the logic board update on my 51d6500. I never got any pops since buying the tv back in july but was feeling left out so i did it anyways, it worked. I didnt see any optimizing screen though, not sure if you see that when doing from the logic board. Now mr. Zoyd sir i have to try your voltage tweeks. I'm just waiting for the wife to be gone for the day. Just in case i do a booboo I can put the back on and play dumb:d. Great job to you and larry and to this whole forum for not giving up and figuring it out ourselves
+1...
chikoo is offline
post #358 of 1653 Old 02-03-2012, 10:51 PM
Piker84's Avatar
Thank you so much for this! I have been extremely frustrated with this brightness pop issue. I had Samsung replace the entire panel about 1 month into ownership. It didn't fix the issue. I've been living with it ever since and it's quite embarrassing to watch movies with friends or family with the pops showing up so often.
I was able to enjoy the latest episode of Person of Interest without any pops. In the past it was impossible to watch a single episode without several of the pops occurring. The picture quality of the image in general has seemingly increased as well. I noticed better color quality of the PS3 theme I use when I turned on the PS3 after the firmware update. None of my TV settings have changed from pre-update to new.
This is what the 2011 Samsung plasma's are supposed to look like... amazing!
Piker84 is offline
post #359 of 1653 Old 02-03-2012, 11:41 PM
Andrew Sabin's Avatar
I'm receiving a new 64D7000 tomorrow. Are new sets with the latest firmware shipping with the pops already fixed? What firmware and build date should I look far to know if the issue is resolved without loading a new firmware?
Andrew
Andrew Sabin
Andrew Sabin is offline
post #360 of 1653 Old 02-04-2012, 05:28 AM
Amazingly Smooth's Avatar
Originally Posted by piker84 View Post
thank you so much for this! I have been extremely frustrated with this brightness pop issue. I had samsung replace the entire panel about 1 month into ownership. It didn't fix the issue. I've been living with it ever since and it's quite embarrassing to watch movies with friends or family with the pops showing up so often.
I was able to enjoy the latest episode of person of interest without any pops. In the past it was impossible to watch a single episode without several of the pops occurring. The picture quality of the image in general has seemingly increased as well. I noticed better color quality of the ps3 theme i use when i turned on the ps3 after the firmware update. None of my tv settings have changed from pre-update to new.
This is what the 2011 samsung plasma's are supposed to look like... Amazing!
+1
Except, of course, in paranoid delusions for those that believe.
Amazingly Smooth is offline
Samsung , Samsung Bd D7000 3d Blu Ray Disc Player Silver , Samsung Bd D6500 Za D6500 Serivce Blue Ray Disc Player 3d Stereo
